A968 with reverse view!!!! Hi guys, i have a problem after flashing the A968 with display. It has been reversed! Any solution or anyone can give me a .bin.bom file to test. The details are the following: [E880_JJF2F12TRI_MT6225S00.GM_01_0_20080613.BIN].The printed PCB writes E880 V2.0, 2008.16.01. Thank you! http://www.imageshack.gr/files/suid2swmgqaab6cl89zl.jpg |
Hello, You need to flash phone with firmware version similar to original version. Do you have original backup ? |
Unfortunately i didn't keep back up. I had a ready .bin file and i load it to 20 phones, only to this phone this .bin file did the display to be reverse. Probably this phone is with newer or older firmaware version with other drivers for display. I don't know what to do now....Thanks for your post. If you can help me please or someone to load other .bin. file to that phone i would appreciate it. |
Hello, The only way now is: 1. double check that this phone original version is E880_JJF2F12TRI_MT6225S00.GM_01_0_20080613 2. if version is exactly like you have posted, you need to find somwhere file with the same (or very similar) firmware version. Files in support area with similar version: ChineseMiracle\Anycool\Anycool-T808_E880_KDI1OVF10_E880_GPRS_MT6225_S00.01_2_16m_ En_Ru_Fr_Es_De_Th_Vn_Tr_Farsi_Pt_Ar_w_eeprom.B0M.b in ChineseMiracle\Anycool\Anycool-T808_E880_KDI1OVF10_E880_GPRS_MT6225_S00.01_5_16m_ En_Fr_Es_Pt-BR_De_Vn_Tr_Ru_Persian_Th.B0M.bin ChineseMiracle\Anycool\Anycool-T818_E880_KDI1DMCF10_E880_GPRS_MT6225_S00.01_3__16 m_En_Ru_Es_It_De_Id_Th_Vn_Tr_Farsi_Pt_Ar.B0M.bin ChineseMiracle\_MT6225\E880_JJF1_MT6225S00.GM_01_2 _20080531__A968_16m_En_Cn_Cn.B0M.bin ChineseMiracle\_MT6225\E880_JQ1MCF10_E880_GPRS_MT6 225_S00.01_4_16m_En_Ru_Fr_Es_It_Id_Th_Vn_Tr_Farsi_ Pt_Ar.B0M.bin ChineseMiracle\_MT6225\E880_KDI1DOVF10_MT6225S00.G M_01_0_20080820_16m_En_Ru_Fr_Es_It_De_Vn_Tr_Farsi_ Pt_Ar.B0E.bin ChineseMiracle\_MT6225\E880_XZY1MCF8_E880_GPRS_MT6 225_S00.01_3__Cesim-V30_16m_En_Ru_Fr_It_Id_Th_Farsi_Ar.B0M.bin ChineseMiracle\_MT6225\repair_eeprom\E880_JJF1_MT6 225S00.GM_01_2_20080531__ffs_016.B0E.bin ChineseMiracle\_MT6225\repair_eeprom\E880_JQ1MCF10 _E880_GPRS_MT6225_S00.01_4.B0E.bin ChineseMiracle\_MT6225\repair_eeprom\E880_XZY1MCF8 _E880_GPRS_MT6225_S00.01_3__ffs_01.B0E.bin |
Thanks a lot! I will go now to support area to load one by one your recommended files. |
Anyone can upload roms E880_JJF2F12TRI_MT6225S00.GM_01_0_20080527 or E880_JJF2F12TRI_MT6225S00.GM_01_0_20080613 or E880_JJF2F12TRI_MT6225S00.GM_01_0_20080618 pleaseeeeeee |
please go to www.rapidshare.com and upload file. post link here, thanx |
Thank you very very very much!!!!!!!!!:):):):):). I solve the problem with this date rom !!!! |
hello! i will upload this file to our support server too. thank you! |
Hello! Someone can translate the flash file of this phone to have portuguease inside because I have the same phone with sw fault but the phone has portuguease lang... If some one can help I will be thankfull. |
Please I realy need this file translated if some one could help me... Best Reguards |
changjiang a 968, uart 2 is occupied, it can not be reseted to uart1 after going eng. Dear sir, I have a changjiang a968. it was working fine. but sudenly I find it saying that uart 2 is occupied when i try to use it as a comport to conect pc. it is well working in webcam mode and storage mode. I tried to go in eng. mode with *#3646633#. device- set uart-urt setting- ps config to uart 1, but it says ( not allowed or conflict ). I have nothing did with this phone. Dear friend/sir please help me is it a hardware problem or it can be solved with software or any special code. I also tried reset factory setting by 1122 code. but still it remain same. before this probelm I was using this phone as a modem for gprs.through my pc. Please help thanks. |
