12-20-2016, 00:15 | #1 (permalink) |
No Life Poster Join Date: Dec 2005 Location: mt brazil
Member: 211017 Status: Offline Thanks Meter: 312 | Cat S50 Unsupported CPU 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device not found! Check cable, connection and drivers! Reconnect Power/Cable! Operation : Identify [ v1.04 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 400 [MSM8x26] ID_BLOCK_S : 054E6500 ID_BLOCK_I : 008050E1 ID_BLOCK_L : E24DD8D4D9C38E88 ID_BLOCK_L : 0305DF056E733843 Use CM2 Internal Loader Error : Prepare target failed! Unsupported CPU or unknown SBType! Send log and report.log to support! Include device info also! Reconnect Power/Cable! |
01-03-2017, 13:46 | #2 (permalink) |
Freak Poster Join Date: Apr 2001 Location: Lithuania Age: 51
Member: 3962 Status: Offline Sonork: 75446 Thanks Meter: 2 | the same problem CAT S50 Operation : Identify [ v1.08 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 400 [MSM8x26] ID_BLOCK_S : 08B69155 ID_BLOCK_I : 008050E1 ID_BLOCK_L : 55152B297299E14FAE2660EC596C5F25 ID_BLOCK_L : 56228CAAA87173FFB900C1577B09D1F4 Use CM2 Internal Loader Error : Prepare target failed! Unsupported SecureType! Send log and report.log to support! Include device info also! |
