06-16-2016, 16:35 | #1 (permalink) |
Cheater -Don't Deal with him- Join Date: Feb 2003 Location: gsmcity Age: 44
Member: 21296 Status: Offline Thanks Meter: 328 | Meizu Note 2 how to service that model? 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 19 ] Sync... Inital Boot Ok! BB_CPU_PID : 6735 BB_CPU_NME : [MediaTek] MT6735_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1620.10.01 Sending and initialize DA ... [DA_ERROR] : SECURITYBOOT_BOOT_NOT_ACCEPTED Boot Error! Also Huawe Y330 can not be flashed via our paid tool, while can be easily services using original SP flashtool and many other options missing many phones I can't flash with the flash files that I have from the net, while I flash those phones successfully with SP flashtool. What is the purpose of buying this tool? |
06-16-2016, 17:17 | #4 (permalink) | |
No Life Poster Join Date: Dec 2004 Location: Uganda Age: 45
Member: 96478 Status: Offline Sonork: 100.1674604 Thanks Meter: 1,421 | Quote:
I think there is no Box on this forum fully supports Meizu phones. Hope team Will add it soon, stay tuned,you will get the purpose of buying this Tool. Wbr | |
06-16-2016, 17:46 | #5 (permalink) |
Member: 21296 Status: Offline Thanks Meter: 328 | Tell me how do you flash Huawei Y330 then? It is impossible or even if it is possible it takes 20 minutes till you find the way, but using free SP tool just select files inside Rework-Secro folder first and then all the files from the main firmware folder, and in 7 minutes we have a working phone.. Cm2MTK says: [SCATCHECK] : Missing File : \USB_Upgrade\Rework-Secro\MBR [SCATCHECK] : Scatter wrong or incomplete. Use Factory or CM2MTK Scatter! for Y330 flashing |
06-16-2016, 18:40 | #6 (permalink) | |
Seems you are PLANTED HERE BY COPY TOOLS DID YOU BOUGHT CM2 FOR FLASHING Y330 ONLY ?? if its true,better through it AWAY to DUSTBIN. Leave Proffessional CM2,Better use SPF TOOL Forever. Good luck Thanks for Understanding. | |
