08-12-2008, 18:59 | #2 (permalink) |
Product Supporter Join Date: Feb 2008 Location: Jat-Chi-Bangladesh Age: 46
Member: 705213 Status: Offline Sonork: https://wa.link/aru52t Thanks Meter: 2,733 | 5310 fm sim insert to resert ==== log opened: [8/12/2008 1:06:07 AM] ==== Application: C:\Program Files\InfinityBox\ChineseMiracle\ChineseMiracle.ex e Loading data, wait... [Infinity Box] v2.54 S/N: ******** Wait... Do you want to continue ? COM13 [VCP0] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: reset Use only for mode-3 ! WARNING ! Settings will be cleared, user data erased, Imei set to default value ! Make flash backup before this procedure ! Do you want to continue ? COM13 [VCP0] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: reset Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6223:8A04]... CPU: MT6223 high speed boot enabled chip: 0011:326A:000C boot step size: 0400 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: 01227E22212201:2AEA0000000000 flash: Amd AMD/Fujitsu std [def 0080x020000] 16Mb detecting chip #01 in region #00... flash: 01227E22212201:2AEA0000000000 flash: Amd AMD/Fujitsu std [def 0080x020000] 16Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud... 115200 Set baud Done Initialize bootcode... Initialize bootcode Done Check firmware integrity... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: 01227E22212201:2AEA0000000000 flash: Amd AMD/Fujitsu std [def 0080x020000] 16Mb detecting chip #01 in region #00... flash: 01227E22212201:2AEA0000000000 flash: Amd AMD/Fujitsu std [def 0080x020000] 16Mb it's time to stop: 2A0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [standard] generation identification#1 protocol ver: 04 ver. sw1: LC6223_07A_PCB01_GPRS_MT6223_S00.LK56J07_7_3_1_4T0 6J0523_M511B.BIN ver. sw2: LK56J07.7.3.1.4T06J0523_M511B, 00000000 ffs offset/size: 00C40000/003C0000 detect device identification#2... detection phase #1... . warning: optional information not found, if phone works well just ignore this warning detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset detected: 00C40000 flash: 01227E22212201:2AEA0000000000 checking area[00000000]: 00000000-00FFFFFF... eeprom/ffs found near: 00E20000 Detected eeprom/ffs address is non-standard: 00E20000 Posible reasons: 1. eeprom is Ok but address is non-standard 2. eeprom damaged and can't be detected 3. eeprom is Ok but detected incorrectly (f.e. unknown eeprom structure) If you are not sure that detected address is correct: 1. press "NO" (and select standard address or terminate current operation) 2. make flash backup for emergency case 3. repeat required operation Are you sure that detected eeprom address is correct ? autodetected eeprom/ffs address[00E20000] confirmed by user detecting eeprom/ffs size... eeprom/ffs size: 001E0000 ffs chip: 00 eeprom/ffs area: 00000000:00E20000-00FFFFFF Check firmware integrity Done Check firmware content... Check firmware content Done Backup required data... reading [eeprom[LC6223_07A_PCB01_GPRS_MT6223_S00.LK56J07_7_3_1_4T0 6J0523_M511B.BIN]]... file saved: C:\Program Files\InfinityBox\ChineseMiracle\eeprom[LC6223_07A_PCB01_GPRS_MT6223_S00.LK56J07_7_3_1_4T0 6J0523_M511B.BIN]_20080812-011727.B0E.bin flash: 01227E22212201:2AEA0000000000 Backup required data Done Patch required data... Patch required data Done Special operation... Special operation Done Write... Write Done Finalization... formatting... flash: 01227E22212201:2AEA0000000000 Finalization Done Finished, time used: 241 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! Imei 35044801123456 already was repaired: 7/23/2008-3:03:57 AM Continue with this imei ? Action: imei Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched ON ! Connecting, wait... baud set to: 460800 error: connection failed ! Operation failed ! Finished, time used: 23 sec Power off phone now ! Imei 35044801123456 already was repaired: 8/12/2008-1:18:44 AM Continue with this imei ? Action: imei Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched ON ! Connecting, wait... Phone detected, wait... Hardware version: MT6223, E04 Hardware version: X901A_HW Software version: LK56J07.7.3.1.4T06J0 Software date: 2000.00.00 Barcode: MT012345678901234567 imei: 135790246811220 imei write method: mode-1 imei write channel: imei #1 for dual sim/mono-CPU new imei: 350448011234561 imei verification failed Operation failed ! Finished, time used: 51 sec Power off phone now ! Use only for mode-3 ! Imei 35044801123456 already was repaired: 8/12/2008-1:19:40 AM Continue with this imei ? Action: imei Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched ON ! Connecting, wait... baud set to: 57600 error: connection failed ! Operation failed ! Finished, time used: 4 sec Power off phone now ! Use only for mode-3 ! Use only for mode-3 ! Use only for mode-3 ! Imei 35044801123456 already was repaired: 8/12/2008-1:20:00 AM Continue with this imei ? COM13 [VCP0] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: imei imei write method: mode-3 imei write channel: imei #2 for dual sim/mono-CPU new imei: 350448011234561 Boot... Press and HOLD Power button now ! error: can't detect device Release Power button now ! in case of initial connection problem: on/off "Boot baudrate autoselect" box. Boot Fail Finished, time used: 31 sec Remove/Install battery now ! Imei 35044801123456 already was repaired: 8/12/2008-1:21:07 AM Continue with this imei ? COM13 [VCP0] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: imei imei write method: mode-3 imei write channel: imei #2 for dual sim/mono-CPU new imei: 350448011234561 Boot... Press and HOLD Power button now ! error: can't detect device Release Power button now ! in case of initial connection problem: on/off "Boot baudrate autoselect" box. Boot Fail Finished, time used: 16 sec Remove/Install battery now ! Imei 35044801123456 already was repaired: 8/12/2008-1:21:33 AM Continue with this imei ? COM13 [VCP0] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: imei imei write method: mode-3 imei write channel: imei #2 for dual sim/mono-CPU new imei: 350448011234561 Boot... Press and HOLD Power button now ! error: can't detect device Release Power button now ! in case of initial connection problem: on/off "Boot baudrate autoselect" box. Boot Fail Finished, time used: 26 sec Remove/Install battery now ! WARNING ! Settings will be cleared, user data erased, Imei set to default value ! Make flash backup before this procedure ! Do you want to continue ? COM13 [VCP0] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: reset Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6223:8A04]... CPU: MT6223 high speed boot enabled chip: 0011:326A:000C boot step size: 0400 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: 01227E22212201:2AEA0000000000 flash: Amd AMD/Fujitsu std [def 0080x020000] 16Mb detecting chip #01 in region #00... flash: 01227E22212201:2AEA0000000000 flash: Amd AMD/Fujitsu std [def 0080x020000] 16Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud... 115200 Set baud Done Initialize bootcode... Initialize bootcode Done Check firmware integrity... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: 01227E22212201:2AEA0000000000 flash: Amd AMD/Fujitsu std [def 0080x020000] 16Mb detecting chip #01 in region #00... flash: 01227E22212201:2AEA0000000000 flash: Amd AMD/Fujitsu std [def 0080x020000] 16Mb it's time to stop: 2A0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [standard] generation identification#1 protocol ver: 04 ver. sw1: LC6223_07A_PCB01_GPRS_MT6223_S00.LK56J07_7_3_1_4T0 6J0523_M511B.BIN ver. sw2: LK56J07.7.3.1.4T06J0523_M511B, 00000000 ffs offset/size: 00C40000/003C0000 detect device identification#2... detection phase #1... . warning: optional information not found, if phone works well just ignore this warning detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset detected: 00C40000 flash: 01227E22212201:2AEA0000000000 checking area[00000000]: 00000000-00FFFFFF... eeprom/ffs found near: 00CC0000 Detected eeprom/ffs address is non-standard: 00CC0000 Posible reasons: 1. eeprom is Ok but address is non-standard 2. eeprom damaged and can't be detected 3. eeprom is Ok but detected incorrectly (f.e. unknown eeprom structure) If you are not sure that detected address is correct: 1. press "NO" (and select standard address or terminate current operation) 2. make flash backup for emergency case 3. repeat required operation Are you sure that detected eeprom address is correct ? autodetected eeprom/ffs address[00CC0000] confirmed by user detecting eeprom/ffs size... eeprom/ffs size: 00340000 ffs chip: 00 eeprom/ffs area: 00000000:00CC0000-00FFFFFF Check firmware integrity Done Check firmware content... Check firmware content Done Backup required data... reading [eeprom[LC6223_07A_PCB01_GPRS_MT6223_S00.LK56J07_7_3_1_4T0 6J0523_M511B.BIN]]... file saved: C:\Program Files\InfinityBox\ChineseMiracle\eeprom[LC6223_07A_PCB01_GPRS_MT6223_S00.LK56J07_7_3_1_4T0 6J0523_M511B.BIN]_20080812-013832.B0E.bin flash: 01227E22212201:2AEA0000000000 Backup required data Done Patch required data... Patch required data Done Special operation... Special operation Done Write... Write Done Finalization... formatting... flash: 01227E22212201:2AEA0000000000 Finalization Done Finished, time used: 443 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! Imei 35044801123456 already was repaired: 8/12/2008-1:22:12 AM Continue with this imei ? COM13 [VCP0] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: imei imei write method: mode-3 imei write channel: imei #2 for dual sim/mono-CPU new imei: 350448011234561 Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6223:8A04]... CPU: MT6223 high speed boot enabled chip: 0011:326A:000C boot step size: 0400 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: 01227E22212201:2AEA0000000000 flash: Amd AMD/Fujitsu std [def 0080x020000] 16Mb detecting chip #01 in region #00... flash: 01227E22212201:2AEA0000000000 flash: Amd AMD/Fujitsu std [def 0080x020000] 16Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud... 115200 Set baud Done Initialize bootcode... Initialize bootcode Done Check firmware integrity... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: 01227E22212201:2AEA0000000000 flash: Amd AMD/Fujitsu std [def 0080x020000] 16Mb detecting chip #01 in region #00... flash: 01227E22212201:2AEA0000000000 flash: Amd AMD/Fujitsu std [def 0080x020000] 16Mb it's time to stop: 2A0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [standard] generation identification#1 protocol ver: 04 ver. sw1: LC6223_07A_PCB01_GPRS_MT6223_S00.LK56J07_7_3_1_4T0 6J0523_M511B.BIN ver. sw2: LK56J07.7.3.1.4T06J0523_M511B, 00000000 ffs offset/size: 00C40000/003C0000 detect device identification#2... detection phase #1... . warning: optional information not found, if phone works well just ignore this warning detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset detected: 00C40000 flash: 01227E22212201:2AEA0000000000 checking area[00000000]: 00000000-00FFFFFF... Can't detect eeprom/ffs area Do you want to use standard ffs address: 00C40000 ? If you are not sure that standard address is correct: 1. press "NO" and terminate current operation 2. make flash backup for emergency case 3. repeat required operation standard ffs address selected by user detecting eeprom/ffs size... eeprom/ffs size: 003C0000 ffs chip: 00 eeprom/ffs area: 00000000:00C40000-00FFFFFF Check firmware integrity Done Check firmware content... Check firmware content Done Backup required data... reading [eeprom[LC6223_07A_PCB01_GPRS_MT6223_S00.LK56J07_7_3_1_4T0 6J0523_M511B.BIN]]... file saved: C:\Program Files\InfinityBox\ChineseMiracle\eeprom[LC6223_07A_PCB01_GPRS_MT6223_S00.LK56J07_7_3_1_4T0 6J0523_M511B.BIN]_20080812-014701.B0E.bin flash: 01227E22212201:2AEA0000000000 Backup required data Done Patch required data... 2 step(s) required to finalize Patch required data Done Special operation... Special operation Done Write... flash: 01227E22212201:2AEA0000000000 Write: eeprom Write Done Finalization... Finalization Done Finished, time used: 498 sec Remove/Install battery now ! |
5310 seccessfly unlock 100% ok | best_unlocking | Nokia Base Band 5 ( BB-5 ) | 4 | 04-20-2009 18:55 |
5310 unlock 100% ok | best_unlocking | JAF No Tp Unlocker by Cinek | 8 | 04-08-2009 19:09 |
5310 bad software repair 100% ok | guljee786 | Infinity-Box | 0 | 04-05-2009 16:22 |
