Old 09-14-2009, 12:39   #1 (permalink)
Member: 939467
Thanks Meter: 50
alcatel 303x problem after flash
hello
i have flashed alcatel 303x with simfree firmware. after that i get no service?
what should i do?
i`m not confodent with eeprom files so i dont want to try that
please help infinity team
Old 09-14-2009, 12:52   #2 (permalink)
Member: 100041
Thanks Meter: 4
hello try with other firmware
Old 09-14-2009, 14:17   #3 (permalink)
Member: 939467
Thanks Meter: 50
i have finally repaired it
solution is:
flash it with
303X-2BALEU1-132_XI13AA20_JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI _08A_W08_36_SP1_V9_2009-02-19_En_Fr_Es_It_De_simfree.B0M.bin
after that make format: complete
The Following User Says Thank You to Akvarius_Sistem For This Useful Post:
Old 09-14-2009, 23:10   #4 (permalink)
Member: 130995
Thanks Meter: 35,227
Hello,
Also do not forget to use latest MModule software version, it's very important for Alcalel models !
Old 10-22-2009, 09:48   #5 (permalink)
Member: 939467
Thanks Meter: 50
sorry but still problem with this phone..
after some time when you change sim you cant power on the phone..
any solution to this infinity team ?
Old 10-22-2009, 10:21   #6 (permalink)
Member: 130995
Hello,
Did you tried to power-on phone without sim card ?
What is the results ?
Old 10-22-2009, 10:48   #7 (permalink)
Member: 939467
Thanks Meter: 50
yes there was a problem like that. it was turning on without simcard.i thought that its imei problem
i have made complete format again
after that imei repair
now it works good but i dont know for how long it will last..
Old 10-22-2009, 16:04   #8 (permalink)
Member: 130995
Hello,
If you will see the same problem after several days again, I think you need to check phone hardware due to it may be that hardware is partially damaged (f.e. bad soldering etc.).
Old 10-22-2009, 18:48   #9 (permalink)
Member: 939467
Thanks Meter: 50
i`ll check if it returns again but the phone was brand new when arrived and i hope that it will not return again..
Old 10-22-2009, 22:00   #10 (permalink)
Member: 921325
Thanks Meter: 20
Infinity is great and helped me a lot, but, this time, I unlocked the phone with easy (pinout from polarbox) because I keep out of reflash.
Old 11-04-2009, 12:50   #11 (permalink)
Member: 939467
Thanks Meter: 50
problem again with alcatel 303x
phone works great some time and after a while phone relocks again and it stays locked..
can we fix this phone permanently?
Old 11-05-2009, 01:17   #12 (permalink)
Member: 130995
Hello,
You can try to open phone and check it's hardware, f.e. rehot/reball flash chip.
Old 11-16-2009, 22:53   #13 (permalink)
Member: 130995
Hello,
Here is direct unlock solution for Alcatel models.
It's beta solution, need to test it and see what will be the results.
Please, try to unlock phone with this new software:
http://www.infinity-box.com/download...dule_v2.94.rar
It is no need to flash phone, just use "SP-Unlock" button from software "Service" page.
Waiting for your results.
Old 12-11-2009, 14:07   #14 (permalink)
Member: 939467
Thanks Meter: 50
i`ll try to flash it with new flash files on support page
after that i`ll make direct unlock
i hope it will be fixed
Old 12-11-2009, 14:41   #15 (permalink)
Member: 939467
Thanks Meter: 50
i have flashed it and made FFS format with
303X-2ARGTE1-169_XI16CD03_JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI _08A_W08_36_SP1_V9_2009-05-14_En_Fr_Es_It_Pt.B0M.bin
after that i have made Sp unlock
now only ALCATEL appears on the screen and the phone shuts down?
any solution?
Problem after flash alcatel 203a [ANSWERED] hmontoya PolarBox 3 1 11-17-2009 19:05
alcatel 303x dead after unlock foufou34 Infinity-Box 2 09-19-2009 17:58
help problem after flash alcatel c701a movistar mexico ramscell Infinity-Box 3 12-02-2008 18:37
alcatel bg31g dead after flashing skorn BF, BG, TH, BHx Series 5 07-05-2005 07:48
Alcatel BE1 16F after flashing says "CHECK SIM CARD" spvaka Alcatel & TCL Old Models 4 07-08-2004 14:23
Page generated in 0.23144 seconds with 10 queries
