12-03-2015, 20:53 | #1 (permalink) |
Freak Poster Join Date: Aug 2014
Member: 2235175 Status: Offline Thanks Meter: 25 | Alcatel 7041D Preloader Status : Not active (Erased) 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 16 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6582 BB_CPU_HW : CB00 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6582_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0x05 BLVersion : 0xFE Preloader Status : Not active (Erased) Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 11010030303447453001DF5C82773285 DA Stat : v4.2 on BBID : 0x87 DRAM not initialized , configure DRAM Settings DRAM EmiReq Ok , 0x00BC Error : DA init Failed! Error code : 0x5 LErr : 00000BBF Boot Error! Operation Failed Elapsed: 00:00:19 Reconnect Power/Cable! any help about this case pleas |
12-04-2015, 09:07 | #3 (permalink) |
Member: 2235175 Status: Offline Thanks Meter: 25 | Alcatel 7041D Preloader Status : Not active (Erased) Not accept flash Give same error Error : DA init Failed! Error code : 0x5 LErr : 00000BBF Found many firmware could you provide me link for a goud firmware pleas? Sent from my iPhone using Tapatalk Last edited by iPhon-neo; 12-04-2015 at 09:13. |
12-04-2015, 09:15 | #5 (permalink) |
Member: 2235175 Status: Offline Thanks Meter: 25 | Alcatel 7041D Preloader Status : Not active (Erased) I' m out now of my shop when i will be there i post flashing logs. but i already tried it and give me the error above ! Possible problem with firmware, if know pleas good firmware post here, thank you Sent from my iPhone using Tapatalk |
12-04-2015, 14:59 | #10 (permalink) |
No Life Poster Join Date: Mar 2007 Location: Factory Reset Protection (FRP) Age: 13
Member: 459784 Status: Offline Sonork: +91-9179403087 Thanks Meter: 1,543 | Hello- Here Is Firmware Flash It Download 4 Part And Post Result Dev-Host - Alcatel Pop C7 7040D.part1.rar - The Ultimate Free File Hosting / File Sharing Service Dev-Host - Alcatel Pop C7 7040D.part2.rar - The Ultimate Free File Hosting / File Sharing Service Dev-Host - Alcatel Pop C7 7040D.part3.rar - The Ultimate Free File Hosting / File Sharing Service Dev-Host - Alcatel Pop C7 7040D.part4.rar - The Ultimate Free File Hosting / File Sharing Service |
The Following User Says Thank You to pradeep_kus For This Useful Post: |
12-04-2015, 17:01 | #11 (permalink) |
Member: 2235175 Status: Offline Thanks Meter: 25 | Quote: Scatter wrong Sent from my iPhone using Tapatalk |
12-04-2015, 17:30 | #12 (permalink) | |
Member: 2235175 Status: Offline Thanks Meter: 25 | Alcatel 7041D Preloader Status : Not active (Erased) phone revived by this Firmware HERE. Quote:
