08-04-2011, 18:10 | #1 (permalink) |
No Life Poster Join Date: Aug 2010 Location: HGJIKL
Member: 1360208 Status: Offline Thanks Meter: 133 | Huawei g6620 unlock problem.need help from team. module v3.99 Action: read unlock codes unlock method: read codes Model: Huawei-G6620 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6253:8A02:8A00]... CPU: MT6253 high speed boot On chip: 0000:0000:000F status: FF Connecting at 19200, wait... error: can not finalize test mode repeat operation and HOLD phone "Power" button more long time ! error: operation failed ! Finished, time used: 1 min 24 sec Remove/Install battery now ! WE have 3 new phones,and all result same when we do as usuall.before some time we unlocked this ,model with out any problem.but now can,t .cables are good.tried with lg gw300+lg gs 101 .soft take info but keep givng error on end.batteries well charged.what more can do?tried with V3.92 and v3.99 .tried press power button long time+short time.all but not luck.please help. |
08-04-2011, 19:19 | #2 (permalink) |
Member: 1360208 Status: Offline Thanks Meter: 133 | Phone go in test mode,white screen but soft say error. COM4 [VCP0] selected module v3.79 Action: read unlock codes unlock method: read codes Model: Huawei-G6620 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6253:8A02:8A00]... CPU: MT6253 chip: 0000:0000:000F status: FF Connecting at 19200, wait... error: can not finalize test mode repeat operation and HOLD phone "Power" button more long time ! error: operation failed ! Finished, time used: 1 min 17 sec Remove/Install battery now ! |
The Following User Says Thank You to swisss For This Useful Post: |
08-04-2011, 23:21 | #3 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | Please, read full flash from this phone and send full flash backup (or RapidShare – Secure Data Logistics or 4shared.com - free file sharing and storage link) to [email protected] Thank you ! |
08-04-2011, 23:52 | #5 (permalink) |
Junior Member Join Date: Oct 2007 Location: SPAIN
Member: 615685 Status: Offline Thanks Meter: 1 | por favor, necesito ayuda, estoy peleandome hace unos cuantos dias, y tengo prisa para arreglar el telefono que he estropeado con infinity box, porque sino el cliente me va a matar, por favor que alguien se conecte conmigo en privado o aqui para explicarle. |
08-05-2011, 08:22 | #6 (permalink) | |
Member: 1360208 Status: Offline Thanks Meter: 133 | Quote:
module v3.99 Device: Huawei-G6620 Checking data, wait... Action: read flash NAND interface: BROM_DLL_v3.1016.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! bootcode current/expected: 0.0/3.2 CPU: 6253:8A02:8A00 status: 00 bbchip bl ver: 00 NOR flash id[0000]: 0000:000000000000 [AMD] AM29DL323D chip size: 0Mb otp status/size: S_DONE/00000000 NAND flash id[0000]: 0000:000000000000 [SAMSUNG] K9F5608Q0C chip size: 0Mb page/spare size: 0000/0000 pages per block: 0000 bits i/o: 00 address cycles: 00 internal RAM size: 00000000 external RAM [HW_RAM_UNKNOWN, CS0] size: 00000000 sec error code: 00 error: can not boot device: 07E8:S_BROM_SPEEDUP_BAUDRATE_FAIL error: last error: 07E8:S_BROM_SPEEDUP_BAUDRATE_FAIL Disconnect... done Finished, time used: 22 sec Remove/Install battery now ! even can not read full flash?where i am wrong | |
08-05-2011, 08:32 | #7 (permalink) |
Member: 1360208 Status: Offline Thanks Meter: 133 | COM4 [VCP0] selected module v3.99 Device: Huawei-G6620 Checking data, wait... advanced flash detection enabled Action: read/check information ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6253:8A02:8A00]... CPU: MT6253 high speed boot On chip: 0000:0000:000F status: FF error: can't set initial baud Release Power button now ! in case of initial connection problem: on/off "Boot baudrate autoselect" Boot Fail Finished, time used: 10 sec Remove/Install battery now ! |
08-05-2011, 10:38 | #8 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | Yes, I read previous message well. I do not see anything special or new in this phone hardware (according to given log text). What to do: press and HOLD phone power button during boot/read process. Waiting for results. |
08-05-2011, 15:09 | #10 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | Hello, Thank you, but I do not use TeamViewer for this kind of tests. Please, just try to repeat flash read operation again, but press and HOLD phone power button during boot/read process |
08-06-2011, 03:55 | #12 (permalink) |
Member: 1360208 Status: Offline Thanks Meter: 133 | You should use team viere or any method,when ur tool user facing problem.you must know about ......... Any way do as u say But same result. Last edited by InfinitySupport; 08-06-2011 at 12:08. Reason: advertizing deleted |
08-06-2011, 09:15 | #13 (permalink) |
Member: 1360208 Status: Offline Thanks Meter: 133 | Same error COM4 [VCP0] selected module v3.99 Action: read unlock codes unlock method: read codes Model: Huawei-G6620 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6253:8A02:8A00]... CPU: MT6253 high speed boot On chip: 0000:0000:000F status: FF Connecting at 19200, wait... error: can not finalize test mode repeat operation and HOLD phone "Power" button more long time ! error: operation failed ! Finished, time used: 1 min 17 sec Remove/Install battery now ! |
08-06-2011, 10:16 | #14 (permalink) |
Member: 1360208 Status: Offline Thanks Meter: 133 | Flash information by infinity box.let logs COM4 [VCP0] selected module v3.99 Device: Huawei-G6620 Checking data, wait... Action: read flash NAND interface: BROM_DLL_v3.1016.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6253:8A02:8A00 status: FF bbchip bl ver: FE NOR flash id[0064]: 0089:890400000000 [INTEL] PF48F40xxM0x1xx chip size: 32Mb otp status/size: S_DA_NOR_OTP_EXIST/00000108 NAND flash chip: not installed internal RAM size: 00020000 external RAM: absent done Set baudrate (115200)... done ram test... testing 32bit... 32bit ram test passed testing 16bit... 16bit ram test passed ram test passed ===> detect existing firmware structure... detect ffs... ffs offset/size: 00000000/00000000 detect sec ro... detect custom parameters... detect project-id... project-id: G6620SS_C210_M40_05_03N detect NOR info... number of areas/bytes to read: 1:00050000 reading (HW_STORAGE_NOR)... TCL-ID detection... TCL-ID detection done startup code area #1 detection... number of areas/bytes to read: 1:00001000 reading (HW_STORAGE_NOR)... number of areas/bytes to read: 1:00001000 reading (HW_STORAGE_NOR)... startup code area #1 is invalid startup code area #1 detection done rom info ver: 07 sw version: SJ_S0A_HW_VODAFONE_NUMONYX_PCB01_GPRS_MT6253_S00.G 6620SS_C210_M40_05_03N.BIN_FLNPF38F4050M0Y3DE project-id: G6620SS_C210_M40_05_03N, 2C49FFDF code offset: 00000000 ffs offset/size [02]: 01800000/00800000 rom info structure: [protected] type (07), 1 record(s) TCL-ID is absent ===> done area size: 32Mb number of areas/bytes to read: 1:02000000 reading (HW_STORAGE_NOR)... error: can not read memory: 0FAA:S_FT_READBACK_FAIL can not read memory, errorcode: 0FAA it may be problem with current operation error: last error: 0FAA:S_FT_READBACK_FAIL Disconnect... done Finished, time used: 59 min 18 sec Remove/Install battery now ! |
need ericsson 88 cable | migdamas | Old Ericsson Phones & Sony Phones | 2 | 03-24-2017 16:24 |
need eeprom photo???? | mobileinfo | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 05-26-1999 11:35 |
