01-14-2010, 10:12 | #1 (permalink) |
No Life Poster Join Date: Jul 2006 Location: PAKISTAN
Member: 303790 Status: Offline Thanks Meter: 290 | 6300 dead with infinity after that the set in off ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6226:8A02:8A01]... CPU: MT6226 high speed boot Off chip: 0031:7541:7244 status: FF high speed boot Off boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 98004900000002:29EA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb detecting chip #01 in region #00... flash: 98004900000002:29EA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb detecting chip #02 in region #00... flash: 98004900000002:29EA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb detecting chip #03 in region #00... flash: 98004900000002:29EA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb number of flash chip/regions detected: 04/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... interesting cpu type found Initialize bootcode Done ====> Check firmware integrity ... device parameters detection in progress... detecting chip #00 in region #00... flash: 98004900000002:29EA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb detecting chip #01 in region #00... flash: 98004900000002:29EA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb it's time to stop: 290000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: 2nd [enhanced] generation TCL-ID is absent startup code area #1 is Ok startup code area #1 backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.8DF18BCC.[U26_07B_GEMINI_PCB01_GPRS_MT6226_S01.MAUI_07B_W08_ 16_M9D04.BIN_A4108575].rpl rom info detection finished ==================== New firmware detected (v.3.04, database date: unknown): U26_07B_GEMINI_PCB01_GPRS_MT6226_S01.MAUI_07B_W08_ 16_M9D04.BIN This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to http://rapidshare.com or http://4shared.com - include in your e-mail full text from phone back label (phone name etc.) ==================== device-id: 8DF18BCC rom info ver: 04 sw version: U26_07B_GEMINI_PCB01_GPRS_MT6226_S01.MAUI_07B_W08_ 16_M9D04.BIN project-id: MAUI.07B.W08.16.M9D04, 758510A4 code offset: 00000000 ffs offset/size [01]: 00E00000/00200000 rom info structure: 2nd [enhanced] generation TCL-ID is absent detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00E00000 standard ffs/eeprom offset confirmed: 00E00000 detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... reading: U26_07B_GEMINI_PCB01_GPRS_MT6226_S01.MAUI_07B_W08_ 16_M9D04__ffs... file saved: C:\Program Files\InfinityBox\ChineseMiracle\U26_07B_GEMINI_PC B01_GPRS_MT6226_S01.MAUI_07B_W08_16_M9D04__ffs_201 00114-135916.B0E.bin flash: 98004900000002:29EA0000000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... chip formatting... flash: 98004900000002:29EA0000000000 Erase: chip 1 of 1 Finalization Done file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\U 26_07B_GEMINI_PCB01_GPRS_MT6226_S01.MAUI_07B_W08_1 6_M9D04__system_log_8DF18BCC_A4108575_20100114-140025.B0X.bin Finished, time used: 2 min 11 sec Remove/Install battery now ! |
01-16-2010, 11:34 | #6 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! flash phone with available on support firmware flashfiles/ChineseMiracle/_MT6226/U26_07B_GEMINI_PCB01_GPRS_MT6226_S01.MAUI_07B_W08_ 16_M9D04__Nokia-6700-2sim_16m_En_Ru_Fr_Th_Tr_Farsi_Ar.B0M.bin flashfiles/ChineseMiracle/_MT6226/U26_07B_GEMINI_PCB01_GPRS_MT6226_S01.MAUI_07B_W08_ 16_M9D04__NOKIA-6700_16m_En_Ru_Fr_Th_Tr_Ar.B0M.bin flashfiles/ChineseMiracle/_MT6226/U26_07B_GEMINI_PCB01_GPRS_MT6226_S01.MAUI_07B_W08_ 16_M9D04__Nokia-6700_16m_En_Ru_Fr_Th_Vn_Tr.B0M.bin |
6300 dead with blue lights | nahi_sonu | Nokia Hardware & Hardware Repair | 6 | 06-10-2009 11:47 |
kg200 dead with infinity box | ..:::Gsm india:::.. | Infinity-Box | 3 | 12-04-2008 22:51 |
6300 dead with other firmware | ::. zine .:: | Infinity-Box | 2 | 02-06-2008 20:53 |
mobile dead with infinity | Mohsin-* | Infinity-Box | 3 | 10-29-2007 17:51 |
W220 DEAD with INFINITY | Umbabaraumba | Infinity-Box | 22 | 07-28-2007 08:54 |
