Old 10-26-2008, 02:39   #1 (permalink)
Member: 376326
Thanks Meter: 32
6120c dead can i revive this w/ infinity?
i format the phone still no power
infinity team can you help me to revive my phone
heres my logs
COM5 [VCP0] selected
module v2.65
Device: Autodetect 6205-6227 NOR
Checking data, wait...
eeprom backup enabled, it may takes several minutes !
Action: "format ffs"
Boot...
19200 fixed
Connecting, wait...
Initializing[6225:8A03:8A00]...
CPU: MT6225
high speed boot enabled
chip: 0001:FB03:0003
boot step size: 0400
Release Power button now !
Boot Done
Initialize...
flash: EC257E25082501:18E59F00000000
flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb
detecting chip #01 in region #00...
number of flash chip/regions detected: 02/01
Initialize Done
Set baud...
460800
Set baud Done
Initialize bootcode...
Initialize bootcode Done
Check firmware integrity...
device parameters autodetection in progress..
it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5
total flash region size: 01000000
detect device identification#1...
detection phase #1...
detect device identification#1 finished
identification#1 structure: 2nd [enhanced] generation
security area (code #1) is Ok
security area (code #1) backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.B9EF6F90.[MT6225_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_08_M P_V27.BIN_048CDB12].rpl
identification#1 detection finished
device-id: B9EF6F90
identification#1 protocol ver: 04
ver. sw1: MT6225_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_08_M P_V27.BIN
ver. sw2: MAUI.06B.W07.08.MP.V27, ED2473FB
ffs offset/size: 00E00000/00200000
detect device identification#2...
warning: optional information is not found,
if phone works well just ignore this warning
detect device identification#2 finished
detecting eeprom/ffs area in 1 chip(s)...
standard eeprom/ffs offset detected: 00E00000
checking area[00000000]: 00000000-00FFFFFF...
eeprom/ffs found near: 00E00000
detecting eeprom/ffs size...
eeprom/ffs size: 00200000
ffs chip: 00
eeprom/ffs area: 00000000:00E00000-00FFFFFF
Check firmware integrity Done
Check firmware content...
Check firmware content Done
Backup required data...
Backup required data Done
Patch required data...
Patch required data Done
Special operation...
Special operation Done
Write...
Write Done
Finalization...
formatting...
Finalization Done
file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\s ystem_log_B9EF6F90_MT6225_06B_PCB01_GPRS_MT6225_S0 0.MAUI_06B_W07_08_MP_V27.BIN_048CDB12_20081026-093853.B0X.bin
Finished, time used: 43 sec
Remove/Install battery now !
File system has been modified !
It is need to press and HOLD phone "Power" button
during long time (up to 1 min) to make phone Powered-On !
Old 10-26-2008, 04:40   #2 (permalink)
Registered User
Member: 461468
Thanks Meter: 139
Sirs, please used power supply not battery before due I ever the same problem like u.
After power is on normally n then use battery back.
Rgds,
Old 10-26-2008, 05:08   #3 (permalink)
Member: 376326
Thanks Meter: 32
sir i'll already using power supply
i press power for 1minutes but still no power
Old 10-26-2008, 14:35   #4 (permalink)
Member: 130995
Thanks Meter: 35,227
Hello,
If phone can ot On after format it may be that you need to flash phone with firmware file.
Also in many cases it\'s need to check phone hardware, f.e. rehot/reball flash and CPU chip.
dead cect u90 revived with infinity aliakbar Infinity-Box 8 06-01-2009 16:23
R300 dead after unlock revive by infinity ayhen42 Infinity-Box 4 05-18-2009 21:44
How can I revive this SE K600 ? Not power On. Grupo MovilFree SETool2 4 03-23-2009 19:37
X701 restarts itself,Can i fix this by infinity? Mr GsM Infinity-Box 3 06-29-2008 14:25
Page generated in 0.20065 seconds with 10 queries
