Old 11-04-2016, 12:10   #1 (permalink)
Member: 2384553
Thanks Meter: 85
5051x frp
phone not detecting to software drivers perfectly installed
Operation : Reset Settings [ v1.01 ]
2. PRESS and HOLD BOTH VOLUME KEYS!
3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode!
Wait for phone...
Device not found!
Check cable, connection and drivers!
Reconnect Power/Cable!
Old 11-04-2016, 12:43   #2 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 20,352
Hello.
You not installed drivers as manual require.
Old 11-04-2016, 21:29   #3 (permalink)
Member: 2384553
Thanks Meter: 85
i did install drivers correctly and furious gold detected and remove frp successfully but after reset phone still have frp but when i am trying to clear with infinity its show this error . phone is show correct drivers in device manager . please help me
Old 11-04-2016, 21:35   #4 (permalink)
JayDi's Avatar
Member: 462970
CM2 not work with native QHS_PORT_9008.
In manual explained what need install.
The Following 2 Users Say Thank You to JayDi For This Useful Post:
Old 11-04-2016, 21:52   #5 (permalink)
Member: 2384553
Thanks Meter: 85
i install drivers qcom infinity drivers (QLM_Drivers_v1.00) but its not install . please guide me .
Old 11-04-2016, 21:55   #6 (permalink)
Member: 2384553
Thanks Meter: 85
i am using win7 and install all these and when trying to install manual from withxp folder its show mokia connectivity driver .
EmergencyDownloadDriver
WinUsbCoInstallers
WinUsbCompatIdInstaller
WinUsbDriversExt
Old 11-04-2016, 22:00   #7 (permalink)
Member: 2384553
Thanks Meter: 85
Done
Wait for phone...
Device Found!
Initialize ...
Handshake passed!
BB_IDC_CPU : SnapDragon 210 [MSM8909]
ID_BLOCK_S : 039C5BDF
ID_BLOCK_I : 009600E1
ID_BLOCK_L : 49C762F6FE52E492
ID_BLOCK_L : 9B939302A85331CC
Use CM2 Internal Loader
Loader Sent! Initializing ...
Running FireHose on BBID : MSM8909 , FLASH : eMMC , VER : 1
ExtInfo : 0x0000C000/00100000/00001000/00001000
Boot Ok!
Format USER ...
Format CACHE ...
Format Ok!
Remove FRP ( Google Reset Protection )
FRP removed!
Done!
Elapsed: 00:00:13
The Following 2 Users Say Thank You to daddyunl0cker1 For This Useful Post:
Page generated in 0.16873 seconds with 8 queries
