12-08-2016, 07:59 | #1 (permalink) |
Freak Poster Join Date: Feb 2016 Location: karnataka, mysore
Member: 2528503 Status: Offline Sonork: 1670792 Thanks Meter: 70 | Acer- iconia one 7 b1-770 model [a5007] pattern lock mt 8127a help jaydi sir WHERE MY UNIT IS ACER ICONIA A5007 PATTERN LOCKED ,WHEN AM TRYING TO UNLOCK AM GETTING THIS ERROR PLZ HELP IS IT POSSIBLE TO UNLOCK ??? HERE IS THE LOG TRYING TO GET EXTENDED INFO Card found : S/N : 914EDBBC , v0134 Chinese Miracle II [MTK module] v 1.58 Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 44 ] Sync... Inital Boot Ok! BB_CPU_PID : 8127 BB_CPU_NME : [MediaTek] MT8127_S00 BB_CPU_EXT : 0xCA04 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... [DA_ERROR] : SECURITYBOOT_BOOT_NOT_ACCEPTED Boot Error! Operation Failed Elapsed: 00:00:09 Reconnect Power/Cable! READ PATTERN DP ALSO NOT POSSIBLE Card found : S/N : 914EDBBC , v0134 Chinese Miracle II [MTK module] v 1.58 Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 44 ] Sync... Inital Boot Ok! BB_CPU_PID : 8127 BB_CPU_NME : [MediaTek] MT8127_S00 BB_CPU_EXT : 0xCA04 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... [DA_ERROR] : SECURITYBOOT_BOOT_NOT_ACCEPTED Boot Error! Operation Failed Elapsed: 00:00:09 Reconnect Power/Cable! Operation : Read Pattern/DP Lock [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Device boot not done Check Drivers Try again Boot Error! Operation Failed Elapsed: 00:00:28 Reconnect Power/Cable! Operation : Read Pattern/DP Lock [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 44 ] Sync... Inital Boot Ok! BB_CPU_PID : 8127 BB_CPU_NME : [MediaTek] MT8127_S00 BB_CPU_EXT : 0xCA04 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... [DA_ERROR] : SECURITYBOOT_BOOT_NOT_ACCEPTED Boot Error! Operation Failed Elapsed: 00:00:14 Reconnect Power/Cable! |
12-08-2016, 11:06 | #2 (permalink) | |
Freak Poster Join Date: Mar 2010
Member: 1261483 Status: Offline Sonork: 100.1644685 Thanks Meter: 124 | Quote:
Bootloader locked. first unlock bootloader then try to read pattern.. | |
12-14-2016, 09:28 | #4 (permalink) | |
Member: 2528503 Status: Offline Sonork: 1670792 Thanks Meter: 70 | Hello dear jaydi plz help plz help me with above log how to remove patten plz you can help me plz Quote:
