02-25-2023, 15:06 | #1 (permalink) |
No Life Poster Join Date: Jul 2008 Location: Sharja UAE
Member: 820592 Status: Offline Sonork: 100.1590378 Thanks Meter: 327 | after reset phone stuck on RED logo Nokia G10 Code: 1. Power Off the device 2. Wait 20 seconds 3. Connect USB cable to device [remember Vol+ | Vol-] Waiting for device connection... PTFN: MediaTek USB Port_V1632 (COM8) MODE: BOOTROM; PORT: 8 Waiting BOOT ack... BROM: Skip ACK verify BROM: Init BROM BROM: Init passed CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] MEID: 53F5CB876B98191E4D62F9AAE2FF7136 BROM: Sec Level: 0x000000E7 Mode: SBC+SLA+SDA+EXT BROM: BROM|BL : 0x05|0xFE [BOOTROM] BROM: SOCID: AB555B64EB0B6808EFFA1B9239A1A1DF1CE33AD6C32BDC31B8044D6B74AA780F BROM: SLA: Local Auth BROM: SLA: Starting Auth BROM: FF : Look for EMI BROM: FF : EMI not found BROM: SLA: Auth Passed BROM: SEC: 0x000000E0 AGENT: 0_base: BASE_v2112 | Manual: Off [0656ff20] C:\InfinityBox\CM2MT2\boot\0_base\BASE_v2112\MTK_AllInOne_DA.bin Looking for suitable BootChain in DA... Found MT6765 AGENT: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... BROM: DA sent BROM: Transfer control to DA... DA: AGENT started DA: SYNC DA: MODE: BROM DA: EXT_RAM NOT initialized EMMC: CID: 880103534C4436344765FB6A1957C7E1 VEN: Foresee OEM: 3 ID: 534C44363447 [SLD64G] PRV: 0x65 SNN: 4218034519 [0xFB6A1957] MF: 12/2020 EMI: INFINITY PRELOADER_INFINITY_3 with 5 memory type(s) supported EMI: Init EMI from INTERNAL DB EMI: EXT_RAM CFG Passed DA: BOOT to 2nd DA... DA: 2ND stage confirmed DA: SYNC with DA passed DA: Receiving HW info SRAM 0x0003A000 [ 232.00 KB ] DRAM 0x100000000 [ 4.00 GB ] EMMC: CID: 880103534C4436344765FB6A1957C7E1 VEN: Foresee OEM: 3 ID: 534C44363447 [SLD64G] PRV: 0x65 SNN: 4218034519 [0xFB6A1957] MF: 12/2020 BOOT1: 0x00400000 [ 4.00 MB ] BOOT2: 0x00400000 [ 4.00 MB ] RPMB: 0x00400000 [ 4.00 MB ] USER: 0xE67800000 [ 57.62 GB ] CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] RNID: B21D506D75998D8934235A5D9FE4D3D2 MEID: 53F5CB876B98191E4D62F9AAE2FF7136 DA: USB: HIGH-SPEED Boot done [1] EMI settings has been learned! Connect device again with required operation! Done: 00:01:31 Reconnect Power/Cable now here is log Code: Operation: Reset Settings/Format FS [ v2.38d1 ] Platform: MTK SmartPhone - MT65/67/68/81/83/87 | Helio G/P/X Mode: SMART RESET Wait... WARNING! Format FS WILL RESET ALL USER DATA! Make sure about correct format mode selection! Continue? Yes 1. Power Off the device 2. Wait 20 seconds 3. Connect USB cable to device [remember Vol+ | Vol-] Waiting for device connection... PTFN: MediaTek USB Port_V1632 (COM8) MODE: BOOTROM; PORT: 8 Waiting BOOT ack... BROM: Skip ACK verify BROM: Init BROM BROM: Init passed CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] MEID: 53F5CB876B98191E4D62F9AAE2FF7136 BROM: Sec Level: 0x000000E7 Mode: SBC+SLA+SDA+EXT BROM: BROM|BL : 0x05|0xFE [BOOTROM] BROM: SOCID: AB555B64EB0B6808EFFA1B9239A1A1DF1CE33AD6C32BDC31B8044D6B74AA780F BROM: SLA: Local Auth BROM: SLA: Starting Auth BROM: SLA: Auth Passed BROM: SEC: 0x000000E0 AGENT: 0_base: BASE_v2112 | Manual: Off [0656ff20] C:\InfinityBox\CM2MT2\boot\0_base\BASE_v2112\MTK_AllInOne_DA.bin Looking for suitable BootChain in DA... Found MT6765 AGENT: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... BROM: DA sent BROM: Transfer control to DA... DA: AGENT started DA: SYNC DA: MODE: BROM DA: EXT_RAM NOT initialized EMMC: CID: 880103534C4436344765FB6A1957C7E1 VEN: Foresee OEM: 3 ID: 534C44363447 [SLD64G] PRV: 0x65 SNN: 4218034519 [0xFB6A1957] MF: 12/2020 EMI: INFINITY PRELOADER_INFINITY_3 with 5 memory type(s) supported EMI: Init EMI from INTERNAL DB EMI: EXT_RAM CFG Passed DA: BOOT to 2nd DA... DA: 2ND stage confirmed DA: SYNC with DA passed DA: Receiving HW info SRAM 0x0003A000 [ 232.00 KB ] DRAM 0x100000000 [ 4.00 GB ] EMMC: CID: 880103534C4436344765FB6A1957C7E1 VEN: Foresee OEM: 3 ID: 534C44363447 [SLD64G] PRV: 0x65 SNN: 4218034519 [0xFB6A1957] MF: 12/2020 BOOT1: 0x00400000 [ 4.00 MB ] BOOT2: 0x00400000 [ 4.00 MB ] RPMB: 0x00400000 [ 4.00 MB ] USER: 0xE67800000 [ 57.62 GB ] CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] RNID: B21D506D75998D8934235A5D9FE4D3D2 MEID: 53F5CB876B98191E4D62F9AAE2FF7136 DA: USB: HIGH-SPEED Boot done [1] Reading... Ok Reading... Scan memory... Found region: 30920 [12|30920|1124] Scan filesystem... SmartInfo: AndroidVer: 12 UserDataFS: 0x02 CacheFS: 0x02 Strategy: 7 Verify device config... Ok Loaders Ok Backup [20] to C:\InfinityBox\CM2MT2\backup\MT6765__53F5CB876B98191E4D62F9AAE2FF7136\ [17] Read: NVRAM [7] Read: NVDATA [15] Read: PROINFO [6] Read: NVCFG [10] Read: PROTECT1 [1] Read: PGPT [13] Read: PERSIST [0] Read: PRELOADER Done 8 files Compress: C:\InfinityBox\CM2MT2\backup\MT6765__53F5CB876B98191E4D62F9AAE2FF7136\ Cleanup... Ok Verify C:\InfinityBox\CM2MT2\backup\MT6765__53F5CB876B98191E4D62F9AAE2FF7136.7z Verified Process: RESET PROTECTION... ERR: 0xC0010001 ERROR ERR: 0x00000000 0x00000000 Format Ok: RESET PROTECTION Process: USERDATA... ERR: 0xC0010001 ERROR ERR: 0x00000000 0x00000000 Format Ok: USERDATA Process: USERDATA... ERR: 0xC0010001 ERROR ERR: 0x00000000 0x00000000 Format Ok: USERDATA Process: USERDATA... ERR: 0xC0010001 ERROR ERR: 0x00000000 0x00000000 Format Ok: USERDATA Done: 00:02:25 Reconnect Power/Cable now here is log. Code: Operation: Reset Settings/Format FS [ v2.38d1 ] Platform: MTK SmartPhone - MT65/67/68/81/83/87 | Helio G/P/X Mode: FULL FACTORY: WIPE + FRP Wait... WARNING! Format FS WILL RESET ALL USER DATA! Make sure about correct format mode selection! Continue? Yes 1. Power Off the device 2. Wait 20 seconds 3. Connect USB cable to device [remember Vol+ | Vol-] Waiting for device connection... PTFN: MediaTek USB Port_V1632 (COM42) MODE: BOOTROM; PORT: 42 Waiting BOOT ack... BROM: Skip ACK verify BROM: Init BROM BROM: Init passed CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] MEID: 53F5CB876B98191E4D62F9AAE2FF7136 BROM: Sec Level: 0x000000E7 Mode: SBC+SLA+SDA+EXT BROM: BROM|BL : 0x05|0xFE [BOOTROM] BROM: SOCID: AB555B64EB0B6808EFFA1B9239A1A1DF1CE33AD6C32BDC31B8044D6B74AA780F BROM: SLA: Local Auth BROM: SLA: Starting Auth BROM: SLA: Auth Passed BROM: SEC: 0x000000E0 AGENT: 0_base: BASE_v2112 | Manual: Off [0656ff20] C:\InfinityBox\CM2MT2\boot\0_base\BASE_v2112\MTK_AllInOne_DA.bin Looking for suitable BootChain in DA... Found MT6765 AGENT: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... BROM: DA sent BROM: Transfer control to DA... DA: AGENT started DA: SYNC DA: MODE: BROM DA: EXT_RAM NOT initialized EMMC: CID: 880103534C4436344765FB6A1957C7E1 VEN: Foresee OEM: 3 ID: 534C44363447 [SLD64G] PRV: 0x65 SNN: 4218034519 [0xFB6A1957] MF: 12/2020 EMI: INFINITY PRELOADER_INFINITY_3 with 5 memory type(s) supported EMI: Init EMI from INTERNAL DB EMI: EXT_RAM CFG Passed DA: BOOT to 2nd DA... DA: 2ND stage confirmed DA: SYNC with DA passed DA: Receiving HW info SRAM 0x0003A000 [ 232.00 KB ] DRAM 0x100000000 [ 4.00 GB ] EMMC: CID: 880103534C4436344765FB6A1957C7E1 VEN: Foresee OEM: 3 ID: 534C44363447 [SLD64G] PRV: 0x65 SNN: 4218034519 [0xFB6A1957] MF: 12/2020 BOOT1: 0x00400000 [ 4.00 MB ] BOOT2: 0x00400000 [ 4.00 MB ] RPMB: 0x00400000 [ 4.00 MB ] USER: 0xE67800000 [ 57.62 GB ] CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] RNID: B21D506D75998D8934235A5D9FE4D3D2 MEID: 53F5CB876B98191E4D62F9AAE2FF7136 DA: USB: HIGH-SPEED Boot done [1] Reading... Ok Reading... Scan memory... Found region: 30920 [12|30920|1124] Scan filesystem... Verify device config... Ok Loaders Ok Backup exist: C:\InfinityBox\CM2MT2\backup\MT6765__53F5CB876B98191E4D62F9AAE2FF7136 Process: RESET PROTECTION... Format Ok: RESET PROTECTION Process: USERDATA... Format Ok: USERDATA Process: USERDATA... Format Ok: USERDATA Done: 00:02:10 Reconnect Power/Cable now i try to flash phone but still same, even i try to restore beackup but still stuck on red logo then i try to unlock bootloader but now keep rebooting on logo. Please help |
