Old 05-18-2011, 14:48   #1 (permalink)
jhon357add's Avatar
Member: 949016
Sonork: 161.7672
Thanks Meter: 25
8520 Dead after Format FFS
I have done format ffs to this phone and now dont pwr on..any way or flash to fix it this is the flash
J2TECH25_08A_GEMINI_PCB01_GPRS_MT6225_S00.M6225_08 A_X510_DFD_53_V02
Old 05-18-2011, 15:02   #2 (permalink)
PASSIONATE_BOYS's Avatar
Member: 541591
Sonork: 100.1611509
Thanks Meter: 7,361
This firmware is not present on support area.
Do you have backup of this phone? If yes then write it back to phone.
Else find same model from local market, read full flash and then write it to your faulty phone.
Wr.
Old 05-18-2011, 19:06   #3 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
if you did not refuse- program had to make EEPROM backup automaticly.
find it, load as EEPROM and write to phone.
it will be restored to initial state
Old 05-18-2011, 20:31   #4 (permalink)
jhon357add's Avatar
Member: 949016
Sonork: 161.7672
Thanks Meter: 25
i did it and dont work still phone dead
COM6 [VCP0] selected
module v3.30
Device: Autodetect 6205-6239 NOR
Checking data, wait...
Action: write flash
"smart write" active
skip: Firmware
skip: Customization/Language Pack
skip: Customization
write: Eeprom/ffs
JINGRAN_PCB01_GPRS_MT6225_S00.A5188V1_0__ffs_20110 517-144712.B0E.bin
ffs/eeprom backup enabled, it may takes several minutes !
====> Boot ...
19200 fixed
Connecting, wait...
Initializing [6225:8A05:8A00]...
CPU: MT6225
high speed boot On
chip: 0001:5503:0003
status: FF
boot packet size: 0400
Release Power button now !
Boot Done
====> Initialize ...
flash: EC257E25082501:18E59F00000000
flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb
otp offset: 00000000
detecting chip #01 in region #00...
detecting chip #02 in region #00...
detecting chip #03 in region #00...
number of flash chip/regions detected: 04/01
Initialize Done
====> Set baud ...
115200
Set baud Done
====> Initialize bootcode ...
Initialize bootcode Done
====> Check firmware integrity ...
device parameters detection in progress...
it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5
total flash region size: 01000000
usb bootloader detect...
usb bootloader detect (phase #2)...
usb bootloader (chip) is absent
searching rom info...
search rom info finished
rom info structure: [protected] type (05), 1 record(s)
TCL-ID is absent
startup code area #1 is Ok
startup code area #1 backup saved: C:\InfinityBox\ChineseMiracle\backup_security\id.9 7163342.[J2TECH25_08A_GEMINI_PCB01_GPRS_MT6225_S00.M6225_08 A_X510_DFD_53_V02.BIN_3BC56D71].rpl
New firmware found (v.3.30, database date: 11.05.2011):
This firmware is missing in support area. If this phone is good and working:
- download latest software from support area and try again, probably this firmware already supported in latest software
- make "Read full flash" operation
- send flash backup files to support: [email protected] or upload files to RapidShare AG, Cham, Switzerland or 4shared.com - free file sharing and storage
- include in your e-mail full text from phone back label (phone name etc.)
rom info detection finished
device-id: 97163342
rom info ver: 05
sw version: J2TECH25_08A_GEMINI_PCB01_GPRS_MT6225_S00.M6225_08 A_X510_DFD_53_V02.BIN
project-id: M6225_08A_X510_DFD_53_V02, 716DC53B
code offset: 00000000
ffs offset/size [01]: 00E00000/00200000
TCL-ID is absent
detecting ffs/eeprom area in 1 chip(s)...
standard ffs/eeprom offset detected: 00E00000
checking area [00000000]: 00080000-00FFFFFF...
Can't detect ffs/eeprom area
Do you want to use standard ffs/eeprom address: 00E00000 ?
If you are not sure that standard address is correct:
1. press "NO" and terminate current operation
2. make flash backup for emergency case
3. repeat required operation
standard ffs/eeprom address selected by user
detecting ffs/eeprom size...
ffs/eeprom size: 00200000
ffs/eeprom chip: 00
ffs/eeprom area: 00000000:00E00000-00FFFFFF
firmware area: 00000000-00DFFFFF
sec info (detailed) detection...
searching sec info#1...
search sec info#1 finished
Check firmware integrity Done
====> Check firmware content ...
Check firmware content Done
====> Backup required data ...
reading: J2TECH25_08A_GEMINI_PCB01_GPRS_MT6225_S00.M6225_08 A_X510_DFD_53_V02__ffs...
file saved: C:\InfinityBox\ChineseMiracle\J2TECH25_08A_GEMINI_ PCB01_GPRS_MT6225_S00.M6225_08A_X510_DFD_53_V02__f fs_20110518-151442.B0E.bin
Backup required data Done
====> Patch required data ...
Patch required data Done
====> Special operation ...
Special operation Done
====> Write ...
file saved: C:\InfinityBox\ChineseMiracle\backup_security\J2TE CH25_08A_GEMINI_PCB01_GPRS_MT6225_S00.M6225_08A_X5 10_DFD_53_V02__system_log_97163342_3BC56D71_201105 18-151636.B0X.bin
Area: Eeprom/ffs
Write: Eeprom/ffs
sec info (fast) detection...
Write Done
====> Finalization ...
Finalization Done
file saved: C:\InfinityBox\ChineseMiracle\backup_security\J2TE CH25_08A_GEMINI_PCB01_GPRS_MT6225_S00.M6225_08A_X5 10_DFD_53_V02__system_log_97163342_3BC56D71_201105 18-152018.B0X.bin
Finished, time used: 10 min 18 sec
Remove/Install battery now !
Old 05-18-2011, 22:00   #5 (permalink)
Member: 148515
hello!
if you have many eeprom files, choose the first one.
file end with numbers "20110517-144712"
means date and time
2011 may 17th, 14h47m12s
choose the first available
Old 05-21-2011, 12:19   #6 (permalink)
ORANGE MOB's Avatar
Member: 1549240
Thanks Meter: 1,130
i think need new flash file from same working phone and he will must power on the phone
Old 05-22-2011, 20:54   #7 (permalink)
Member: 148515
hello guys!
yes, this is also option
5110 v 6.0 after unlocking problem with net cole Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 01-10-2001 16:11
5110/6110 after unlocking see only network to which it was locked and ... 2M Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 07-25-2000 00:51
5110 5.24 locked all 4 locks after unlocking... MCG Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 03-07-2000 22:24
6150 V5.20 WANTED --- DEAD OR ALIVE --- IT'S BETTER ALIVE ! ;))) tcamilo Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 12-19-1999 22:30
"Menu 11"? after Net monitor Pyron Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 08-09-1999 10:07
Page generated in 0.16902 seconds with 10 queries
