8800е-1-carbon-RM233 I need this flash: H526_05C_PCB01_GPRS_MT6226_S01.P02_SP_SSD_NB0_1_2_ 0TMC1_26B.BIN I flash phone because i have problem with saving photos and received files. I flash phone with all flashes from support area but not result (blinking LCD or mirror image). By mistake i haven't backup. Thanks in advance. |
If required file can not be found in support area (please use "search" function in support area first) it will be good if somebody can read full flash from the same good working phone and send full flash backup to [email protected] so we will be able to prepare and upload good working files in support area for all users. Please, DO NOT send to us backup files from damaged phones. We CAN NOT repair damaged files ! |
I same need this flash: H526_05C_PCB01_GPRS_MT6226_S01.P02_SP_SSD_NB0_1_2_ 0TMC1_26B.BIN-8800e-1-RM233-carbon |
8800е-1-carbon-RM233 have about 10 different models, using the same firmware version (H526_05C_PCB01_GPRS_MT6226_S01.P02_SP_SSD_NB0_1_2 _0TMC1_26B). But can't be writed for each other,phone will be can't power on ,blinking LCD or mirror image... Here the first please test:) H526_05C_PCB01_GPRS_MT6226_S01.P02_SP_SSD_NB0_1_2_ 0TMC1_26B |
hello! i will upload above software to our support area collection. |
Picters my phone http://www.4shared.com/account/dir/1...ng.html?rnd=33 details phone Action: read information Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched ON ! Connecting, wait... Phone detected, wait... Hardware version: MT6226, E02 Hardware version: KP26_06B_HW Software version: P02_SP_SSD_NB0_1.2.0 Software date: 2005.04.12 Barcode: MT012345678901234567 imei: 352935895304724 Finished, time used: 4 sec Power off phone now ! |
hello milkonym & voffka05! what was you phone Original software version? i think it was not that which posted mr. Star75 you can find this in operation.log file: you must open with notepad operation.log file which is located in Chinese Miracle folder. scrool it from up from end and find First operation with this phone. there you will see Original software version. also helpfull in search is date/time stamp |
8800e-1-carbon-RM233 Hello,Infinity Team, first operation with this phone ==== log: [23/3/09 13:24:46] ==== COM20 [VCP0] selected module v2.76 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: "format ffs" ffs/eeprom backup enabled, it may takes several minutes ! Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6226:8A02:8A01]... CPU: MT6226 high speed boot Off chip: 0031:4BCA:4281 status: FF high speed boot Off boot packet size: 0002 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: 01227E22202200:29EA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb detecting chip #01 in region #00... flash: 01227E22202200:29EA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb detecting chip #02 in region #00... flash: 01227E22202200:29EA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb detecting chip #03 in region #00... flash: 01227E22202200:29EA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb number of flash chip/regions detected: 04/01 Initialize Done Set baud ... 115200 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... device parameters autodetection in progress... detecting chip #00 in region #00... flash: 01227E22202200:29EA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb detecting chip #01 in region #00... flash: 01227E22202200:29EA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb it's time to stop: 290000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [standard] generation identification#1 detection finished identification#1 protocol ver: 04 ver. sw 1: H526_05C_PCB01_GPRS_MT6226_S01.P02_SP_SSD_NB0_1_2_ 0TMC1_26B.BIN ver. sw 2: P02_SP_SSD_NB0_1.2.0TMC1_26B, 00000000 ffs offset/size: 00E00000/00200000 detect device identification#2... detection phase #1... . detect device identification#2 finished detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00E00000 flash: 01227E22202200:29EA0000000000 checking area [00000000]: 00000000-00FFFFFF... ffs/eeprom found near: 00E00000 detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... reading: eeprom[H526_05C_PCB01_GPRS_MT6226_S01.P02_SP_SSD_NB0_1_2_ 0TMC1_26B.BIN]... file saved: C:\Program Files\InfinityBox\ChineseMiracle\eeprom[H526_05C_PCB01_GPRS_MT6226_S01.P02_SP_SSD_NB0_1_2_ 0TMC1_26B.BIN]_20090323-133104.B0E.bin flash: 01227E22202200:29EA0000000000 Backup required data Done Patch required data ... Patch required data Done Special operation ... Special operation Done Write ... Write Done Finalization ... formatting... flash: 01227E22202200:29EA0000000000 Finalization Done Finished, time used: 421 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On !:confused: |
8800e-1-carbon-RM233 Hello,Ifinity Team, First operation with this phone ==== log: [23/3/09 13:24:46] ==== COM20 [VCP0] selected module v2.76 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: "format ffs" ffs/eeprom backup enabled, it may takes several minutes ! Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6226:8A02:8A01]... CPU: MT6226 high speed boot Off chip: 0031:4BCA:4281 status: FF high speed boot Off boot packet size: 0002 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: 01227E22202200:29EA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb detecting chip #01 in region #00... flash: 01227E22202200:29EA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb detecting chip #02 in region #00... flash: 01227E22202200:29EA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb detecting chip #03 in region #00... flash: 01227E22202200:29EA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb number of flash chip/regions detected: 04/01 Initialize Done Set baud ... 115200 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... device parameters autodetection in progress... detecting chip #00 in region #00... flash: 01227E22202200:29EA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb detecting chip #01 in region #00... flash: 01227E22202200:29EA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb it's time to stop: 290000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [standard] generation identification#1 detection finished identification#1 protocol ver: 04 ver. sw 1: H526_05C_PCB01_GPRS_MT6226_S01.P02_SP_SSD_NB0_1_2_ 0TMC1_26B.BIN ver. sw 2: P02_SP_SSD_NB0_1.2.0TMC1_26B, 00000000 ffs offset/size: 00E00000/00200000 detect device identification#2... detection phase #1... .:confused: |
Code: COM5 [VCP0] selected Wait i will upload other file:) |
The 2nd test and post result:) flash[H526_05C_PCB01_GPRS_MT6226_S01.P02_SP_SSD_NB0_1_2_ 0TMC1_26B.BIN]_20090407-141912.B0M.rar Pass; vnmobile |
Thanks, result-:rolleyes: no power on the phone |
