08-10-2015, 08:48 | #1 (permalink) |
No Life Poster Join Date: Jun 2011 Location: pakistan
Member: 1602407 Status: Offline Sonork: 100.1648061 Thanks Meter: 360 | A34 Qmobile not supported Code: 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 12 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8C00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 00AD00BC00900055005600AD00BC0000 eMMC_ID : 00000000000000000000000000000000 DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... DA started successuflly NAND FlashIC initialized [NAND] : FLASH_VEN : 0x0094 , [Acsip] A5R4GA41ATS [NAND] : FLASH_DIE : 00AD 00BC 0090 0055 0056 00AD 00BC [NAND] : FLASH_LEN : 0x20000000 INT RAM : 0x00020000 EXT RAM : 0x10000000 BOOT TYPE : NAND_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Conent now ... Not supported FlashType for this operation yet :( Done! Elapsed: 00:00:10 Reconnect Power/Cable! |
08-10-2015, 13:14 | #2 (permalink) |
No Life Poster Join Date: Mar 2007 Location: Factory Reset Protection (FRP) Age: 13
Member: 459784 Status: Offline Sonork: +91-9179403087 Thanks Meter: 1,542 | Quote: |
08-10-2015, 13:26 | #3 (permalink) | |
Member: 1602407 Status: Offline Sonork: 100.1648061 Thanks Meter: 360 | Quote:
thanks | |
08-10-2015, 14:21 | #4 (permalink) | |
Thanks For Suggestion there is no any bug in CM2 module unfortunately you did all - unsupported operation which is not supported - like nand cpu read flash or new flash id there is lots of flash id - unless - we will not see log, we cant tell you which is supported or not Last edited by pradeep_kus; 08-10-2015 at 14:26. | |
