01-28-2021, 13:29 | #1 (permalink) |
Freak Poster Join Date: Mar 2018 Location: Karachi Pakistan Age: 30
Member: 2824001 Status: Offline Thanks Meter: 110 | Realme 6i RMX2040 Not connecting with Online Auth Infinity-Box [ Chinese Miracle ] MediaTek Service Module [ MTK ] v2.18 Load IDBase v125162 Ok! Update configuration ... Update Ok! Load IDBase v125162 Ok! Operation : Identify [ v2.18 ] Mode : FLASH 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM9) MODE : BOOTROM PORT : 9 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6768 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Talbot TYPE : MODERN RAPHAEL BROM : MEID : 3D258FF8E51F1608B30AE0AA8B40AC9A BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM MODE : 0_base : BASE_v2044 | Manual : Disabled BROM : SOCID : 3DE9C27A832159863AB4787C6B11266FF419E350485FCC1AC6 9B35D3F584E2B9 BROM : LOG : F0: 102B 0000 F3: 0000 0000 [0200] V0: 0000 0000 [0001] AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6768 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : 0x00007017 : DA SEND ERROR! ERROR : SECURE BOOT : SLA REQUIRED IN BROM MODE! INFO : BROM Level : CERT/AUTH required! Try boot device in PRELOADER mode with select PL/PL_CRYPTO/SWSEC type! Error : Fail to init protocol! >>> Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation! Reconnect Power/Cable! |
02-11-2021, 07:19 | #5 (permalink) |
Major Poster Join Date: Nov 2006
Member: 384290 Status: Offline Thanks Meter: 6 | realme 6i boot with infinitybox cm2mt2 Operation : Identify [ v2.21 ] Mode : FLASH 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM12) MODE : BOOTROM PORT : 12 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6785 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Krug TYPE : MODERN RAPHAEL BROM : MEID : 95E5B9D20A61D476EDE4A1D80A7C7025 BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM MODE : Xiaomi : Helio [G70][G80] | Manual : Enabled BROM : SOCID : DEAEBE0717C7CF7C58B48BBCF37402083122260446320DE00E 392BAFABE0944F BROM : SLA : Local Auth BROM : SLA : Auth Started! BROM : SLA : Auth Passed! BROM : SLA : 0x0000001F AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6785 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : INFINITY EMI : SRC : PRELOADER_INFINITY_0 EMI : CNT : 0001 EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00080000 [ 512.00 KB ] DRAM: 0x200000000 [ 8.00 GB ] UFS: CE014B4D3856383030314A4D2D423831 UFS: VEN : 0x01CE VID : KM8V8001JM-B81 IFW : 1300 LU0 : 0x00400000 [ 4.00 MB ] LU1 : 0x00400000 [ 4.00 MB ] LU2 : 0x1DCB000000 [ 119.17 GB ] FSN : 00330063003500310039003600370034 REG : 0x101010000 CHIP : MT6785 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : E357F57247DEACEFF3AE30C226017B5B DA : USB : HIGH-SPEED Boot done! Done! Elapsed: 00:00:42 Reconnect Power/Cable! Operation : Identify [ v2.21 ] Mode : FLASH 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM12) MODE : BOOTROM PORT : 12 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6785 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Krug TYPE : MODERN RAPHAEL BROM : MEID : 95E5B9D20A61D476EDE4A1D80A7C7025 BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM MODE : Xiaomi : Helio [G70][G80] | Manual : Enabled BROM : SOCID : DEAEBE0717C7CF7C58B48BBCF37402083122260446320DE00E 392BAFABE0944F BROM : SLA : Local Auth BROM : SLA : Auth Started! BROM : SLA : Auth Passed! BROM : SLA : 0x0000001F AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6785 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : INFINITY EMI : SRC : PRELOADER_INFINITY_0 EMI : CNT : 0001 EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00080000 [ 512.00 KB ] DRAM: 0x200000000 [ 8.00 GB ] UFS: CE014B4D3856383030314A4D2D423831 UFS: VEN : 0x01CE VID : KM8V8001JM-B81 IFW : 1300 LU0 : 0x00400000 [ 4.00 MB ] LU1 : 0x00400000 [ 4.00 MB ] LU2 : 0x1DCB000000 [ 119.17 GB ] FSN : 00330063003500310039003600370034 REG : 0x101010000 CHIP : MT6785 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : E357F57247DEACEFF3AE30C226017B5B DA : USB : HIGH-SPEED Boot done! Product Brand : realme Product Device : RMX2061 Product Model : realme 6 Pro Product Name : omni_RMX2061 Patch Level : QQ2A.200501.001.B2 Display ID : omni_RMX2061-eng 16.1.0 QQ2A.200501.001.B2 eng.nullxc.20200608.140119 test-keys Ver. CodeName : REL Ver. Release : 16.1.0 Sec. Patch : 2020-05-05 Product Info : RMX2061 Product Board : atoll Board Platform : atoll Product Manfct : realme NVRAM check : Failed! NVRAM damaged! NVRAM : SEC ENCRYPT [ IMEI ENCRYPTED ] Backup sensetive data [ 15 ] Backup path : Backup\MT6785__E357F57247DEACEFF3AE30C226017B5B\ [25] Read : NVRAM [15] Read : NVDATA [24] Read : PROINFO [42] Read : LK [14] Read : NVCFG [19] Read : PROTECT1 [20] Read : PROTECT2 [18] Read : PERSIST [0] Read : PRELOADER [21] Read : SECCFG [5] Read : OPPORESERVE1 [6] Read : OPPORESERVE2 [7] Read : OPPORESERVE3 Backup done! STORAGE : LifeStatus : UFS : OK! PRELOADER : DEVICE : DEV : MT6752 NME : preloader_oppo6785.bin CNT : 000C EMI : [00] : eMMC : LP_DDR4X : ID : 90014A68433861503E : VEN : HYNIX | DEV : hC8aP> : RAM : [ 3.00 GB ] EMI : [01] : eUFS : LP_DDR4X : DEV : MT128GASAO4U21 : RAM : [ 4.00 GB ] EMI : [02] : eUFS : LP_DDR4X : DEV : H9HQ53AECMMDAR : RAM : [ 6.00 GB ] EMI : [03] : eUFS : LP_DDR4X : DEV : MT064GASAO2U21 : RAM : [ 4.00 GB ] EMI : [04] : eUFS : LP_DDR4X : DEV : KM8V7001JM-B810 : RAM : [ 8.00 GB ] EMI : [05] : eUFS : LP_DDR4X : DEV : KM2H7001CM-B518 : RAM : [ 6.00 GB ] EMI : [06] : eUFS : LP_DDR4X : DEV : KM5H7001DM-B424 : RAM : [ 4.00 GB ] EMI : [07] : eUFS : LP_DDR4X : DEV : KM5V7001DM-B621 : RAM : [ 4.00 GB ] EMI : [08] : eUFS : LP_DDR4X : DEV : KM8V8001JM-B813 : RAM : [ 8.00 GB ] EMI : [09] : eUFS : LP_DDR4X : DEV : H9HQ16AFAMMDAR : RAM : [ 8.00 GB ] EMI : [0A] : eUFS : LP_DDR4X : DEV : H9HQ16AECMMDAR : RAM : [ 6.00 GB ] EMI : [0B] : eUFS : LP_DDR4X : DEV : KM2V8001CM-B707 : RAM : [ 6.00 GB ] Done! Elapsed: 00:00:38 |
The Following User Says Thank You to rajeshasr2002 For This Useful Post: |
