225 unlocked COM5 [VCP0] selected module v1.57 Device: ZTE-225, Vodafone-225 Checking data, wait... Action: unlock unlock method-1 Boot ... Press and HOLD Power button now ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 921600 Set Baud Done Connecting ... flash: 00EC:22A0 Connecting Done Check hardware ... sw version: -KE-P108A2V1.0.0B06 16 03 44 Oct 31 2007 16 03 44 04.12.00 18.26 Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-225, Vodafone-225_eeprom-static_20081201-152900.B1E.bin loading data... data loaded reading eeprom-security... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-225, Vodafone-225_eeprom-security_20081201-152900.B1E.bin reading eeprom-complete... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-225, Vodafone-225_eeprom-complete_20081201-152902.B1E.bin reading additional data... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-225, Vodafone-225_lock-area_20081201-152903.B1E.bin backup critical area Done Check memory ... lock found Check memory Done Write ... Erasing: lock-area Writing: lock-area Write Done Finished, time used: 20 sec Remove/Install battery now ! thanks infinity team for your good work |
Thank you very much for test report ! Each test report with attached logs is very important for us so we can see how is Infinity-Box software works and what is possible problems (so we will be able to fix it) and successfully done work. |
Good test report dude keep it up |
