Old 03-08-2015, 06:26   #1 (permalink)
rehmani's Avatar
Member: 333199
Sonork: may i help u just pm me
Thanks Meter: 2,405
intex y2pro reading wrong pattern
Wait for phone...
Phone found! [ 13 ]
Sync...
Inital regs read done
Boot Info :
BB_CPU_ID : 6572
BB_CPU_HW : CA01
BB_CPU_SW : 8A00
BB_CPU_SB : 0000
BB_CPU_NM : [MediaTek] MT6572_S00
Processing BROM stage
BLVersion : 0x01
SecCfgVal : 0x00000000
BromVersion : 0xFF
BLVersion : 0x01
Preloader Status : Alive
Processing DA stage
DA Select done , sending
NAND_ID : 00000000000000000000000000000000
eMMC_ID : 7001004D4D4330344758EE1A9803B12F
DA Stat : v4.2 on BBID : 0x88
DA Sent. Configure setting now ...
DA started successuflly
eMMC FlashIC initialized
[eMMC] : FLASH_VEN : 0070 , OEM : 0100
[eMMC] : FLASH_INF : G40CM
[eMMC] : FLASH_CID : 7001004D4D4330344758EE1A9803B12F
[eMMC] : FLASH_LEN : 0x00000000E6800000
INT RAM : 0x00020000
EXT RAM : 0x20000000
BOOT TYPE : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
Reading data ...
FS Size : 1323 MiB
Magic Ok
Mount point : /data
Get PatternLock ...
PatternLock Sequnce : 46785293
Done!
Elapsed: 00:00:20
Reconnect Power/Cable!
Operation : Read PatternLock [ v1.13 ]
Wait for phone...
Phone found! [ 13 ]
Sync...
Boot Info :
BB_CPU_ID : 6572
BB_CPU_HW : CA01
BB_CPU_SW : 8A00
BB_CPU_SB : 0000
BLVersion : 0x01
BromVersion : 0xFF
BLVersion : 0x01
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Reading data ...
FS Size : 1323 MiB
Magic Ok
Mount point : /data
Get PatternLock ...
Done!
Elapsed: 00:00:23
Old 03-08-2015, 06:45   #2 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 20,352
Hello, yes, because 4-6 is not possible X)
Looks like while DB was compiled exactly this combination gone wrong.
Try 45786293
Old 03-08-2015, 07:10   #3 (permalink)
rehmani's Avatar
Member: 333199
Thanks Meter: 2,405
no not working and see i think 9 and 3 is not possible in combination
Old 03-08-2015, 08:48   #4 (permalink)
JayDi's Avatar
Member: 462970
Possible, because 6 already used.
So, should be then : 98765324
The Following User Says Thank You to JayDi For This Useful Post:
Old 03-08-2015, 09:36   #5 (permalink)
rehmani's Avatar
Member: 333199
Thanks Meter: 2,405
thanks this code is working
Old 03-08-2015, 10:11   #6 (permalink)
JayDi's Avatar
Member: 462970
Ok, will correct procedure in next versions.
Page generated in 0.22487 seconds with 8 queries
