10-29-2008, 06:08 | #1 (permalink) | |
Banned Join Date: Jul 2005 Location: Philippines Age: 53
Member: 161739 Status: Offline Sonork: 100.1584054 Thanks Meter: 3,338 | 6300 on off format by wrong procedure module v2.64 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: "format ffs" Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6226:8A02:8A01]... CPU: MT6226 high speed boot disabled chip: 0031:2F75:8D9F high speed disabled boot step size: 0002 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: 01227E22202200:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb detecting chip #01 in region #00... flash: 01227E22202200:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud... 115200 Set baud Done Initialize bootcode... Initialize bootcode Done Check firmware integrity... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: 01227E22202200:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb detecting chip #01 in region #00... flash: 01227E22202200:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [enhanced] generation security area (code #1) is Ok security area (code #1) backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.5CBB2899.[MTK25_06B_PCB01_GPRS_MT6225_S 00.MAUI_06B_W07_12_10.BIN_7DA61A66].rpl identification#1 detection finished device-id: 5CBB2899 identification#1 protocol ver: 04 ver. sw1: MTK25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_12_10 .BIN ver. sw2: MAUI.06B.W07.12.10, 99E55982 ffs offset/size: 00E00000/00200000 detect device identification#2... detection phase #1... . warning: optional information is not found, if phone works well just ignore this warning detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset detected: 00E00000 flash: 01227E22202200:18E59F00000000 checking area[00000000]: 00000000-00FFFFFF... Can't detect eeprom/ffs area Do you want to use standard ffs address: 00E00000 ? If you are not sure that standard address is correct: 1. press "NO" and terminate current operation 2. make flash backup for emergency case 3. repeat required operation standard ffs address selected by user detecting eeprom/ffs size... eeprom/ffs size: 00200000 ffs chip: 00 eeprom/ffs area: 00000000:00E00000-00FFFFFF Check firmware integrity Done Check firmware content... Check firmware content Done Backup required data... flash: 01227E22202200:18E59F00000000 Backup required data Done Patch required data... Patch required data Done Special operation... Special operation Done Write... Write Done Finalization... formatting... flash: 01227E22202200:18E59F00000000 Finalization Done file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\s ystem_log_5CBB2899_MTK25_06B_PCB01_GPRS_M T6225_S00.MAUI_06B_W07_12_10.BIN_7DA61A66_20081029-120213.B0X.bin Finished, time used: 164 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! Quote:
what problem.................... | |
10-29-2008, 11:21 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, If you have got phone in dead condition it may be software or hardware problem, nobody can be sure. If you have tried to flash phone with several flash files and phone can not power-on at all you have a reason to check phone hardware. |
10-29-2008, 11:46 | #3 (permalink) | |
No Life Poster Join Date: Dec 2006 Location: Bareilly(U.P) Age: 50
Member: 405715 Status: Offline Thanks Meter: 271 | 6300 dead Quote:
if you had tried with software now you should repair by hardware procedure 1-change rtc 32.678 khz.crystal. 2-resold/reball cpu and flash. 3-resold rf section then reflash it check and post reply good luck..... | |
3110 6300 on off track | MANISHCHAWLA | Nokia Hardware & Hardware Repair | 2 | 08-15-2011 06:52 |
6300 on/off (switch) ways pls.. | LoveLess | Nokia Hardware & Hardware Repair | 10 | 12-25-2010 10:15 |
6300 on off button | prime_master786 | Nokia Hardware & Hardware Repair | 6 | 08-14-2009 07:58 |
i need 6300 on off switch ways | .::ADNAN440::. | Chinese Models & Cloned Phones | 0 | 08-01-2009 12:13 |
6300 on off key | atif43 | Chinese Models & Cloned Phones | 3 | 11-19-2008 13:46 |
