01-01-2009, 19:02 | #1 (permalink) |
No Life Poster Join Date: May 2006 Location: Sambrial (Sialkot)
Member: 282066 Status: Offline Sonork: 100.1590696 Thanks Meter: 569 | After LG KG300 now KG195 Successfully fixed "off with LG logo" do same as with LG KG 300 of with LG logo ....and successfully solved same problem of LG KG 195... 1. Run ChineseMiracle software 2. Select model "MT6228 NAND" 3. Make "format" by "whole flash chip" method i did same methode with LG KG 195 now my set is working very well. here is logs COM13 [VCP0] selected module v2.72 Device: Autodetect 6228, 6229, 6230 NAND Checking data, wait... Action: erase flash chip Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6226:8A02:8A01]... CPU: MT6226 high speed boot Off chip: 0031:3941:1B14 high speed boot Off boot packet size: 0002 Release Power button now ! Boot Done Initialize ... version: 3.020A loader: 3.748.0 NAND id: 98F08095 page size: 800+40 pages/block: 40 bits i/o: 08 address cycles: 04 blocks: 0200 NOR: 0098:004900000000 [01000000] NAND: 0098:00F000800095 [04200000] Initialize Done Set baud ... 921600 Set baud Done Identification ... reading structure area... detecting structure... warning: incorrect bootloader header: 20A898E184DC18E9A0638D19118E74D9 nfi area detection finished: failed error: can't detect nand chip parameters, default values assigned Identification Done Write ... formatting... .error: code: 0A00006900 Write Fail Finished, time used: 885 sec Remove/Install battery now ! |
The Following 17 Users Say Thank You to zeerik For This Useful Post: |
01-01-2009, 20:13 | #2 (permalink) | |
No Life Poster Join Date: Dec 2005 Location: IN_BATTLE_FIELD.
Member: 214340 Status: Offline Thanks Meter: 906 | Quote:
Bro alot of Errors accured how it worked,,,it is realy a miracle,,,,BR | |
01-01-2009, 20:21 | #3 (permalink) |
No Life Poster Join Date: Jan 2006 Location: inside emmc ufs Age: 19
Member: 221603 Status: Offline Sonork: 100.1581270 Thanks Meter: 6,395 | kg200 , kg300 , kg195 tested and working with this solution |
The Following 4 Users Say Thank You to c_ahmad79 For This Useful Post: |
01-02-2009, 22:32 | #6 (permalink) |
No Life Poster Join Date: Mar 2008 Location: infinity-box
Member: 720034 Status: Offline Thanks Meter: 213 | @zeerik Thank you very much for test report ! Each test report with attached logs is very important for us so we can see how is Infinity-Box software works and what is possible problems (so we will be able to fix it) and successfully done work. @blaw You can see an instruction in first message in current thread |
01-10-2009, 18:22 | #7 (permalink) |
No Life Poster Join Date: Dec 2007 Location: Skype , Sonork
Member: 649528 Status: Offline Sonork: 100.1590443 Thanks Meter: 6,958 | its tested bro i test also 3 sets 2 kg195 and 1 kg200.. |
The Following User Says Thank You to GsmUniversal For This Useful Post: |
01-12-2009, 03:11 | #13 (permalink) |
No Life Poster Join Date: Oct 2007 Location: Pakistan Age: 41
Member: 616556 Status: Offline Thanks Meter: 112 | WOW Its working KG300 Hang on LG logo Thanx Infinity team COM10 [VCP0] selected module v2.73 Device: Autodetect 6228, 6229, 6230 NAND Checking data, wait... Action: erase flash chip Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6227:8A02:8A01]... CPU: MT6227 high speed boot On chip: 0031995:0A5C boot packet size: 0400 Release Power button now ! Boot Done Initialize ... version: 3.0208 loader: 3.748.0 NAND: Toshiba TC58DVM92A1FT 512+16 32 pages, 66Mb NAND id: 9876A5C0 page size: 200+10 pages/block: 20 bits i/o: 08 address cycles: 04 blocks: 1000 NOR: 0098:004900000000 [01000000] NAND: 0098:007600A500C0 [04200000] Initialize Done Set baud ... 115200 Set baud Done Identification ... reading structure area... detecting structure... warning: incorrect bootloader header: BF66602C6E84A2288134741253A17B54 nfi area detection finished: failed error: can't detect nand chip parameters, default values assigned Identification Done Write ... formatting... .................................................. ........error: code: 4A80006900 ..........................................error: code: A500000000 ...Write Fail Finished, time used: 83 sec Remove/Install battery now ! |
01-13-2009, 15:51 | #14 (permalink) |
Freak Poster Join Date: Jan 2007 Location: Uk/Pk
Member: 436045 Status: Offline Sonork: 1581208 Thanks Meter: 31 | Hello there... I tried the same thingy n it was easy money Thankss.. here's the log.. COM4 [VCP0] selected module v2.69 Device: Autodetect 6228, 6229, 6230 NAND Checking data, wait... Action: erase flash chip Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6226:8A02:8A01]... CPU: MT6226 high speed boot disabled chip: 0031:8741:146C high speed disabled boot packet size: 0002 Release Power button now ! Boot Done Initialize ... version: 3.020A loader: 3.748.0 NAND id: 98F08095 page size: 800+40 pages/block: 40 bits i/o: 08 address cycles: 04 blocks: 0200 NOR: 0098:004900000000 [01000000] NAND: 0098:00F000800095 [04200000] Initialize Done Set baud ... 115200 Set baud Done Identification ... reading structure area... detecting structure... warning: incorrect bootloader header: 3F792BF21C48EA79848CCB27CDED08CE nfi area detection finished: failed error: can't detect nand chip parameters, default values assigned Identification Done Write ... formatting... ....error: code: 0BE1000800 ..error: code: 0C00006900 .error: code: 3400006900 .error: code: 4800006900 .error: code: 5400006900 .error: code: 6000006900 .error: code: 6800006900 .error: code: 7400006900 .error: code: 7C00006900 .error: code: 8800006900 .error: code: 9000006900 .error: code: 9C00006900 .error: code: A400006900 .error: code: B000006900 .error: code: BC00006900 .error: code: C400006900 .error: code: D000006900 .error: code: D800006900 .error: code: E400006900 .error: code: EC00006900 .error: code: F800006900 ....error: code: 0BE1010800 error: code: CD1C00000B Write Fail Finished, time used: 812 sec Remove/Install battery now ! |
The Following User Says Thank You to tom313rd For This Useful Post: |
LG KG300,KG200,KG195,C2500 Flash Free With Spider-Man Cracked. | /FAISAL/ | LG | 12 | 11-13-2010 02:26 |
Lg Kg300 Imei changed Successfully.... | adnanskyland | SpiderMan | 2 | 05-11-2009 19:26 |
lg kg300 dead after flashing with hwk | khan_mobiles | HWK | 2 | 07-28-2008 09:14 |
Help...LG KG300 DEAD After flash with infinity | tedyjohar | Infinity-Box | 1 | 03-12-2008 10:41 |
