10-19-2008, 03:26 | #1 (permalink) |
No Life Poster Join Date: Nov 2003 Location: srilanka Age: 51
Member: 44229 Status: Offline Sonork: 1592530 Thanks Meter: 366 | need support for this - e tel v118 here is log, COM17 [VSerial0] selected module v2.64 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: read NOR flash Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6225:8A03:8A00]... CPU: MT6225 high speed boot enabled chip: 0001:AA03:0004 boot step size: 0400 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud... 460800 Set baud Done Initialize bootcode... Initialize bootcode Done Check firmware integrity... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [enhanced] generation security area (code #1) is Ok security area (code #1) backup saved: E:\mobile\infinity box\InfinityBox\ChineseMiracle\backup_security\id. 54A9B51D.[M3118_PCB01_GPRS_MT6225_S00.M3118_FM_G118_ETEL_V1_ 0.BIN_42DA72A0].rpl ==================== New firmware detected (2.64) : M3118_PCB01_GPRS_MT6225_S00.M3118_FM_G118_ETEL_V1_ 0.BIN - make "Read full flash" operation - send "system_log_..." file to support: [email protected] - send flash backup file(s) to support: [email protected] - include in your e-mail full text from phone back label (phone name etc.) ==================== identification#1 detection finished device-id: 54A9B51D identification#1 protocol ver: 04 ver. sw1: M3118_PCB01_GPRS_MT6225_S00.M3118_FM_G118_ETEL_V1_ 0.BIN ver. sw2: M3118_FM_G118_ETEL_V1.0, 5F8D25BD ffs offset/size: 00E00000/00200000 detect device identification#2... detection phase #1... . warning: optional information is not found, if phone works well just ignore this warning detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset detected: 00E00000 flash: EC257E25082501:18E59F00000000 checking area[00000000]: 00000000-00FFFFFF... eeprom/ffs found near: 00E00000 detecting eeprom/ffs size... eeprom/ffs size: 00200000 ffs chip: 00 eeprom/ffs area: 00000000:00E00000-00FFFFFF Check firmware integrity Done Check firmware content... Check firmware content Done Backup required data... reading: flash[M3118_PCB01_GPRS_MT6225_S00.M3118_FM_G118_ETEL_V1_ 0.BIN]... file saved: E:\mobile\infinity box\InfinityBox\ChineseMiracle\backup flash\flash[M3118_PCB01_GPRS_MT6225_S00.M3118_FM_G118_ETEL_V1_ 0.BIN]_20081019-063506.B0M.bin file saved: E:\mobile\infinity box\InfinityBox\ChineseMiracle\backup_security\sys tem_log_54A9B51D_M3118_PCB01_GPRS_MT6225_S00.M3118 _FM_G118_ETEL_V1_0.BIN_42DA72A0_20081019-063533.B0X.bin Finished, time used: 693 sec Remove/Install battery now ! Action: read information Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched ON ! Connecting, wait... Phone detected, wait... Hardware version: MT6225, E03 Hardware version: M3109P_K5L_V10 Software version: M3118_FM_G118_ETEL_V Software date: 2006.06.14 Barcode: MT012345678901234567 imei: 359446015066022 Finished, time used: 33 sec Power off phone now ! safe format success WARNING ! Settings will be cleared, user data erased, Imei set to default value ! Make flash backup before this procedure ! Do you want to continue ? ==== log: [10/19/2008 6:38:03 AM] ==== COM17 [VSerial0] selected module v2.64 Action: reset settings Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing[6225:8A03:8A00]... CPU: MT6225 high speed boot enabled chip: 0001:AA03:0004 Connecting, wait... Release Power button now ! Phone detected, wait... Hardware: MT6225,E03 Date: 2006.06.14 Version: 1.0 Version: M3118_FM_G118_ETEL_V1.0 Version: M3109P_K5L_V10 detecting structure #2... 0 done 44 byte(s) read imei: 35944601506602 connection Ok building list... done items to clear: 145 145 of 145 items cleared warning: wrong packet cs building list... done 0 items remains Finished, time used: 29 sec Remove/Install battery now ! here is full backup, http://rapidshare.com/files/15537134...063506.B0M.bin br. |
E52 RM-469 Flashing problem.Flash ID not supported for this loader (RAPUv11_algo_xsr1 | rafik2533 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 4 | 04-04-2010 20:38 |
hack3r2k,interested with TRACFONE & NET10 = LG & Samsung, We need support for this | mymiela0419 | FuriousGold | 2 | 01-05-2010 10:11 |
---i need support for this model-- :::ANSWERED::: | magico459 | PolarBox 3 | 1 | 01-20-2009 00:19 |
Need flash for QTEK 9100, need better support for this solution | gsmnice | JAFWM | 0 | 05-04-2006 17:26 |
