12-19-2009, 09:19 | #1 (permalink) |
No Life Poster Join Date: Jul 2009 Location: philippines now here in U.A.E Age: 38
Member: 1070665 Status: Offline Sonork: 100.1636802 Thanks Meter: 572 | 5310 china phone dead for infinity box the problem only hung up COM10 [VCP0] selected module v2.84 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: write NOR flash "smart write" active write: Firmware skip: Customization/Language Pack skip: Customization write: Eeprom/ffs ffs/eeprom backup enabled, it may takes several minutes ! Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:2A03:0002 status: FF boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: 98000300000001:18A59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb detecting chip #01 in region #00... flash: 98000300000001:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb detecting chip #02 in region #00... flash: 98000300000001:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb detecting chip #03 in region #00... flash: 98000300000001:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb number of flash chip/regions detected: 04/01 Initialize Done Set baud ... 460800 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... device parameters autodetection in progress... detecting chip #00 in region #00... flash: 98000300000001:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb detecting chip #01 in region #00... flash: 98000300000001:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [enhanced] generation security area (code #1) is Ok security area (code #1) backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.61B6DF83.[RHY25_06B_PCB01_GPRS_MT6225_S00.A51_V00_01.BIN_FCF FB73C].rpl identification#1 detection finished device-id: 61B6DF83 identification#1 protocol ver: 04 ver. sw 1: RHY25_06B_PCB01_GPRS_MT6225_S00.A51_V00_01.BIN ver. sw 2: A51.V00.01, C3480003 ffs offset/size: 00E00000/00200000 detect device identification#2... detection phase #1... . detect device identification#2 finished detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00E00000 flash: 98000300000001:18E59F00000000 checking area [00000000]: 00000000-00FFFFFF... ffs/eeprom found near: 00FA0000 Detected ffs/eeprom address is non-standard: 00FA0000 Posible reasons: 1. ffs/eeprom is Ok but address is non-standard 2. ffs/eeprom is damaged and can't be detected 3. ffs/eeprom is Ok but detected incorrectly (f.e. unknown ffs/eeprom structure) If you are not sure that detected address is correct: 1. press "NO" (and select standard address or terminate current operation) 2. make full flash backup for emergency case 3. repeat required operation Are you sure that detected ffs/eeprom address is correct ? autodetected ffs/eeprom address confirmed by user: 00FA0000 detecting ffs/eeprom size... ffs/eeprom size: 00060000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00FA0000-00FFFFFF Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... reading: RHY25_06B_PCB01_GPRS_MT6225_S00.A51_V00_01__ffs... file saved: C:\Program Files\InfinityBox\ChineseMiracle\RHY25_06B_PCB01_G PRS_MT6225_S00.A51_V00_01__ffs_20091219-161809.B0E.bin flash: 98000300000001:18E59F00000000 Backup required data Done Patch required data ... Patch required data Done Special operation ... Special operation Done Write ... detect device identification#2... detection phase #1... . detect device identification#2 finished security area (code #1) calculation... done detecting security area (code #2)... security area (code #2) is absent file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\R HY25_06B_PCB01_GPRS_MT6225_S00.A51_V00_01__system_ log_61B6DF83_FCFFB73C_20091219-162519.B0X.bin Area: Firmware flash: 98000300000001:18E59F00000000 Write: Firmware Area: Eeprom/ffs flash: 98000300000001:18E59F00000000 Write: Eeprom/ffs detect device identification#2... detection phase #1... . detect device identification#2 finished Write Done Finalization ... Finalization Done file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\R HY25_06B_PCB01_GPRS_MT6225_S00.A51_V00_01__system_ log_61B6DF83_FCFFB73C_20091219-162713.B0X.bin Finished, time used: 701 sec Remove/Install battery now ! complete but not switch on .................... |
12-19-2009, 09:28 | #3 (permalink) |
Member: 1070665 Status: Offline Sonork: 100.1636802 Thanks Meter: 572 | pleas tell me how to solve this i try format but say this COM10 [VCP0] selected module v2.84 Action: reset settings Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:2A03:0002 status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6225,E05 Date: 2006.06.14 Version: 1.0 Version: A51.V00.01 Version: RHY25_06B_HW detecting structure #2... 0 done 44 byte(s) read imei: 13579024682211 connection Ok building list... done items to clear: 127 warning: wrong packet cs items cleared: 87 of 127 items remains: 0 Finished, time used: 235 sec Remove/Install battery now ! |
12-19-2009, 11:45 | #6 (permalink) |
Member: 1070665 Status: Offline Sonork: 100.1636802 Thanks Meter: 572 | COM10 [VCP0] selected module v2.84 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection disabled Action: write NOR flash "smart write" active write: Firmware skip: Customization/Language Pack skip: Customization write: Eeprom/ffs ffs/eeprom backup enabled, it may takes several minutes ! Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:2A03:0002 status: FF boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: 98000300000001:FFFFFF00000000 flash: Toshiba T 16Mb detecting chip #01 in region #00... flash: 98000300000001:FFFFFF00000000 flash: Toshiba T 16Mb detecting chip #02 in region #00... flash: 98000300000001:FFFFFF00000000 flash: Toshiba T 16Mb detecting chip #03 in region #00... flash: 98000300000001:FFFFFF00000000 flash: Toshiba T 16Mb number of flash chip/regions detected: 04/01 Initialize Done Set baud ... 460800 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... device parameters autodetection in progress... detecting chip #00 in region #00... flash: 98000300000001:FFFFFF00000000 flash: Toshiba T 16Mb Warning: probably flash chip is empty, erased, incorrectly flashed or damaged ! What to do: 1. go to software "Settings" page 2. set "Advanced chip detection method" box CHECKED ! 3. make flash write operation If still no luck: send mail to support ([email protected]) with detailed description of problem, attach the next files in your e-mail: 1. C:\Program Files\InfinityBox\ChineseMiracle\operation.log 2. C:\Program Files\InfinityBox\ChineseMiracle\cfi_xxxx_xxxx.bin detecting chip #01 in region #00... flash: 98000300000001:FFFFFF00000000 flash: Toshiba T 16Mb it's time to stop: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... . detection phase #2... .................................................. .................................................. .................................................. .................................................. .................................................. ...... warning: identification#1 information not found, possible reasons: .old firmware type w/o identification#1 data .damaged firmware .damaged hardware if phone works fine just ignore this warning detect device identification#1 finished detect device identification#2... detection phase #1... . detect device identification#2 finished detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset assigned: 00E00000 flash: 98000300000001:FFFFFF00000000 checking area [00000000]: 00000000-00FFFFFF... ffs/eeprom found near: 00E00000 detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... reading: _ffs... file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\_ ffs_20091219-185717.B0E.bin flash: 98000300000001:FFFFFF00000000 Backup required data Done Patch required data ... Patch required data Done Special operation ... Special operation Done Write ... detect device identification#1... detection phase #1... . detection phase #2... .................................................. .................................................. .................................................. .................................................. .................................................. ...... warning: identification#1 information not found, possible reasons: .old firmware type w/o identification#1 data .damaged firmware .damaged hardware if phone works fine just ignore this warning detect device identification#1 finished detect device identification#2... detection phase #1... . detect device identification#2 finished detecting security area (code #2)... security area (code #2) is absent Area: Firmware flash: 98000300000001:FFFFFF00000000 Write: Firmware error: error# 000000A4 error: flash write error: 00020000:00002000 error: error# 000000A4 error: flash write error: 00020000:00002000 error: error# 000000A4 error: flash write error: 00020000:00002000 error: error# 000000A4 error: flash write error: 00020000:00002000 error: error# 000000A4 error: flash write error: 00020000:00002000 error: error# 000000A4 error: flash write error: 00020000:00002000 error: error# 000000A4 error: flash write error: 00020000:00002000 error: error# 000000A4 error: flash write error: 00020000:00002000 error: error# 000000A4 error: flash write error: 00020000:00002000 error: error# 000000A4 error: flash write error: 00020000:00002000 error: error# 000000A4 error: flash write error: 00020000:00002000 error: error# 000000A4 error: flash write error: 00020000:00002000 error: error# 000000A4 error: flash write error: 00020000:00002000 error: error# 000000A4 error: flash write error: 00020000:00002000 error: error# 000000A4 error: flash write error: 00020000:00002000 detect device identification#2... detection phase #1... . detect device identification#2 finished Write Fail Finished, time used: 332 sec Remove/Install battery now ! |
12-19-2009, 13:01 | #8 (permalink) | |
Member: 1070665 Status: Offline Sonork: 100.1636802 Thanks Meter: 572 | Quote:
here in format ffs complete COM10 [VCP0] selected module v2.84 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection disabled Action: "format ffs" ffs/eeprom backup enabled, it may takes several minutes ! Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:2A03:0002 status: FF boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: 98000300000001:FFFFFF00000000 flash: Toshiba T 16Mb detecting chip #01 in region #00... flash: 98000300000001:FFFFFF00000000 flash: Toshiba T 16Mb detecting chip #02 in region #00... flash: 98000300000001:FFFFFF00000000 flash: Toshiba T 16Mb detecting chip #03 in region #00... flash: 98000300000001:FFFFFF00000000 flash: Toshiba T 16Mb number of flash chip/regions detected: 04/01 Initialize Done Set baud ... 460800 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... device parameters autodetection in progress... detecting chip #00 in region #00... flash: 98000300000001:FFFFFF00000000 flash: Toshiba T 16Mb Warning: probably flash chip is empty, erased, incorrectly flashed or damaged ! What to do: 1. go to software "Settings" page 2. set "Advanced chip detection method" box CHECKED ! 3. make flash write operation If still no luck: send mail to support ([email protected]) with detailed description of problem, attach the next files in your e-mail: 1. C:\Program Files\InfinityBox\ChineseMiracle\operation.log 2. C:\Program Files\InfinityBox\ChineseMiracle\cfi_xxxx_xxxx.bin detecting chip #01 in region #00... flash: 98000300000001:FFFFFF00000000 flash: Toshiba T 16Mb it's time to stop: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... . detection phase #2... .................................................. .................................................. .................................................. .................................................. .................................................. ...... warning: identification#1 information not found, possible reasons: .old firmware type w/o identification#1 data .damaged firmware .damaged hardware if phone works fine just ignore this warning detect device identification#1 finished detect device identification#2... detection phase #1... . detect device identification#2 finished detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset assigned: 00E00000 flash: 98000300000001:FFFFFF00000000 checking area [00000000]: 00000000-00FFFFFF... ffs/eeprom found near: 00E00000 detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... reading: _ffs... file saved: C:\Program Files\InfinityBox\ChineseMiracle\_ffs_20091219-201356.B0E.bin flash: 98000300000001:FFFFFF00000000 Backup required data Done Patch required data ... Patch required data Done Special operation ... Special operation Done Write ... Write Done Finalization ... formatting... flash: 98000300000001:FFFFFF00000000 error: wrong erase first sector at 0x00E00000 Finalization Fail Finished, time used: 216 sec Remove/Install battery now ! here complete but not power on but the problem is when you insert sim car the phone out shat off i format infinity whole flash chip the phone is dead infinity team help .............. | |
12-19-2009, 16:04 | #9 (permalink) |
Member: 1070665 Status: Offline Sonork: 100.1636802 Thanks Meter: 572 | pleas help COM10 [VCP0] selected module v2.84 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: write NOR flash "smart write" active write: Firmware skip: Customization/Language Pack skip: Customization write: Eeprom/ffs ffs/eeprom backup enabled, it may takes several minutes ! Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:2A03:0002 status: FF boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: 98000300000001:FFFFFF00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb detecting chip #01 in region #00... flash: 98000300000001:FFFFFF00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb detecting chip #02 in region #00... flash: 98000300000001:FFFFFF00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb detecting chip #03 in region #00... flash: 98000300000001:FFFFFF00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb number of flash chip/regions detected: 04/01 Initialize Done Set baud ... 460800 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... device parameters autodetection in progress... detecting chip #00 in region #00... flash: 98000300000001:FFFFFF00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb Warning: probably flash chip is empty, erased, incorrectly flashed or damaged ! What to do: 1. go to software "Settings" page 2. set "Advanced chip detection method" box UN-CHECKED ! 3. make flash write operation If still no luck: send mail to support ([email protected]) with detailed description of problem, attach the next files in your e-mail: 1. C:\Program Files\InfinityBox\ChineseMiracle\operation.log 2. C:\Program Files\InfinityBox\ChineseMiracle\cfi_xxxx_xxxx.bin detecting chip #01 in region #00... flash: 98000300000001:FFFFFF00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb it's time to stop: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... . detection phase #2... .................................................. .................................................. .................................................. .................................................. .................................................. ...... warning: identification#1 information not found, possible reasons: .old firmware type w/o identification#1 data .damaged firmware .damaged hardware if phone works fine just ignore this warning detect device identification#1 finished detect device identification#2... detection phase #1... . detect device identification#2 finished detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset assigned: 00E00000 flash: 98000300000001:FFFFFF00000000 checking area [00000000]: 00000000-00FFFFFF... ffs/eeprom found near: 00E00000 detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... reading: _ffs... file saved: C:\Program Files\InfinityBox\ChineseMiracle\5310\eep\SCUD_GEM INI_PCB01_GPRS_MT6225_S00.617B_A_V07_06__ffs_20091 218-153136.B0E.bin flash: 98000300000001:FFFFFF00000000 Backup required data Done Patch required data ... Patch required data Done Special operation ... Special operation Done Write ... detect device identification#1... detection phase #1... . detection phase #2... .................................................. .................................................. .................................................. .................................................. .................................................. ...... warning: identification#1 information not found, possible reasons: .old firmware type w/o identification#1 data .damaged firmware .damaged hardware if phone works fine just ignore this warning detect device identification#1 finished detect device identification#2... detection phase #1... . detect device identification#2 finished security area (code #1) calculation... done detecting security area (code #2)... security area (code #2) is absent Area: Firmware flash: 98000300000001:FFFFFF00000000 Write: Firmware Area: Eeprom/ffs flash: 98000300000001:18E59F00000000 Write: Eeprom/ffs detect device identification#2... detection phase #1... . detect device identification#2 finished Write Done Finalization ... Finalization Done Finished, time used: 388 sec Remove/Install battery now ! |
12-20-2009, 22:47 | #10 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! you erased whole flash chip, all16mb. now phone must be flashed with firmware "HY25_06B_PCB01_GPRS_MT6225_S00.A51_V00_01" in order to get it back to work for example this one: flashfiles/ChineseMiracle/_MT6225/RHY25_06B_PCB01_GPRS_MT6225_S00.A51_V00_01__5310_1 6m_En_Ru_Fr_De_Id_Cn_Tr_Farsi_Cn_Ar.B0M.bin |
12-20-2009, 22:56 | #11 (permalink) |
Freak Poster Join Date: Mar 2007
Member: 476420 Status: Offline Sonork: 100.1605239 Thanks Meter: 164 | never say that this box kill phone for ever becoz yougogp can live it by flashed it with same virsion .good method you can see support to get procedure to flash shaines phones good luck |
i-Pmart BX Series RJ45 Cable Compatible For China NK N5 For Infinity Box | IPMART | ipmart WebShop | 0 | 07-09-2009 06:50 |
i-Pmart BX Series RJ45 Cable Compatible For China Motorola L7+ For Infinity Box | IPMART | ipmart WebShop | 0 | 07-08-2009 10:50 |
need china 5310 express music flash file for infinity box | pogs1962 | Chinese Models & Cloned Phones | 1 | 05-08-2009 14:23 |
Free First in the world updates only for Infinity Box Customers | Infinity-Box | Main Sales Section | 0 | 03-01-2009 17:39 |
1600 china phone hang, using infinity box...... | Redtan_70 | Infinity-Box | 3 | 01-07-2009 03:42 |
