Old 10-10-2011, 09:45   #1 (permalink)
Malik Irfan85's Avatar
Member: 1484062
Sonork: 1610135
Thanks Meter: 218
Alcatel 355x After Unlock dead?
i have Alcatel 355x.
which matter unlock after dead.
read file this set . . ..
Alcatel-355X,355A__system_log_E5765BC2_5DE28CEF_20111010-122232.B0X.bin - 4shared.com - online file sharing and storage - download
plz solved this matter plz . . . . .
thanx in abvance . . . .
Old 10-10-2011, 12:09   #2 (permalink)
Member: 1484062
Sonork: 1610135
Thanks Meter: 218
plz infinity team help m?
where is yellow box???????????
Old 10-10-2011, 12:09   #3 (permalink)
Member: 1484062
Sonork: 1610135
Thanks Meter: 218
Old 10-10-2011, 13:23   #4 (permalink)
shamshad quresh's Avatar
Member: 898041
Sonork: 100.1593459
Thanks Meter: 549
brother send unlocking log here then we tell solution.
Old 10-11-2011, 10:38   #5 (permalink)
Member: 1670509
post your complete logs bro.
Old 10-11-2011, 11:03   #6 (permalink)
Member: 1670509
we have same prob. bro.,
but i fixed them hirs. my logs
COM17 [VCP0] selected
module v4.01
Device: Alcatel-355X, 355A
Checking data, wait...
Action: write flash
"smart write" active
write: Firmware
355X-2APMPT1-46A_XI46CM60_JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI _08A_W08_36_SP1_V34_2010-11-01_En_Fr_Es_De_Pt.B0M.bin
skip: Customization/Language Pack
skip: Customization
skip: Eeprom/ffs
====> Boot ...
19200 fixed
Connecting, wait...
Initializing [6223:8A05:8A00]...
CPU: MT6223
high speed boot On
chip: 0011:8CA6:A00C
status: 01
boot packet size: 0400
Release Power button now !
Boot Done
====> Initialize ...
flash: 01227E22202200:FFFFFF00000000
flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb
otp offset: 00000000
Initialize Done
====> Set baud ...
230400
Set baud Done
====> Initialize bootcode ...
Initialize bootcode Done
====> Check firmware integrity ...
usb bootloader detect...
usb bootloader detect (phase #2)...
usb bootloader (chip) is absent
searching rom info...
search rom info finished
warning: rom info information not found, possible reasons:
- old firmware type w/o rom info information
- empty (completely or partially erased) flash chip
- damaged firmware
- damaged hardware (bad soldered or damaged flash chip)
> if phone works fine just ignore this warning <
ffs/eeprom address can not be detected, value from database assigned: 00C00000/00400000
sec info (detailed) detection...
searching sec info#1...
search sec info#1 finished
Check firmware integrity Done
====> Check firmware content ...
Check firmware content Done
====> Backup required data ...
original imei: 35392304225781
Backup required data Done
====> Patch required data ...
Patch required data Done
====> Special operation ...
Special operation Done
====> Write ...
- damaged firmware
sec info (fast) detection...
usb bootloader (file) is absent
startup code area #1 check...
startup code area #1 calculation...
startup code area #1 fixed
file saved: c:\InfinityBox\MModule\backup_security\Alcatel-355X,355A__system_log_20111011-081127.B0X.bin
Area: Firmware
Write: Firmware
searching sec info#2...
search sec info#2 finished
security area (sec info, cust) calculation...
identification header detected
relocation table detected
name table[00] #7000000 detected
customization: CI46CM60
customization name adjusted
customization detected: CI46CM60
flash: 01227E22202200:2BEA0000000000
Write: security area (sec info, cust)
security area (sec info, cust) calculation done
security area (sec info, hash) calculation...
..................security area (sec info, hash) detecting size...
security area (sec info, hash) detecting parameters...
security area (sec info, hash) encoding...
done
Write: security area (sec info, hash)
security area (sec info, hash) calculation done
Write Done
====> Finalization ...
Finalization Done
file saved: c:\InfinityBox\MModule\backup_security\Alcatel-355X,355A__system_log_20111011-082833.B0X.bin
Finished, time used: 17 min 33 sec
Remove/Install battery now !
Old 10-11-2011, 12:08   #7 (permalink)
Member: 898041
Sonork: 100.1593459
Thanks Meter: 549
use old exe and unlock again your problem will b solved. bro
Unlocking 5190 Ryu Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 23 01-07-2018 17:14
$50 Reward for unlocking my 6150!!! TheDon Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 5 03-23-2015 14:21
FAQ about unlock n0kia man0n Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 6 11-29-2010 19:06
Page generated in 0.18980 seconds with 10 queries
