03-07-2015, 10:57 | #1 (permalink) |
No Life Poster Join Date: Mar 2014 Location: Romania
Member: 2157664 Status: Offline Thanks Meter: 43 | MT6582 privacy lock I have a tablet based on MT6582 with privacy lock. When I try to reset privacy lock with infinity it tells me that privacy lock is not in use. Please help I need the data from the tablet. Thanks! |
03-07-2015, 11:11 | #3 (permalink) |
Member: 2157664 Status: Offline Thanks Meter: 43 | Start at : [07.03.2015 / 12:00:33] Operation : Reset Privacy Lock [ v1.14 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 4 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6582 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6582|8312_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 20010053414D3038473A0E070A0F1705 DA Stat : v4.2 on BBID : 0x87 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0020 , OEM : 0100 [eMMC] : FLASH_INF : G80MA [eMMC] : FLASH_CID : 20010053414D3038473A0E070A0F1705 [eMMC] : FLASH_LEN : 0x00000001CC580000 INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Checking data ... Privacy Lock not set! Done! Elapsed: 00:00:11 Reconnect Power/Cable! Finish at : [07.03.2015 / 12:00:44] |
03-07-2015, 11:20 | #4 (permalink) | |
No Life Poster Join Date: Mar 2007 Location: Factory Reset Protection (FRP) Age: 13
Member: 459784 Status: Offline Sonork: +91-9179403087 Thanks Meter: 1,543 | Quote:
03-07-2015, 11:40 | #5 (permalink) |
Member: 2157664 Status: Offline Thanks Meter: 43 | Start at : [07.03.2015 / 12:00:01] Operation : Check / Read Info [ v1.14 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 4 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6582 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6582|8312_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 20010053414D3038473A0E070A0F1705 DA Stat : v4.2 on BBID : 0x87 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0020 , OEM : 0100 [eMMC] : FLASH_INF : G80MA [eMMC] : FLASH_CID : 20010053414D3038473A0E070A0F1705 [eMMC] : FLASH_LEN : 0x00000001CC580000 INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : Qualcore ProdName : Qualcore ProdModel : Qualcore 7020 3G Device : Qualcore AndroidVer: 4.4.2 MTKxCPU : MT6582 MTKxPRJ : ALPS.KK1.MP1.V2.12 Done! Elapsed: 00:00:10 Reconnect Power/Cable! Finish at : [07.03.2015 / 12:00:12] |
03-07-2015, 11:48 | #6 (permalink) | |
there should be pettren lock! as i seen in log there is not Any PL! if asking password or pin do format it data will be lost - if asking gmail lock do format it data will be lost - if pettren lock ,try to do read pettern lock - try n post result @ | |
