03-29-2009, 08:27 | #1 (permalink) |
Freak Poster Join Date: Aug 2005 Location: Afghanistan Age: 36
Member: 173915 Status: Offline Thanks Meter: 301 | a35 successfully repaired use this firmware: ZTE-A35_Main_LP_TELMA-P108A5B01-Fr-MG01_g3dBV2[1].0_Jun-19-2007.B1M here is log: COM11 [VCP0] selected module v1.64 Device: ZTE-A35 Checking data, wait... Action: flash write Boot ... Press and HOLD Power button now ! e-gold: 820000 loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 460800 Set Baud Done Connecting ... flash: 0001:22C4 Connecting Done Check hardware ... sw version: LMA-P108A5B01-Fr-MG01 g3dBV2.0 04.12.00 18.26.11 08.02.00 EF-MG- Check hardware Done Check parameters ... Check parameters Done backup critical area ... backup critical area Done Check memory ... Check memory Done Write ... Erasing: Firmware Writing: Firmware Write Done Finished, time used: 114 sec Remove/Install battery now ! if still dead then select firmware+eeprom and flash. dont forget pressing thanks button |
The Following 3 Users Say Thank You to ashrafi580 For This Useful Post: |
07-29-2010, 09:05 | #2 (permalink) |
No Life Poster Join Date: Jun 2004 Location: Cameroon- Bamenda
Member: 69269 Status: Offline Thanks Meter: 175 | dead zte A35 not connecting COM3 [VCP2] selected module v1.73 Device: ZTE-A35 Checking data, wait... Action: write flash Boot ... Press and HOLD Power button now ! e-gold: 820013 loading... next part... boot answer: 00 error: unknown bootcode answer: Release Power button now Boot Failed Finished, time used: 44 sec Remove/Install battery now ! |
08-21-2010, 16:43 | #5 (permalink) | |
Major Poster Join Date: Jul 2010
Member: 1348367 Status: Offline Sonork: 59153 Thanks Meter: 7 | Quote:
Successfully Repaired 3110c Security Test failed after SD Repair | romeoluv56 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 14 | 05-14-2012 12:37 |
who have successfully repair SAMSUNG Qaulcomm CPU MSM6281..etc by Omnia repair tool? | zhanglei5556 | QUALCOMM Models (3G) | 5 | 12-15-2009 22:49 |
zte a35 successfully unlock | ashrafi580 | Infinity-Box | 3 | 03-30-2009 08:23 |
zte a35 imei repair | kachman | Infinity-Box | 5 | 07-29-2008 07:59 |
A35 IMEI repair ??? | djanib | x1x to x45/x50 | 0 | 12-04-2001 15:08 |
