About flash file Product supporter Plz tel me about flash file. can i write flash file(bin) in a set from read to another same model set.because many flase not avalable in support site. ...........ant tell me about nor flash & nand flase .Thanks in advance |
You must read flash file and send it to us , we will convert it and upload it to support area in the correct format which phones do you refer to ? |
niktel c 2000 ([M380_CSTN_ABROAD_PCB01_GSM_MT6225_S00.M380_CSTN_AB ROAD_V1_0_2.BIN]) |
plz inform me when u upload this flase file.Thanks in advance |
I have a china other dead set model 2gsm,2blutooth .After formating calling & receving ok.Display show only dial number.No menu display here.I am post formating log file & backup flash.Plz convert it & upload And inform me By posting here.Plz guide me also.Thanks |
1 Attachment(s) |
@umesh garg you can write "Chinese" model backup into another phone without sending files to support persons. Impotrtant advic: read text in software log window during flash reading and follow advices given by software |
@42 Thanks for usefull advices But sir can u tell me about post 6 & 7.where i can got tested ok flash file.I am searching past 1 month in support area. E553_W1PA.01.1_26S01 please help me |
Hello, If you can not find exactly the same flash file you have two ways: 1. try to use similar (not exact the same) flash files from Infinity-Box support area 2. try to find the same phone, read flash from it and flash into dead phone |
Thanks for fast support But sir how I can search similar file from support area.For example file is-----E553_W1PA.01.1_26S01 how can u search its similat file .plz explain & tell me after flashed similar file set 100% proper work or some diffrent type menu display. |
Can u tell me in this file......E553_W1PA.01.1_26S01............whitch part is nessesary for search similar file |
You can try to search files similar to "E553_W1PA..." but as I can see you already gave the answer for your question here: http://forum.gsmhosting.com/vbb/show...2&postcount=11 so you need to find so similar version as possible |
Thanks for help........ |
