03-31-2009, 07:21 | #1 (permalink) |
Freak Poster Join Date: Feb 2009 Location: I LOVE PAKISTAN Age: 38
Member: 977491 Status: Offline Thanks Meter: 82 | Again unlock J132 with INFINITY BOX COM6 [VCP1] selected module v1.30 Device: Sony-Ericsson-J132 "advanced chip detection" active Action: unlock Checking data, wait... Boot ... Phone should be Switched OFF ! Press Power button now ! rom version: 0502 Connecting... booting... finalizing... Boot done Check connection ... Check connection done Set baud ... 115200 Set baud done Check hardware ... flash: 2088C0FFFFFFFF:2088C000000000 flash: ST Intel std [def 007Fx010000 0008x002000] 8Mb Check hardware done Read data ... reading Sony-Ericsson-J132_eeprom_calibration-1... file saved: C:\Documents and Settings\Administrator\Desktop\Sony-Ericsson-J132_eeprom_calibration-1_20090331-034243.80E.bin Read data done Check data ... Check data done Write ... ..... flash: 2088C0FFFFFFFF:2088C000000000 Write: simlock Write done Finished, time used: 92 sec Remove/Install battery now ! |
The Following 2 Users Say Thank You to themobileshop For This Useful Post: |
03-31-2009, 15:04 | #2 (permalink) | |
Member: 130995 Status: Offline Thanks Meter: 35,228 | Quote:
Each test report with attached logs is very important for us so we can see how is Infinity-Box software works, what is phone hardware configuration (f.e. flash chip type) and what is possible problems (so we will be able to fix it) and successfully done work. | |
04-01-2009, 14:32 | #3 (permalink) |
Junior Member Join Date: May 2006
Member: 282355 Status: Offline Thanks Meter: 0 | unlock J132 Today I can't unlock sony j132 COM7 [VCP0] selected module v1.32 Device: Sony-Ericsson-J132 "advanced chip detection" active Action: read full flash Checking data, wait... Boot ... Phone should be Switched OFF ! Press Power button now ! rom version: 0502 Connecting... booting... finalizing... Boot fail error: operation failed Finished, time used: 50 sec Remove/Install battery now ! |
04-02-2009, 10:23 | #6 (permalink) |
Junior Member Join Date: Sep 2005 Location: poland tomaszów maz Age: 43
Member: 176377 Status: Offline Thanks Meter: 2 | j132 problem COM7 [VCP0] selected module v1.32 Device: Sony-Ericsson-J132 "advanced chip detection" active Action: read full flash Checking data, wait... Boot ... Phone should be Switched OFF ! Press Power button now ! rom version: 0502 Connecting... booting... finalizing... Boot fail error: operation failed Finished, time used: 50 sec Remove/Install battery now ! |
04-04-2009, 12:56 | #7 (permalink) | |
Cheater -Don't Deal with him- Join Date: Feb 2003 Location: gsmcity Age: 44
Member: 21296 Status: Offline Thanks Meter: 328 | No chance for me. I try everything that you suggest. New security and new security. I don't believe that your method works at all... COM1 [Serial0] selected module v1.32 Device: Sony-Ericsson-J132 "advanced chip detection" active Action: unlock Checking data, wait... Boot ... Phone should be Switched OFF ! Press Power button now ! rom version: 0502 Connecting... booting... finalizing... Boot fail error: operation failed Finished, time used: 14 sec Remove/Install battery now ! Quote:
04-05-2009, 13:23 | #8 (permalink) |
Member: 977491 Status: Offline Thanks Meter: 82 | here the pinout of this cabel. but i told that work only ipmart orignal cabel. THANKS for using the best device INFINITY BOX. [email protected] connector_usb_mini-5.gif === flash/unlock cable === keyboard top _____ /12345\ _______ 1: Gnd 3: box Rx/phone Tx (RJ45 pin-3) 4: box Tx/phone Rx (RJ45 pin-2) === USB cable === use ordinary Moto C350 usb cable |
04-05-2009, 13:27 | #9 (permalink) |
Member: 977491 Status: Offline Thanks Meter: 82 | i think any body could not undersatand this slution. bro,s i told already that in prosses when u reach on finilizing u must re-prees power button. cheeq this now dont forget say thanks to me. |
04-09-2009, 08:37 | #10 (permalink) |
Freak Poster Join Date: Apr 2008
Member: 745190 Status: Offline Sonork: salmanafzal Thanks Meter: 63 | Dear Help me i am realy worried about unlock of J132 its giving error any solution please describe booting... finalizing... Boot done Check connection ... Check connection done Set baud ... 115200 Set baud done Check hardware ... flash: 2088C0FFFFFFFF:2088C000000000 flash: ST Intel std [def 007Fx010000 0008x002000] 8Mb Check hardware done Read data ... reading Sony-Ericsson-J132_eeprom_calibration-1... warning: wrong data size at 0x067F0000, retry... warning: wrong cs at 0x067F0000, retry... warning: wrong data size at 0x067F0000, retry... warning: wrong data size at 0x067F0000, retry... warning: wrong cs at 0x067F0000, retry... warning: wrong cs at 0x067F0000, retry... warning: wrong cs at 0x067F0000, retry... warning: wrong cs at 0x067F0000, retry... warning: wrong cs at 0x067F0000, retry... error: too many retries during read operation Probably errors exist during flash read operation. Do you want to repeat read operation ? aborted by user error: operation failed Finished, time used: 80 sec Remove/Install battery now ! ==== log: [4/8/2009 6:29:33 PM] ==== COM3 [VCP0] selected module v1.30 Device: Sony-Ericsson-J132 "advanced chip detection" active Action: unlock Checking data, wait... Boot ... Phone should be Switched OFF ! Press Power button now ! Boot fail error: operation failed Finished, time used: 28 sec Remove/Install battery now ! |
04-09-2009, 18:41 | #11 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,228 | Hello, You need to double check your cable, charge battery and try again. In most cases this kind of communication problems is a result of bad cable. |
04-11-2009, 08:38 | #13 (permalink) |
No Life Poster Join Date: Jul 2004 Location: sri lanka
Member: 73323 Status: Offline Sonork: 1001664281 Thanks Meter: 68 | COM7 [VCP0] selected module v1.32 Device: Sony-Ericsson-J132 "advanced chip detection" active Action: unlock Checking data, wait... Boot ... Phone should be Switched OFF ! Press Power button now ! rom version: 0502 Connecting... booting... finalizing... Boot fail error: operation failed Finished, time used: 47 sec Remove/Install battery now ! |
07-09-2009, 05:28 | #15 (permalink) | |
No Life Poster Join Date: Jun 2005 Location: Sydney
Member: 153695 Status: Offline Sonork: srkhan Thanks Meter: 788 | Quote:
How to Unlock VODAFONE225 With Infinity Box??? | KUBAT1 | Infinity-Box | 2 | 01-19-2008 16:25 |
When we can unlock W375 with Infinity-Box? | stylius | Infinity-Box | 1 | 05-14-2007 09:03 |
plz is c117 unlock posible with infinity box | ARAB GSM | Infinity-Box | 2 | 10-20-2006 07:49 |
can i unlock p341 with Infinity-Box | elsokary | Infinity-Box | 2 | 08-27-2005 17:45 |
i Can't Unlock G51E with Infinity Box | flechazo | Infinity-Box | 1 | 07-09-2005 14:47 |
