02-06-2016, 10:10 | #1 (permalink) |
No Life Poster Join Date: May 2011 Location: KPK Mardan Age: 36
Member: 1582572 Status: Offline Sonork: 100.1609641 Thanks Meter: 573 | alcatel 4032 show this mess the slot has been permanently locked Finish at : [2/6/2016 / 1:50:40 PM] Start at : [2/6/2016 / 1:56:39 PM] Operation : SP Unlock [ v1.40 ] Mode : Direct Unlock 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 17 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v5.1540.01.01 NAND_ID : 00000000000000000000000000000000 eMMC_ID : FE014E50314A3934481276E83C72516D DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 00FE , OEM : 014E [eMMC] : FLASH_INF : [MICRON] , H49J1 [eMMC] : FLASH_CID : FE014E50314A3934481276E83C72516D [eMMC] : FLASH_EXT : 0x00100000 , 0x00100000 , 0x00100000 [eMMC] : FLASH_LEN : 0x00000000E9800000 [eMMC] : FLASH_UCP : 3736 MiB INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Lock Status : Locked! Unlocking ... Unlock done! Done! Elapsed: 00:00:43 Reconnect Power/Cable! Finish at : [2/6/2016 / 1:57:23 PM] Start at : [2/6/2016 / 2:01:09 PM] Operation : SP Unlock [ v1.40 ] Mode : Direct Unlock 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 17 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v5.1540.01.01 NAND_ID : 00000000000000000000000000000000 eMMC_ID : FE014E50314A3934481276E83C72516D DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 00FE , OEM : 014E [eMMC] : FLASH_INF : [MICRON] , H49J1 [eMMC] : FLASH_CID : FE014E50314A3934481276E83C72516D [eMMC] : FLASH_EXT : 0x00100000 , 0x00100000 , 0x00100000 [eMMC] : FLASH_LEN : 0x00000000E9800000 [eMMC] : FLASH_UCP : 3736 MiB INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Lock Status : Locked! Unlocking ... Unlock done! Done! |
02-06-2016, 10:33 | #2 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Hello, Make full Factory Reset. Run phone. Check it. Off it after. Do unlock once again. Power on. Check. Also interest to see eMMC R/O state. |
02-06-2016, 14:01 | #3 (permalink) |
Member: 1582572 Status: Offline Sonork: 100.1609641 Thanks Meter: 573 | Card found : S/N : 533B1BFE , v0129 Chinese Miracle II [MTK module] v 1.40 Operation : Format FileSystem [ v1.40 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 17 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v5.1540.01.01 NAND_ID : 00000000000000000000000000000000 eMMC_ID : FE014E50314A3934481276E83C72516D DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 00FE , OEM : 014E [eMMC] : FLASH_INF : [MICRON] , H49J1 [eMMC] : FLASH_CID : FE014E50314A3934481276E83C72516D [eMMC] : FLASH_EXT : 0x00100000 , 0x00100000 , 0x00100000 [eMMC] : FLASH_LEN : 0x00000000E9800000 [eMMC] : FLASH_UCP : 3736 MiB INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Format prepare error : PMT info is wrong!!! Structure NOT detected! Make "Identify" first! Done! Elapsed: 00:00:22 Reconnect Power/Cable! Operation : Check / Read Info [ v1.40 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 17 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v5.1540.01.01 NAND_ID : 00000000000000000000000000000000 eMMC_ID : FE014E50314A3934481276E83C72516D DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 00FE , OEM : 014E [eMMC] : FLASH_INF : [MICRON] , H49J1 [eMMC] : FLASH_CID : FE014E50314A3934481276E83C72516D [eMMC] : FLASH_EXT : 0x00100000 , 0x00100000 , 0x00100000 [eMMC] : FLASH_LEN : 0x00000000E9800000 [eMMC] : FLASH_UCP : 3736 MiB INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! EXTRA : LCD [0] : ili9806_6572_dsi_vdo LCD [1] : ili9806_6572_dsi_vdo_txd LCD Res : 800x480 TOUCH [0] : ft6306 TOUCH [1] : msg2138a CAM [0] : hi257_yuv CAM [1] : sp2519_yuv CAM [2] : hi351_yuv CAM [3] : hi253_yuv CAM [4] : gc0329_yuv MODEM : jrdhz72_we_jb3_hspa LOCALE : en_US es_ES zh_CN zh_TW ru_RU pt_BR fr_FR de_DE tr_TR it_IT in_ID ms_MY vi_VN ar_EG th_TH pt_PT nl_NL el_GR hu_HU tl_PH ro_RO cs_CZ iw_IL my_MM km_KH ko_KR hdpi Done! Elapsed: 00:00:11 Reconnect Power/Cable! Operation : Format FileSystem [ v1.40 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 17 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v5.1540.01.01 NAND_ID : 00000000000000000000000000000000 eMMC_ID : FE014E50314A3934481276E83C72516D DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 00FE , OEM : 014E [eMMC] : FLASH_INF : [MICRON] , H49J1 [eMMC] : FLASH_CID : FE014E50314A3934481276E83C72516D [eMMC] : FLASH_EXT : 0x00100000 , 0x00100000 , 0x00100000 [eMMC] : FLASH_LEN : 0x00000000E9800000 [eMMC] : FLASH_UCP : 3736 MiB INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Format prepare error : PMT info is wrong!!! Structure NOT detected! Make "Identify" first! Done! Elapsed: 00:00:09 Reconnect Power/Cable! |
