02-27-2017, 15:13 | #1 (permalink) |
No Life Poster Join Date: Mar 2007 Location: ALGERIA Age: 17
Member: 467636 Status: Offline Sonork: Double Kanon Thanks Meter: 2,654 | Alcatel 5054D Read Full Flash File Code: Operation : Read Flash [ v1.09 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 210 [MSM8909] ID_BLOCK_S : 034373A6 ID_BLOCK_I : 009600E1 ID_BLOCK_L : 23C5BF47F67C69644338D8C50259D9F1 ID_BLOCK_L : 1E75DB7267EE50D5E8C7884143A2BC9F Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8909 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000001D2000000 [ eMMC 8 GiB ] ExtInfo : 0x0000C000/00100000/00001000/00001000 Boot Ok! Brand : TCL ProdName : 5054D ProdModel : 5054D Device : Pop355 AndroidVer: 5.1.1 Manufact. : TCL QLMxCPU : MSM8909 DevInfo : MSM8909__TCL__TCL__ANDR_v5.1.1__5054D__Pop355__5054D Reading Flash Content ... [Read Ok] : gpt_main0.bin [Read Ok] : NON-HLOS.bin [Read Ok] : nvram.img [Read Ok] : perso.img [Read Ok] : sbl1.mbn [Read Ok] : rpm.mbn [Read Ok] : tz.mbn [Read Ok] : secro.img [Read Ok] : fs_gc.img [Read Ok] : sec.dat [Read Ok] : emmc_appsboot.mbn [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : system.img [Read Ok] : persist.img [Read Ok] : splash.img [Read Ok] : tctperso.img [Read Ok] : cache.img [Read Ok] : misc.img [Read Ok] : userdata.img [Read Ok] : gpt_backup0.bin Android Info saved! Read finished! Configuration : MSM8909 / eMMC Firmware Size : 1786 MiB Done! Elapsed: 00:03:08 Code: Operation : Reset Settings [ v1.09 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 210 [MSM8909] ID_BLOCK_S : 034373A6 ID_BLOCK_I : 009600E1 ID_BLOCK_L : 23C5BF47F67C69644338D8C50259D9F1 ID_BLOCK_L : 1E75DB7267EE50D5E8C7884143A2BC9F Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8909 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000001D2000000 [ eMMC 8 GiB ] ExtInfo : 0x0000C000/00100000/00001000/00001000 Boot Ok! Format USER ... Format CACHE ... Format Ok! Remove FRP ( Google Reset Protection ) FRP removed! Done! Elapsed: 00:00:26 Reconnect Power/Cable! |
The Following 3 Users Say Thank You to MDK23 For This Useful Post: |
07-08-2017, 15:22 | #3 (permalink) |
Junior Member Join Date: May 2010
Member: 1308581 Status: Offline Thanks Meter: 0 | Hi MDK23 If possible, can you upload your firmware or provide a file like this one msm8909__tcl__tcl__andr_v.5.1.1__5054d that I tried on google? I found the file but for 5054X Thanks |
07-09-2017, 20:45 | #4 (permalink) |
Member: 163 Status: Offline Thanks Meter: 7,785 | Exclusive for Infinity BOX Users - ot-5054D_Unbrick_FULL_by_bRkA File is QFIL compatible, but you can always use CM2 Memory Tool to write desired partitions, like system.img, userdata.img, cache.img, etc,. etc. (Most problems on QCom models come from corrupted system or userdata partitions). b.r. Alex
__________________ Always press THANKS button if my post was helpful! Please DO NOT send me PM's for help, You can ask for help on forum Do not post THANKS posts - use thanks button ! ALWAYS use SEARCH button before posting! |
The Following 7 Users Say Thank You to Brka For This Useful Post: |
03-08-2018, 10:31 | #5 (permalink) | |
No Life Poster Join Date: Feb 2013
Member: 1886712 Status: Offline Thanks Meter: 53 | Quote:
and now phone not ask any driver i need solution how to alive my phone | |
03-09-2018, 06:28 | #7 (permalink) | |
Member: 163 Status: Offline Thanks Meter: 7,785 | Quote:
check cable, try other usb port, other pc, other OS. p.s. It's not "my flash file", it's FACTORY STOCK one. If factory is wrong, then I am, too. b.r. Alex
__________________ Always press THANKS button if my post was helpful! Please DO NOT send me PM's for help, You can ask for help on forum Do not post THANKS posts - use thanks button ! ALWAYS use SEARCH button before posting! | |
The Following 2 Users Say Thank You to Brka For This Useful Post: |
03-10-2018, 11:14 | #8 (permalink) | |
if you have any other solution like boot repair etc please tell me. | |
03-10-2018, 23:21 | #9 (permalink) | |
with both volume keys pressed + insert usb cable, or with EDL cable. b.r. Alex
The Following User Says Thank You to Brka For This Useful Post: |
04-03-2018, 20:23 | #10 (permalink) | |
No Life Poster Join Date: Dec 2006 Location: GSM WORLD
Member: 412843 Status: Offline Sonork: 100.1604902 Thanks Meter: 497 | Quote:
Thanks Anticipation | |
04-04-2018, 15:53 | #11 (permalink) | ||
No Connectivity After Flash Tried All Keys Even With EDL Cable Some One Knows EDL Pinouts ? Will Be Grateful Thanks Anticipation | ||
04-04-2018, 17:25 | #12 (permalink) |
Member: 163 Status: Offline Thanks Meter: 7,785 | Try standard edl cable (gnd+green wire shorted), insert cable, wait 2-3 seconds, remove shorting. B.r Alex
05-08-2018, 09:32 | #13 (permalink) |
Member: 1886712 Status: Offline Thanks Meter: 53 | hi my alcatel 5054d after flash dead Dead After Flashing With Your File No Connectivity After Flash Tried All Keys Even With EDL Cable Some One Knows EDL Pinouts ? Will Be Grateful Thanks |
06-15-2018, 20:00 | #15 (permalink) | |
Freak Poster Join Date: Dec 2014 Location: amateur team
Member: 2303526 Status: Offline Thanks Meter: 24 | Quote:
Can you re-upload this file sir ? file deleted ! thank you. | |
