09-05-2015, 09:55 | #1 (permalink) |
No Life Poster Join Date: Sep 2006 Location: Allah is Greatest
Member: 358694 Status: Offline Sonork: 100.1597323 Thanks Meter: 994 | Alcatel 4007x Stuck 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 7 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6575 BB_CPU_HW : CB00 BB_CPU_SW : 8A00 BB_CPU_SB : E201 BB_CPU_NM : [MediaTek] MT6575|MT6577_S00 Processing BROM stage i2c Init : 00000000 SpeedSet : 0000 VChrgSet : 0x28 , BatStat : 0x02 WD Disable stat : 0x0000 BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Stat : v3.2 on BBID : 0x84 DA Sent. Configure setting now ... DA started successuflly NAND FlashIC initialized [NAND] : FLASH_VEN : 0x0082 , [SAMSUNG] KF98G16Q4X [NAND] : FLASH_DIE : 002C 00BC 0090 0066 0054 0000 0000 [NAND] : FLASH_LEN : 0x20000000 INT RAM : 0x00020000 EXT RAM : 0x10000000 BOOT TYPE : NAND_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Done! Elapsed: 00:00:05 Reconnect Power/Cable! Format Operation : Format FileSystem [ v1.26 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 7 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6575 BB_CPU_HW : CB00 BB_CPU_SW : 8A00 BB_CPU_SB : E201 BB_CPU_NM : [MediaTek] MT6575|MT6577_S00 Processing BROM stage i2c Init : 00000000 SpeedSet : 0000 VChrgSet : 0x28 , BatStat : 0x02 WD Disable stat : 0x0000 BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Stat : v3.2 on BBID : 0x84 DA Sent. Configure setting now ... DA started successuflly NAND FlashIC initialized [NAND] : FLASH_VEN : 0x0082 , [SAMSUNG] KF98G16Q4X [NAND] : FLASH_DIE : 002C 00BC 0090 0066 0054 0000 0000 [NAND] : FLASH_LEN : 0x20000000 INT RAM : 0x00020000 EXT RAM : 0x10000000 BOOT TYPE : NAND_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Format : Cache and UserData (Full Factory Reset) Format CACHE block Format block Ok! Format UDA block Format block Ok! Done! Elapsed: 00:00:13 Reconnect Power/Cable! Still same.... then i flash it with this file using SP Flash Tool 4007x-2AVDZA1 |
09-05-2015, 22:01 | #2 (permalink) | |
Member: 358694 Status: Offline Sonork: 100.1597323 Thanks Meter: 994 | Quote:
