after unlock vodafone 226 fm key pad not work ? after unlock vodafone 226 fm key pad not work ? before ublock key works but now key pad not work ? need help to fix this problem plz here is unlock log COM3 [VCP0] selected module v1.60 Device: Vodafone-226FM Checking data, wait... Action: unlock unlock method-1 Boot ... Press and HOLD Power button now ! loading... middle part... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 115200 Set Baud Done Connecting ... flash: 0001:011A Connecting Done Check hardware ... sw version: 8 EDI_IF EDI_IF_040108_1352 040108_1352 Thhmm Dddmmmyyyy 0123 Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\Vodafone-226FM_eeprom-static_20090118-172628.B1E.bin loading data... data loaded reading eeprom-security... file saved: C:\Program Files\InfinityBox\Pana01\Vodafone-226FM_eeprom-security_20090118-172629.B1E.bin reading eeprom-complete... file saved: C:\Program Files\InfinityBox\Pana01\Vodafone-226FM_eeprom-complete_20090118-172634.B1E.bin reading additional data... file saved: C:\Program Files\InfinityBox\Pana01\Vodafone-226FM_lock-area_20090118-172640.B1E.bin backup critical area Done Check memory ... lock found Check memory Done Write ... Erasing: lock-area Writing: lock-area Write Done Finished, time used: 44 sec Remove/Install battery now ! 226 fm flash file not avalable in infinity support site ? |
Hello, it can not be true. Unlock procedure can not affect to phone keyboard functionality. Check phone without sim card after unlock. |
can u give me full flash file for vodafone 226 fm ? plzzz its not avlable in support side . [ |
Hello, Unlock procedure can not affect to phone keyboard functionality. Check phone without sim card after unlock. |
thats i know . but beforu key work fine ? with out sim & with sim 1 3 7 key work other key press any key * (star) symbol show ? need help |
Hello, I don't think it's software problem. Please, open phone and check it's hardware. |
sir when vodafone 226 fm flash file avalable in support side ? can any one post here vodafone 226 fm flash file ? |
I found flash file maby u can try.dont ask me how to use it. http://rapidshare.com/files/150583783/226_FM.rar |
[QUOTE=milandhal;4070615]after unlock vodafone 226 fm key pad not work ? before ublock key works but now key pad not work ? need help to fix this problem plz here is unlock log COM3 [VCP0] selected module v1.60 Device: Vodafone-226FM Checking data, wait... Action: unlock unlock method-1 Boot ... Press and HOLD Power button now ! loading... middle part... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 115200 Set Baud Done Connecting ... flash: 0001:011A Connecting Done Check hardware ... sw version: 8 EDI_IF EDI_IF_040108_1352 040108_1352 Thhmm Dddmmmyyyy 0123 Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\Vodafone-226FM_eeprom-static_20090118-172628.B1E.bin loading data... data loaded reading eeprom-security... file saved: C:\Program Files\InfinityBox\Pana01\Vodafone-226FM_eeprom-security_20090118-172629.B1E.bin reading eeprom-complete... file saved: C:\Program Files\InfinityBox\Pana01\Vodafone-226FM_eeprom-complete_20090118-172634.B1E.bin reading additional data... file saved: C:\Program Files\InfinityBox\Pana01\Vodafone-226FM_lock-area_20090118-172640.B1E.bin backup critical area Done Check memory ... lock found Check memory Done Write ... Erasing: lock-area Writing: lock-area Write Done Finished, time used: 44 sec Remove/Install battery now ! ITS 100% UNLOCK & NO KEYPAD PROBLEM COM3 [VCP2] selected module v1.68 Device: Vodafone-226FM Checking data, wait... Action: unlock unlock method-1 Boot ... Press and HOLD Power button now ! e-gold: 820010 loading... middle part... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 115200 Set Baud Done Connecting ... flash: 0001:011A Connecting Done Check hardware ... sw version: 8 EDI_IE 211207_1322 EDI_IE_211207_1322 Thhmm Dddmmmyyyy 0123 Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\Vodafone-226FM_eeprom-static_20091013-131018.B1E.bin loading data... data loaded reading eeprom-security... file saved: C:\Program Files\InfinityBox\Pana01\Vodafone-226FM_eeprom-security_20091013-131024.B1E.bin reading eeprom-complete... file saved: C:\Program Files\InfinityBox\Pana01\Vodafone-226FM_eeprom-complete_20091013-131031.B1E.bin reading additional data... file saved: C:\Program Files\InfinityBox\Pana01\Vodafone-226FM_lock-area_20091013-131041.B1E.bin backup critical area Done Check memory ... lock found lock type #1 found Check memory Done Write ... Erasing: lock-area Writing: lock-area Write Done Finished, time used: 62 sec Remove/Install battery now ! |
