06-17-2006, 16:09 | #1 (permalink) |
No Life Poster Join Date: Jan 2005 Location: root
Member: 111871 Status: Offline Sonork: 100.78975 Thanks Meter: 100 | VS2 Restarting I received a VS2 to unlock, all ok, went to infinity, like many times before, to do it. It starts ok, but in the end, gives msg "unlock impossible", or something like that. So, I tried unlocking with Panasolar, after unlocking it seems to be alright. But when testing the phone, I discovered that is was restarting, when pressing center button, top left or top button. To solve that, I flashed with Infinity all files, no problems during flashing, but even after flashing problem is still the same. Is there any way to get this matter solved using infinity? br |
06-17-2006, 19:56 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hi, I think it's need to make the next steps: 1. talk with panasolar support about the problem 2. check phone hardware 3. if no results after steps 1. and 2.: send me Log file after unlock try and we will see what to do. |
06-19-2006, 19:32 | #3 (permalink) |
Member: 111871 Status: Offline Sonork: 100.78975 Thanks Meter: 100 | hello, 1 - they said clip wouldnīt do that, and itīs my problem; 2 - hardware is ok, phone was working perfectly before unlocking; 3 - image attached, pls give a hand. br |
06-19-2006, 23:55 | #4 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hi, try this: http://forum.gsmhosting.com/vbb/showthread.php?t=307569 and let me know about results (and log file). |
06-20-2006, 02:36 | #5 (permalink) |
Member: 111871 Status: Offline Sonork: 100.78975 Thanks Meter: 100 | hello, now unlock worked wonderfully, but phone still restarting. this problem only occurs when entering menus, main one or message, from main screen. if none of these buttons are pressed (left, top left, up, center), phone works ok, even calls can be made. but during a call, i can access menus, and even type a sms. camera also works normally. that´s a very weird situation, I´ve unlocked dozens of those phones, and never saw something like that, and tryed everything I could think. if u have any shot, i´d be very glad, phone owner is a pain in the *** who calls every 5 minutes.. thanks for ur attention. br __________________________ log file below: Phone must be in TEST-MODE: * + # + Power Connecting, wait... Phone found, wait... Connection Ok Unlocking... Imei: 3568010042xxxxx SEC ver: 00.11Sg(0002) SW ver: NBG_LEOPARD_05.19.02SMARTI_SDB1SGOLDliteV1 MMI ver: Mmi:VS2-VH09,Jan13200611:10:35 auto-detection in progress... Unlock code: 21560235 EXACTLY STEP-BY-STEP: 1. insert ANY sim-card into phone 2. switch-on phone 3. switch-off phone 4. switch-on phone, press 52824** 5. enter unlock code 6. switch-off phone startup mode confirmed Done Finished |
06-20-2006, 08:35 | #6 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hi, I think you have a reason to check hardware. It's first time when I hear about this kind of damage. If phone was flashed with full set of files w/o errors I think need to check HW. |
06-20-2006, 16:41 | #7 (permalink) |
Member: 111871 Status: Offline Sonork: 100.78975 Thanks Meter: 100 | well, checked pcb very well with a microscope, couldn´t find anything wrong, besides, as said, checked phone before unlocking, and it was working fine. tried to flash it again, and can´t anymore, already switched cable, still same thing... gonna buy another phone today so I can get rid of this phone owner, but if you have something new, please let me know. anyway, nice update on last pana1.24a, really better! br Try #1 [Infinity Box] v.1.24A Loading, wait... S/N: 0379:0108 Standard firmware detected Wait... Current device: X60,X66,X68,X77 Ready COM1 ready Current device: VS2,VS3 Loading file [version 01]... VS2_VS3_VA47_Main.2CM.bin Loaded Loading file [version 01]... VS2_FFS1_AP_R03.2CF.bin Loaded Loading file [version 01]... VS2_VS3_GP1108.2CG.bin Loaded Loading file [version 01]... VS2_FFS2_AP_R03.2CS.bin Loaded Testing COM1 at 115200... Device: VS2,VS3 Checking data, wait... Action: Flash write Boot... Press Power button now ! Checking... Boot answer: 02 Boot Done Set Baud... Set Baud Done Connecting... FLASH ID: 0089:880D Connecting Done Check free space... Flash chip supported Check free space Done Write... Reset... Done Writing: Firmware Repair write error [A0121000]... Err: write failed[A0020000] Err: erase not confirmed Write Failed Finished Remove/Install battery now ! Time used: 132 sec Try #2 [Infinity Box] v.1.24A Loading, wait... S/N: 0379:0108 Standard firmware detected Wait... Current device: X60,X66,X68,X77 Ready Current device: VS2,VS3 Loading file [version 01]... VS2_VS3_VF10_Main.2CM.bin Loaded Loading file [version 01]... VS2_FFS2_AP_R03.2CS.bin Loaded Loading file [version 01]... VS2_FFS1_AP_R03.2CF.bin Loaded Testing COM1 at 115200... Device: VS2,VS3 Checking data, wait... Action: Flash write Boot... Press Power button now ! Checking... Boot answer: 02 Boot Done Set Baud... Set Baud Done Connecting... Connecting Failed Finished Remove/Install battery now ! Time used: 16 sec Try #3 Testing COM1 at 115200... Device: VS2,VS3 Checking data, wait... Action: Flash write Boot... Press Power button now ! Checking... Err: wrong Boot answer2: Boot answer: 00 Err: unknown hardware Boot Failed Finished Remove/Install battery now ! Time used: 5 sec |
E72 keep restarting ..... any help with hardware solution?? | abu_nairoukh | Nokia Hardware & Hardware Repair | 4 | 12-14-2010 11:10 |
need help master manole n95-8gb write screen restart | haslyn | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 15 | 03-30-2010 10:56 |
Restart your Friend's cell phone using sms | kashem403342 | Nokia Hardware & Hardware Repair | 3 | 03-29-2010 13:45 |
Restart your Friend's cell phone using sms | kashem403342 | Nokia Base Band 5 ( BB-5 ) | 0 | 03-29-2010 11:57 |
p900 restart restart restart restart | clinic*mobile | Sony Ericsson | 2 | 05-31-2004 11:33 |
