06-18-2022, 17:17 | #1 (permalink) |
Freak Poster Join Date: Feb 2015
Member: 2349975 Status: Offline Thanks Meter: 51 | Alcatel 1054x sp code reader Operation : Check/Read Info [ v1.27 ] 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 11 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending boot ... Boot Sent , starting... Boot Ver : Spreadtrum Boot Block version 1.2 Boot Ok CPU ID : 6531 , FDLStat : 0100 [0] Flash DIE : 00C8 0060 0016 0000 [0] Flash VEN : GigaDevice , GD25LQ32 [0] Flash CAP : 00400000 Elapsed: 00:00:07 Reconnect Power/Cable! Operation : Read FullFlash [ v1.27 ] 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 11 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending boot ... Boot Sent , starting... Boot Ver : Spreadtrum Boot Block version 1.2 Boot Ok CPU ID : 6531 , FDLStat : 0100 [0] Flash DIE : 00C8 0060 0016 0000 [0] Flash VEN : GigaDevice , GD25LQ32 [0] Flash CAP : 00400000 Read Flash Content Read Ok , collect info Set FileInfo : Model Vendor : ALCATEL Model Name : 1054X ExtInfo Data : ENGLISH Saved to : C:\InfinityBox\CM2SPD\Read_out\SPD6531_00400000_GD 25LQ32_ENGLISH__ALCATEL-1054X.bin Done! Elapsed: 00:01:18 Reconnect Power/Cable! I have read and saved flash file but no provision to read sp unlock codes. Please help. |
06-18-2022, 20:13 | #2 (permalink) | |
No Life Poster Join Date: Apr 2005 Location: John Kemeny1926-1992 Age: 57
Member: 136220 Status: Offline Thanks Meter: 406 | Quote:
run cm2spd 1select seting spd6531 2 select user data/fornesic/other read user cood | |
06-19-2022, 19:45 | #3 (permalink) | |
Member: 148515 Status: Offline Thanks Meter: 19,534 | Quote:
You can try with code-by-imei service. Please see line 150 here https://infinity-box.com/price/ | |
06-21-2022, 15:01 | #4 (permalink) | |
Member: 2349975 Status: Offline Thanks Meter: 51 | Quote: I tried with my infinity user online account and was charged three credits and give a code (1543253582) that is not adequate: Unlock code by imei (#7) Router - Alcatel OT-1010X/OT-208X, Beeline A105/ 3582990733172121543253582COMPLETED I think it required a 16 digits code and not 10 as show above. Can I get a refund of my credit or give the 16 digits code to unlock the phone? | |
