Old 06-08-2009, 14:46   #1 (permalink)
kisna's Avatar
Member: 770127
Thanks Meter: 37
Alcatel ot-s621 unlocking ????????
How to unlock alcatel ot-s621 without any risk . Anybody have tested solution plz share with me.
Thanx in advance
Old 06-08-2009, 16:00   #2 (permalink)
nadirghazi's Avatar
Member: 779665
Sonork: 100.1581784
Thanks Meter: 492
flash with sim free serbian file
if after flash set becomes white display then flash with t mobile firmware your phone will be with good display but locked so you have to wait for future update....
Old 06-09-2009, 06:46   #3 (permalink)
kisna's Avatar
Member: 770127
Thanks Meter: 37
where are infinity supporters.plz help me.i have Alcatel ot-s621( lobster virgin mobile) i will try all sim free files .but after flash phone dead or blue screen.or write same backup file phone will working fine.but locked . i need perfect unlocking solution. thanx in advance .
Old 06-09-2009, 08:49   #4 (permalink)
hasnain's Avatar
Member: 265626
Sonork: 100.1591486
Thanks Meter: 2,982
Follow these steps to unlock Alcatel S621x ( LOBSTER 621 )
1. Flash with file S621X-2AALAP1_XD54BM02_JRD25_06B_PCB01_GPRS_MT6225_S00.M AUI_06B_W07_28_SP1_V34_2008-07-22_En_Fr_Serbian_simfree.B0M.bin
after flash mobile will not power on.
2. than Format FFS (select complete )
still mobile will not power on
3. than click "repair security zone".
now mobile will power on and unlocked
The Following User Says Thank You to hasnain For This Useful Post:
Old 06-09-2009, 09:02   #5 (permalink)
ehsas_ghum's Avatar
Member: 171512
Thanks Meter: 1,034
FLASH WITH THIS FILE UR SET IS ALIVE WITH DISPLAY BUT LOCKED
use this file S621X-2ATBMK1_XD55DB40_JRD25_06B_PCB01_GPRS_MT6225_S00.M AUI_06B_W07_28_SP1_V34_2008-10-31_En_Srpski_Bg_Shqip_T-Mobile.B0M
Old 06-09-2009, 09:44   #6 (permalink)
Cheater -Don't Deal with him-
Member: 490708
Sonork: 100.1587135
Thanks Meter: 569
Not possible to unlock yet .if u,ve poler box then yes u ca unlock if not then wait for great infinity team update.
br
Old 08-07-2009, 08:52   #7 (permalink)
lucky121's Avatar
Member: 559810
Sonork: Not use
Thanks Meter: 176
i change the imei and i flash the set ewith given file and sim free dile but set dosnt working still lock
infinty dosnt working good
lucky121
Old 08-07-2009, 09:56   #8 (permalink)
Member: 130995
Thanks Meter: 35,227
@lucky121
Infinity-Box working good.
Waiting for honest answer: what MModule version you have used ?
Old 08-13-2009, 05:58   #9 (permalink)
lucky121's Avatar
Member: 559810
Sonork: Not use
Thanks Meter: 176
bro i m using MMoudle v2.79
but bro when infinity give the solution then the set will not expinsive
lucky121
Old 08-13-2009, 07:02   #10 (permalink)
amar181's Avatar
Member: 510122
Sonork: 100.1606547
Thanks Meter: 1,822
Yes brother you can unlock with flash file it 100% working infinity box.....................Try to flash last fimware if you use low firmware your fone goes blue display ... so use high fimware.........
Br.
amar181
Old 08-13-2009, 18:52   #11 (permalink)
Member: 130995
lucky121
Latest MModule version is 2.83
Why you do not use latest software ?
Old 09-18-2009, 09:11   #12 (permalink)
GsmGalant's Avatar
Member: 87568
Thanks Meter: 101
Succesfull flash and unlock without any modification OT-S621:
COM3 [VCP2] selected
module v2.83
Device: Alcatel-S621X, S621A
Checking data, wait...
Action: write NOR flash
"smart write" active
"format ffs" active
write: Firmware
S621X-2AALBG1-556_XD55BU40_JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_ 06B_W07_28_SP1_V34_2009-01-07_En_Serbian_Tr_Bg_Al_simfree.B0M.bin
skip: Customization/Language Pack
skip: Customization
skip: Eeprom/ffs
Boot ...
19200 fixed
Connecting, wait...
Initializing [6225:8A03:8A00]...
CPU: MT6225
chip: 0001:2603:A004
status: 01
boot packet size: 0400
Release Power button now !
Boot Done
Initialize ...
flash: 01227E22422200:18E59F00000000
flash: Amd AMD/Fujitsu std [D 0004x008000 00FEx020000 0004x008000] 32Mb
Initialize Done
Set baud ...
460800
Set baud Done
Initialize bootcode ...
Initialize bootcode Done
Check firmware integrity ...
detect device identification#1...
detection phase #1...
detect device identification#1 finished
identification#1 structure: 2nd [enhanced] generation
security area (code #1) is Ok
security area (code #1) backup saved: C:\Program Files\InfinityBox\MModule\backup_security\id.6876C D03.[JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_28_SP 1_V34.BIN_26DFC24B].rpl
identification#1 detection finished
device-id: 6876CD03
identification#1 protocol ver: 05
ver. sw 1: JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_28_SP 1_V34.BIN
ver. sw 2: MAUI.06B.W07.28.SP1.V34, B43D20D9
ffs offset/size: 01020000/00FE0000
ffs address assigned: 01020000
detect device identification#2...
detect device identification#2 finished
sim-lock status: enabled
Check firmware integrity Done
Check firmware content ...
Check firmware content Done
Backup required data ...
original imei: 35199002025416
Backup required data Done
Patch required data ...
Patch required data Done
Special operation ...
firmware patch sp-lock #1 is not required
firmware patch sp-lock #2 is not required
Special operation Done
Write ...
security area (code #1) check...
security area (code #1) calculation...
security area (code #1) fixed
file saved: C:\Program Files\InfinityBox\MModule\backup_security\Alcatel-S621X,S621A_JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_0 6B_W07_28_SP1_V34__system_log_6876CD03_26DFC24B_20 090918-005020.B0X.bin
Area: Firmware
Write: Firmware
security area (code #3, part #2) calculation...
customization: CD55BU40
done
Write: security area (code #3, part #2)
security area (code #3, part #2) calculation done
security area (code #3, part #1) calculation...
..................security area (code #3, part #1) detecting size...
security area (code #3, part #1) detecting parameters...
security area (code #3, part #1) encoding...
done
Write: security area (code #3, part #1)
security area (code #3, part #1) calculation done
Write Done
Finalization ...
formatting...
Finalization Done
file saved: C:\Program Files\InfinityBox\MModule\backup_security\Alcatel-S621X,S621A_JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_0 6B_W07_28_SP1_V34__system_log_6876CD03_26DFC24B_20 090918-010336.B0X.bin
Finished, time used: 834 sec
Remove/Install battery now !
File system has been modified !
It is need to press and HOLD phone "Power" button
during long time (up to 1 min) to make phone Powered-On !
The Following 3 Users Say Thank You to GsmGalant For This Useful Post:
Old 10-02-2009, 13:45   #13 (permalink)
virgin_phones's Avatar
Member: 359939
Sonork: none
Thanks Meter: 61
i have one phone i will try and post result.
Old 10-02-2009, 15:11   #14 (permalink)
Member: 130995
Hello,
It should be no problem, but anyway, we will be glad to see more test reports.
Old 10-08-2009, 15:31   #15 (permalink)
Member: 197538
Thanks Meter: 97
I tried with latest MM module V2.91 but still having same problem ,,, phone is from virgin Mobile and everytime i flash with sim free flash it turns on with blue screen ,,, I have to flash it back with Virgin flash file
ANY CLUE WHY IT IS GOING TO BLUE SCREEN AND SOLUTION PLEASE <<????
THANKS
MIKE
Alcatel OT-S621 unlock? Bmt_HR Infinity-Box 28 08-26-2014 08:48
Alcatel ot 103 Unlock probleme abote didier Infinity-Box 4 04-26-2010 17:04
Alcatel OT-S621 unlock Bmt_HR Easy-Unlocker 4 04-13-2009 05:05
Alcatel/Lobster OT-S621 Unlock MFC Basic Micro-Box Software Support (SAMSUNG, HUAWEI, etc...) 3 02-15-2009 12:04
How to Unlock the Alcatel OT-S621 N/East Unlocker Infinity-Box 12 02-13-2009 12:15
Page generated in 0.35829 seconds with 9 queries
