A 38 (Benq-Siemens) Restart Solved A 38 (Benq-Siemens) with restart problem has successfully been repired by Infinity Box. Thanks to this wonderful team of their excellent support COM4 [VCP0] selected module v1.31 Device: BenQ A38 Checking data, wait... Action: flash write "smart write" active Write: Firmware Skip: Flex Write: Language Pack Skip: Eeprom Boot... Phone should be Switched OFF ! Press Power button now ! Connecting... Boot Done Check Connection... Check Connection Done Set Baud... 406250 Set Baud Done Check Flash... Check Flash Done Check Parameters... Check Parameters Done Check Space... Flash: 0001:227E221D2200 flash: Amd S29GL032A-U r1,r2,r8,r9 U 4Mb Check Space Done Check Data... Check Data Done Erasing... erase operation not required Erasing Done Writing... Write: Firmware Flash: 0001:227E221D2200 flash: Amd S29GL032A-U r1,r2,r8,r9 U 4Mb Write: Language Pack flash: Amd S29GL032A-U r1,r2,r8,r9 U 4Mb Writing Done Finished, time used: 192 sec Remove/Install battery now ! |
Each test report with attached logs is very important for us so we can see how is Infinity-Box software works, what is phone hardware configuration (f.e. flash chip type) and what is possible problems (so we will be able to fix it) and successfully done work. |
