07-31-2008, 10:01 | #17 (permalink) |
Freak Poster Join Date: Sep 2005 Age: 43
Member: 176522 Status: Offline Thanks Meter: 17 | coral 100 still can't unlock with this update....i tried to flash it with zte125 but still the same...you cannot enter the lock code..heres the log: COM3 [VCP0] selected Device: Coral-100 Checking data, wait... Action: unlock unlock method-1 Boot... Press and HOLD Power button now (if boot does not start remove/install batery) ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud... 230400 Set Baud Done Connecting... flash: 0001:22C4 Connecting Done Check hardware... Check hardware Done Check parameters... Check parameters Done backup critical area... reading [eeprom-sta]... file saved: C:\Program Files\InfinityBox\Pana01\Coral-100_eeprom-sta_20080731-171520.B1E.bin loading data... data loaded reading [eeprom-sec]... file saved: C:\Program Files\InfinityBox\Pana01\Coral-100_eeprom-sec_20080731-171525.B1E.bin reading [eeprom-complete]... file saved: C:\Program Files\InfinityBox\Pana01\Coral-100_eeprom-complete_20080731-171530.B1E.bin reading additional data... done backup critical area Done Check memory... current status: 0 Check memory Done Write... Erasing: lock-area Writing: lock-area Write Done Finished, Remove/Install battery now ! Time used: 249 sec Unlock instruction: 1. Power-On phone 2. Enter code: 12345678 |
08-01-2008, 14:00 | #19 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,228 | Hello, Make flash backup for emergency case. Try to use this file for flashing: ZTE-A35_Main_LP_TELMA-P108A5B01-Fr-MG01_g3dBV2.0_Jun-19-2007 Make unlock again |
11-18-2008, 05:49 | #23 (permalink) | |
Freak Poster Join Date: Nov 2002
Member: 17851 Status: Offline Thanks Meter: 151 | Quote:
Been Flashing and unlocking this after soooo long time, finally got the right Flashfile to REALLY unlock this fone. Finally, DOne! Thanks Infinity. PS: to change language to English: Menu 4,1,1>english | |
11-21-2008, 13:52 | #24 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,228 | Hello, Please, try to use this new Pana01 v1.56 software: http://www.infinity-box.com/download...na01_v1.56.rar We are waiting for your results. |
12-10-2008, 19:35 | #25 (permalink) |
Freak Poster Join Date: Jul 2006 Location: ONLY WITH YOU Age: 39
Member: 314847 Status: Offline Thanks Meter: 102 | flash complete on bleu 351x thanx to infinity COM11 [Serial2] selected module v1.57 Device: Bleu-351x Checking data, wait... Action: flash write Boot ... Press and HOLD Power button now ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 115200 Set Baud Done Connecting ... flash: 0001:011A Connecting Done Check hardware ... Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\Bleu-351x_eeprom-static_20081210-235544.B1E.bin loading data... data loaded reading eeprom-security... file saved: C:\Program Files\InfinityBox\Pana01\Bleu-351x_eeprom-security_20081210-235545.B1E.bin reading eeprom-complete... file saved: C:\Program Files\InfinityBox\Pana01\Bleu-351x_eeprom-complete_20081210-235551.B1E.bin backup critical area Done Check memory ... Check memory Done Write ... Erasing: Firmware Writing: Firmware Erasing: Firmware Writing: Firmware Erasing: Firmware Writing: Firmware Write Done Finished, time used: 85988 sec Remove/Install battery now ! |
SKY SK1 Problem In Flashing | maplegsm | Infinity-Box | 6 | 01-22-2009 08:57 |
10 Nov 2008: SE-R300, R306, BenQ-Siemens-T33, T51, LG-KG180, MG170 models in test | InfinitySupport | Infinity-Box | 34 | 12-24-2008 19:04 |
10 Nov 2008: SE-R300, R306, BenQ-Siemens-T33, T51, LG-KG180, MG170 models in test | Infinity-Box | Service Products News & Updates | 0 | 11-10-2008 10:44 |
15 Jul 2008: KG208, KP230, KP235 models in test | InfinitySupport | Infinity-Box | 37 | 10-23-2008 14:03 |
13 Aug 2006: TCL Q550 model in test | InfinitySupport | Infinity-Box | 1 | 08-13-2006 20:56 |
