Old 12-14-2008, 14:54   #1 (permalink)
basilbaby's Avatar
Member: 263709
Thanks Meter: 327
5310 rm-217 china pinout tested...
5310 rm-217 china pinout tested........
COM6 [VCP1] selected
Device: Autodetect 6205-6227 NOR
Checking data, wait...
Action: "format ffs"
Boot...
19200 fixed
Connecting, wait...
Initializing[6225:8A03:8A00]...
CPU: MT6225
high speed boot enabled
chip: 0001:FF0F:FFFF
boot step size: 0400
Release Power button now !
Boot Done
Initialize...
flash: EC257E25082501:18E59F00000000
flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb
detecting chip #01 in region #00...
number of flash chip/regions detected: 02/01
Initialize Done
Set baud...
460800
Set baud Done
Initialize bootcode...
Initialize bootcode Done
Check firmware integrity...
device parameters autodetection in progress..
it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5
total flash region size: 01000000
detect device identification#1...
detection phase #1...
detect device identification#1 finished
identification#1 structure: 2nd [enhanced] generation
security area#1 is Ok
security area#1 backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.45B2968B.[T6225_PCB01_GPRS_MT6225_S00.TEST1_0_06B_W07_28.BIN _1080F7CB].rpl
New firmware detected:
- make "Read full flash" operation
- send "system_log_..." file to support: [email protected]
- send flash backup file(s) to support: [email protected]
- include in your e-mail full text from phone back label (phone name etc.)
identification#1 detection finished
device-id: 45B2968B
identification#1 protocol ver: 04
ver. sw1: T6225_PCB01_GPRS_MT6225_S00.TEST1_0_06B_W07_28.BIN
ver. sw2: TEST1.0.06B.W07.28, 34087FEF
ffs offset/size: 00E00000/00200000
detect device identification#2...
warning: optional information is not found,
if phone works well just ignore this warning
detect device identification#2 finished
detecting eeprom/ffs area in 1 chip(s)...
standard eeprom/ffs offset detected: 00E00000
checking area[00000000]: 00000000-00FFFFFF...
eeprom/ffs found near: 00ED0000
Detected eeprom/ffs address is non-standard: 00ED0000
Posible reasons:
1. eeprom is Ok but address is non-standard
2. eeprom damaged and can't be detected
3. eeprom is Ok but detected incorrectly (f.e. unknown eeprom structure)
If you are not sure that detected address is correct:
1. press "NO" (and select standard address or terminate current operation)
2. make flash backup for emergency case
3. repeat required operation
Are you sure that detected eeprom address is correct ?
autodetected eeprom/ffs address[00ED0000] confirmed by user
detecting eeprom/ffs size...
eeprom/ffs size: 00130000
ffs chip: 00
eeprom/ffs area: 00000000:00ED0000-00FFFFFF
Check firmware integrity Done
Check firmware content...
Check firmware content Done
Backup required data...
Backup required data Done
Patch required data...
Patch required data Done
Special operation...
Special operation Done
Write...
Write Done
Finalization...
formatting...
Finalization Done
file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\s ystem_log_45B2968B_T6225_PCB01_GPRS_MT6225_S00.TES T1_0_06B_W07_28.BIN_1080F7CB_20081214-172438.B0X.bin
Finished, time used: 161 sec
Remove/Install battery now !
File system has been modified !
It is need to press and HOLD phone "Power" button
during long time (up to 1 min) to make phone Powered-On !
Old 12-15-2008, 19:58   #2 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
thank you for sharing this pinout!
can you also send backup readed from this phone?
[email protected]
Old 12-15-2008, 20:24   #3 (permalink)
waji mobiles's Avatar
Member: 326871
Sonork: down2 sky.up 2 the earth
Thanks Meter: 636
Arrow Difficult to do use this1.
SORRY BRO VERY DIFFICULT TO DO FOR ECERY MEMBER SOO USE THIS 1.
http://forum.gsmhosting.com/vbb/showthread.php?t=649566
6300 rm-217 china phone pin-out need, master_tugo Infinity-Box 14 03-23-2010 06:05
New N73-1 Rm-133 china pinout tested... basilbaby Infinity-Box 3 09-05-2009 11:49
5310 RM-217 no flash file from support site EngrRML Infinity-Box 15 06-11-2009 21:21
nokia 5310 rm-303 new pinout ener920 Infinity-Box 3 05-03-2009 00:30
6300 rm-217 new pinout tolski Infinity-Box 0 01-04-2009 13:27
Page generated in 0.16954 seconds with 10 queries
