02-16-2008, 16:57 | #1 (permalink) |
Freak Poster Join Date: Oct 2005
Member: 194285 Status: Offline Thanks Meter: 53 | after also format ffs phone restart with sim my problem is after also format ffs phone is restarting with sim phone have two rx and tx rxa, txa and rxb, txb phone is connecting to infinity in rxa, txa gnd readed full flash also done format ffs still phone is restarting then connect rxb and txb phone is not connecting to infinity COM4 [VCP0] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: read NOR flash Boot... Press and HOLD Power button now ! baud autodetection active 19200 Connecting, wait... Initializing[6226:8A02:8A01]... CPU: MT6226 chip: 0031:C4BF:505D high speed disabled boot step size: 0002 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud... 460800 Set baud Done Identification... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb it's time to stop: 290000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [enhanced] generation security area#1 damaged, recalculation required identification#1 detection finished device-id: 02149427 identification#1 protocol ver: 04 ver. sw1: E553_B2_E553_GPRS_MT6226_S01.01_1.BIN ver. sw2: E553_B2.01.1, 0D6CDD79 ffs offset/size: 00800000/001FF000 detect device identification#2... detection phase #1... . warning: optional information not found detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset detected: 00800000 flash: EC257E25082501:29EA0000000000 checking area[00000000]: 00000000-00FFFFFF... eeprom/ffs found near: 00E00000 Detected eeprom/ffs address is non-standard: 00E00000 Posible reasons: 1. eeprom is Ok but address is non-standard 2. eeprom damaged and can't be detected 3. eeprom is Ok but detected incorrectly (f.e. unknown eeprom structure) If you are not sure that detected address is correct: 1. press "NO" (and select standard address or terminate current operation) 2. make flash backup for emergency case 3. repeat required operation Are you sure that detected eeprom address is correct ? autodetected eeprom/ffs address[00E00000] confirmed by user detecting eeprom/ffs size... eeprom/ffs size: 00200000 ffs chip: 00 eeprom/ffs area: 00000000:00E00000-00FFFFFF reading [flash[E553_B2_E553_GPRS_MT6226_S01.01_1.BIN]]... file saved: D:\Program Files\InfinityBox\ChineseMiracle\backup_flash[E553_B2_E553_GPRS_MT6226_S01.01_1.BIN]_20080216-154459.B0M.bin Finished, time used: 524 sec Remove/Install battery now ! |
02-17-2008, 10:33 | #5 (permalink) |
Member: 194285 Status: Offline Thanks Meter: 53 | here is log for 2nd cpu with rxb txb COM4 [VCP0] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: reset Boot... Press and HOLD Power button now ! error: can't detect device Release Power button now ! in case of initial connection problem: on/off "Boot baudrate autoselect" box. Boot Fail Finished, time used: 248 sec Remove/Install battery now ! |
Sigmatel restart with sim after ffs etc. | Riteshgpt60 | Infinity-Box | 25 | 04-17-2010 11:24 |
ZT608 restart with sim i format with infinity still same | zargar322 | Infinity-Box | 1 | 07-10-2008 23:24 |
Hi please help me with death n95 formats ffs phone no conected | bibooo | Infinity-Box | 14 | 01-30-2008 22:51 |
CECT T689 After format FFS work only with 1 sim | snsoftkiller | Infinity-Box | 12 | 11-04-2007 21:40 |
