01-03-2017, 19:58 | #1 (permalink) |
No Life Poster Join Date: Sep 2007 Location: around
Member: 595864 Status: Offline Thanks Meter: 163 | 354252068948792 unlock error i got this order : Order/Transaction ID: 774951/1018755 Date: 2016-12-24 13:42:19 Amount/Credits: -17 Credits From/To: System Product: SL3 unlock code (15 digits) Status: COMPLETED Tag: 354252068948792 Result: 412314247896486 hello. unlock error with this code 412314247896486. tried manually all levels 1 to 7. tried Check Unlock options in BEST, error. saved RPL and restored with Counters reset, but error. Also restored RPL and repaired sec method 1 and same error. Phone is 15 NCK as BEST detected it. i doubt anyone else tried to unlock it before. pls clear situation. thanks |
01-03-2017, 22:50 | #2 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | Reset phone to defaults and then enter code via keyboard #pw+412314247896486+7# If code is not accepted it's good idea to explain what is thee problem with phone bacause iof you starrt to make repair/rpl etc. means you know something about your phone. |
01-03-2017, 23:08 | #3 (permalink) | |
Member: 595864 Status: Offline Thanks Meter: 163 | Quote:
thought counter may be blocked and thats why i saved and restored RPL with check on Clear Counter... i user 2.25. should i try with an older version ? any other ideea ? thanks | |
01-04-2017, 00:09 | #5 (permalink) |
Member: 595864 Status: Offline Thanks Meter: 163 | Phone found! MTKx Nokia Phone detected Read info... Ok Reading Phone Info.... Software ver : 20.10.11 00-00-00 RM-1012 IMEI 1 : 354252068948792 IMEI 2 : 123456789012345 XappVer : 000008CA Ape Ver : NEMO G 59cb152c/0 (59cb152c+0) T Mon Jul 1 02:50:44 2013 U 69b804d5 PPM : EA CNT : PEARL.20.10.11.p1 Product SN : 6C4B989AU Product code : 059W345 Base Prd.code: 059W428 Module code : 0206306 Hardware info======= HWID : 3401 LCDVer: TPO Lock info =========== IMEI : 354252068948792 IMEI spNet : 3A 45 52 02 86 49 78 29 Conf key : 800000000003000B Provider key : 2261000000000000 Country : Romania Operator : RO ORANGE Lock info: Block 1 L1:Close; SimLock status : Ok Security status : Ok Done! |
01-04-2017, 00:21 | #6 (permalink) |
Member: 595864 Status: Offline Thanks Meter: 163 | Card found: S/N : ....... , v0118 Registered to: ...... Connect phone on selected interface... Phone found! MTKx Nokia Phone detected Read info... Ok Reading Phone Info.... Software ver : 20.10.11 00-00-00 RM-1012 IMEI 1 : 354252068948792 IMEI 2 : 123456789012345 XappVer : 000008CA Ape Ver : NEMO G 59cb152c/0 (59cb152c+0) T Mon Jul 1 02:50:44 2013 U 69b804d5 PPM : EA CNT : PEARL.20.10.11.p1 Product SN : 6C4B989AU Product code : 059W345 Base Prd.code: 059W428 Module code : 0206306 Hardware info======= HWID : 3401 LCDVer: TPO Lock info =========== IMEI : 354252068948792 IMEI spNet : 3A 45 52 02 86 49 78 29 Conf key : 800000000003000B Provider key : 2261000000000000 Country : Romania Operator : RO ORANGE Lock info: Block 1 L1:Close; SimLock status : Ok Security status : Ok Done! Card serial: ........ Card type: BEST Dongle Card password: ...... Link to my account: http://user.infinity-best.com Login: ........ Connecting to server... Credits: 11 Unlock procedure started... Using F-bus count... Sending code 412314247896486 Level : 7 to SimLock Server... Simlock Server Answer: Error (i had this problem in the past on other phones and after RESETing Counter, accepted code. so this is why i tried to save and restore RPL and reset counter) Done! ++++++++++++++++++++++++++++++++++ Reading Phone Info.... Software ver : 20.10.11 00-00-00 RM-1012 IMEI 1 : 354252068948792 IMEI 2 : 123456789012345 XappVer : 000008CA Ape Ver : NEMO G 59cb152c/0 (59cb152c+0) T Mon Jul 1 02:50:44 2013 U 69b804d5 PPM : EA CNT : PEARL.20.10.11.p1 Product SN : 6C4B989AU Product code : 059W345 Base Prd.code: 059W428 Module code : 0206306 Hardware info======= HWID : 3401 LCDVer: TPO Lock info =========== IMEI : 354252068948792 IMEI spNet : 3A 45 52 02 86 49 78 29 Conf key : 800000000003000B Provider key : 2261000000000000 Country : Romania Operator : RO ORANGE Lock info: Block 1 L1:Close; SimLock status : Ok Security status : Ok Done! Sending NCK code to phone ... NCK Code Sent! Conf key : 800000000003000B Provider key : 2261000000000000 Country : Romania Operator : RO ORANGE Lock info: Block 1 L1:Close; Terminal locked! Reading Phone Info.... Software ver : 20.10.11 00-00-00 RM-1012 IMEI 1 : 354252068948792 IMEI 2 : 123456789012345 XappVer : 000008CA Ape Ver : NEMO G 59cb152c/0 (59cb152c+0) T Mon Jul 1 02:50:44 2013 U 69b804d5 PPM : EA CNT : PEARL.20.10.11.p1 Product SN : 6C4B989AU Product code : 059W345 Base Prd.code: 059W428 Module code : 0206306 Hardware info======= HWID : 3401 LCDVer: TPO Lock info =========== IMEI : 354252068948792 IMEI spNet : 3A 45 52 02 86 49 78 29 Conf key : 800000000003000B Provider key : 2261000000000000 Country : Romania Operator : RO ORANGE Lock info: Block 1 L1:Close; SimLock status : Ok Security status : Ok Done! |
01-04-2017, 06:48 | #7 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | Order refunded. Do not upload it any more, it will be no other code. its not a problem with code but its something with your phone |
