Old 01-20-2008, 19:27   #1 (permalink)
Member: 432679
Thanks Meter: 118
A 898 DEAD help plz
THIS CELL IS DEAD, CUSTOMERS says it was working fine and suddenly became dead.
I MADE CONNECTION AS PER THE PINOUT IMAGE..
I run the cineese miracle software AND SELECT MT62xx- 6227
COM5 [VCP0] selected
Action: reset settings
Model: Autodetect 6205-6227 NOR
Checking data, wait...
error: can't activate test moide
error: operation failed !
Finished, time used: 249 sec
Remove/Install battery now !
WARNING ! Settings will be cleared, user data erased, Imei set to default value !
Make flash backup before this procedure !
only RX blue light start blinking continously when connet it to infinity box. then after 249 sec i stopped the software
THIS CELL IS NOT ZTE MADE,,, ONLY A 898 IS WRITTEN ON BACK ..CHECK THIS IMAGE
KINDLY ASSIT ME THIS IS MY FIRST EXPRIENCE WITH CHINA PHONE
Regards!
Old 01-20-2008, 23:14   #2 (permalink)
Member: 130995
Thanks Meter: 35,227
Hello,
It looks like you have used wrong pinout.
Also, try to make "complete" format instead of "safe".
Make flash backup before any operation !
Old 01-21-2008, 18:21   #3 (permalink)
Member: 432679
Thanks Meter: 118
Device: Autodetect 6205-6227 NOR
eeprom backup enabled, it may takes several minutes !
Action: reset
Boot...
baud autodetection active
19200
Connecting, wait...
Initializing[6226:8A02:8A01]...
CPU: MT6226
chip: 003183E:4AE0
high speed disabled
boot step size: 0002
Release Power button now !
Boot Done
Initialize...
flash: 98004900000002:2CEA0000000000
flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb
detecting chip #01 in region #00...
number of flash chip/regions detected: 02/01
Initialize Done
Set baud...
460800
Set baud Done
Identification...
device parameters autodetection in progress..
it's time to stop: 2C0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5
total flash region size: 01000000
detect device identification#1...
detection phase #1...
detect device identification#1 finished
identification#1 structure: 2nd [enhanced] generation
security area#1 is Ok
security area#1 backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.E60C5C76.[CKT26_06B_PCB01_GPRS_MT6226_S01.LION6_08_26B_HL_L5 SM_204_070918_LD-TR0_OV0_SS75_CTF_BT.BIN_8DE6BA47].rpl
identification#1 detection finished
device-id: E60C5C76
identification#1 protocol ver: 04
ver. sw1: CKT26_06B_PCB01_GPRS_MT6226_S01.LION6_08_26B_HL_L5 SM_204_070918_LD-TR0_OV0_SS75_CTF_BT.BIN
ver. sw2: LION6_08_26B_HL_L5SM_204_070918_LD-TR0_OV0_SS75_CTF_BT
ffs offset/size: 00F00000/00100000
detect device identification#2...
warning: optional information not found
detect device identification#2 finished
detecting eeprom/ffs area in 1 chip(s)...
standard eeprom/ffs offset detected: 00F00000
checking area[00000000]: 00000000-00FFFFFF...
eeprom/ffs found near: 00E00000
Detected eeprom/ffs address is non-standard: 00E00000
Posible reasons:
1. eeprom is Ok but address is non-standard
2. eeprom damaged and can't be detected
3. eeprom is Ok but detected incorrectly (f.e. unknown eeprom structure)
If you are not sure that detected address is correct:
1. press "NO" (and select standard address or terminate current operation)
2. make flash backup for emergency case
3. repeat required operation
Are you sure that detected eeprom address is correct ?
autodetected eeprom/ffs address[00E00000] confirmed by user
detecting eeprom/ffs size...
eeprom/ffs size: 00200000
ffs chip: 00
eeprom/ffs area: 00000000:00E00000-00FFFFFF
reading [eeprom[CKT26_06B_PCB01_GPRS_MT6226_S01.LION6_08_26B_HL_L5 SM_204_070918_LD-TR0_OV0_SS75_CTF_BT.BIN]]...
file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_eeprom[CKT26_06B_PCB01_GPRS_MT6226_S01.LION6_08_26B_HL_L5 SM_204_070918_LD-TR0_OV0_SS75_CTF_BT.BIN]_20080121-224007.B0E.bin
Identification Done
Manipulation...
Manipulation Done
Finalization...
Finalization Done
Write...
formatting...
Write Done
file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_system_log _E60C5C76_CKT26_06B_PCB01_GPRS_MT6226_S01.LION6_08 _26B_HL_L5SM_204_070918_LD-TR0_OV0_SS75_CTF_BT.BIN_8DE6BA47_20080121-224022.B0X.bin
Finished, time used: 208 sec
after this i didn't do restore orignal imei..and when power on. phones comes live but in chineese language..how to change in english language??????????
regards!
Old 01-21-2008, 18:36   #4 (permalink)
unlock_solution's Avatar
Member: 478791
Thanks Meter: 52
hi friend dial *#0000# for set english language and if you want restore imei then power on phone and use method one and right imei ......................
wbr
varun
Old 01-21-2008, 18:49   #5 (permalink)
Member: 432679
Thanks Meter: 118
thanks buddy
but i tried *#0044# to set english language and its ok.
i would like to tell that the pinout in C:\Program Files\InfinityBox\pinout\ChineseMiracle..A898 is not work for me, when i swap the rx and tx then only its detected by infinity..
thanks alot to infinity team
regards!
c45 BA20 dead help plz moustafatch x1x to x45/x50 20 09-10-2004 11:22
BG3 106kr126 dead. help plz? :) Newsted BF, BG, TH, BHx Series 0 01-25-2004 19:08
BF4 Dead-Help plz Cutty BF, BG, TH, BHx Series 4 03-20-2003 09:02
SL42 dead. HELP PLZ!!1 alex_kokaiko x1x to x45/x50 0 07-02-2002 23:21
used atxxee reader/writer by cage to upload 990723 and phone dead HELP PLZ makona Old Ericsson Phones & Sony Phones 11 07-16-2000 23:30
Page generated in 0.20433 seconds with 11 queries
