12-31-2015, 15:31 | #1 (permalink) |
No Life Poster Join Date: Jan 2004 Location: Serbia Age: 40
Member: 49634 Status: Offline Sonork: 100.1671023 Thanks Meter: 71 | Acer Liquid Z410 preloader erased |
12-31-2015, 15:55 | #3 (permalink) |
Member: 49634 Status: Offline Sonork: 100.1671023 Thanks Meter: 71 | Code: Chinese Miracle II [MTK module] v 1.40 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 116 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6752 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6732|MT6752_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0x05 BLVersion : 0xFE Preloader Status : Not active (Erased) Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v5.1540.01.01 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 150100513732534D4200CA74CC9A62FD DA Stat : v4.2 on BBID : 0x8F DRAM not initialized , configure DRAM Settings DRAM EmiReq Ok , 0x00B0 DRAM Init Ok , 0x40000000 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0015 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BMS27 [eMMC] : FLASH_CID : 150100513732534D4200CA74CC9A62FD [eMMC] : FLASH_EXT : 0x00400000 , 0x00400000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : acer ProdName : z410_emea_gen1 ProdModel : Z410 Device : acer_z410 AndroidVer: 4.4.4 MTKxCPU : MT6752 MTKxPRJ : Acer_AV0K0_Z410_1.002.00_EMEA_GEN1 MODEM : BaseBand : MT6752_S00_MOLY_LR9_W1423_MD_LWTG_MP_V1_P13_1_lwg_n EXTRA : LCD [0] : rm68171_fwvga_dsi_vdo LCD [1] : sim_rm68191_qhd_dsi_vdo_cmi_45 LCD [2] : sim_otm9605_qhd_dsi_vdo_hsd_45 LCD Res : 960x540 TOUCH [0] : gt9xx_v22 CAM [0] : gc2355_mipi_raw CAM [1] : ov2680_mipi_raw CAM [2] : gc0310_mipi_yuv CAM [3] : gc5004_mipi_raw CAM [4] : ov5670_mipi_raw MODEM : z410_mt6732k52_md1_lwg_dsds_EU_V102 LOCALE : en_GB en_US es_ES ru_RU pt_BR fr_FR de_DE it_IT ar_EG pt_PT nl_NL uk_UA hr_HR el_GR fa_IR mk_MK sr_RS sl_SI tr_TR iw_IL Done! Elapsed: 00:00:17 Reconnect Power/Cable! Operation : HW Test [ v1.40 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 116 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6752 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6732|MT6752_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0x05 BLVersion : 0xFE Preloader Status : Not active (Erased) Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v5.1540.01.01 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 150100513732534D4200CA74CC9A62FD DA Stat : v4.2 on BBID : 0x8F DRAM not initialized , configure DRAM Settings DRAM EmiReq Ok , 0x00B0 DRAM Init Ok , 0x40000000 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0015 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BMS27 [eMMC] : FLASH_CID : 150100513732534D4200CA74CC9A62FD [eMMC] : FLASH_EXT : 0x00400000 , 0x00400000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Processing Miscellaneous test MSC : BatteryLevel : 4153 mV [Processing] FlashMemory Read-Write test [eMMC] : [SAMSUNG] , BMS27 , 0x1D2000000 , 7456 MiB [eMMC] : CID : 150100513732534D4200CA74CC9A62FD [eMMC] : MODE : SQ-WR [PASSED] : eMMC RW Check #1 Ok! [eMMC] : MODE : RA-WR [PASSED] : eMMC RW Check #2 Ok! [eMMC RO CHECK] : eMMC Ok! READ-WRITE Passed! [Processing] RAM Read-Write test [DRAM] : 0x40000000 , 1024 MiB [DRAM] : ADDRESS BUS test [PASSED] : Bus Count : 0x1D [DRAM] : DATA BUS test [PASSED] : Bus Count : 0x1F [DRAM] : PATTERN test [PASSED] : PATTERN Ok [DRAM] : INCDEC test [PASSED] : INCDEC Ok All Done! Done! Elapsed: 00:02:31 Reconnect Power/Cable! User selected Preloader file : preloader_simcom6752_lwt_cu.bin Operation : Init Preloader [ v1.40 ] Supported HW by Preloader : FlashID [0] CID : 90014A484147326505 , Name : HAG2e , Vendor : 90 , [HYNIX] FlashID [1] CID : 150100513758534142 , Name : Q7XSAB , Vendor : 15 , [SAMSUNG] FlashID [2] CID : 90014A484147326504 , Name : HAG2e , Vendor : 90 , [HYNIX] FlashID [3] CID : FE014E50314A39354B , Name : P1J95K , Vendor : FE , [MICRON] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 116 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6752 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6732|MT6752_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0x05 BLVersion : 0xFE Preloader Status : Not active (Erased) Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v5.1540.01.01 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 150100513732534D4200CA74CC9A62FD DA Stat : v4.2 on BBID : 0x8F DRAM not initialized , configure DRAM Settings DRAM EmiReq Ok , 0x00B0 Error : DA init Failed! Error code : 0x5 LErr : EMICFG_NOT_FOUND Boot Error! Operation Failed Elapsed: 00:00:07 Reconnect Power/Cable! |
01-04-2016, 10:27 | #5 (permalink) | |
Member: 49634 Status: Offline Sonork: 100.1671023 Thanks Meter: 71 | not helping... It didn't helped... do you have any more ideas? thx Quote:
01-06-2016, 14:48 | #7 (permalink) |
Member: 49634 Status: Offline Sonork: 100.1671023 Thanks Meter: 71 | Can you start collecting/supporting PRL sharing, it's a common problem to repair erased preloaders and big trouble to find the right ones... thanks anyway |
01-06-2016, 15:06 | #8 (permalink) | |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Quote:
We are already collecting preloader files and updating support in every update. But it's nearly impossible to support worldwide phones since millions of phones are there and so preloaders. What's not supported users can post in section and team will add it in coming updates. Br. Infinity Box Support Team. | |
