02-04-2019, 16:46 | #1 (permalink) |
Freak Poster Join Date: Feb 2006 Location: BiH Age: 37
Member: 236764 Status: Offline Thanks Meter: 12 | Alcatel 8068 frp how to remove frp on this device (Tablet) Android 8.1.0 ! Always this error : Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 367 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x01000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : SIGNED with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v3.3001.00.00 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x9C NAND Flash : NOT INSTALLED eMMC Flash : 450100444734303038011E7D5204359B Initialize Memory ... [DA_ERROR] : DRAM Configure failed! ErroCode : 0x2003 EMICFG_NOT_FOUND TRY NOT HOLD VOLUME(+/-) KEYS ON CONNECT! Boot Error! Operation Failed Elapsed: 00:00:08 Reconnect Power/Cable! |
02-05-2019, 09:14 | #3 (permalink) |
Member: 236764 Status: Offline Thanks Meter: 12 | Infinity-Box Chinese Miracle MediaTek Service Module [ MTK ] v2.00 r4 Operation : Identify [ v2.00 r4 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM367) MODE : BOOTROM PORT : 367 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6580 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : LEGACY MTK Info : Device is not supported yet! Reconnect Power/Cable! |
02-06-2019, 05:22 | #8 (permalink) | |
Product Supporter Join Date: Jun 2014 Location: India
Member: 2211790 Status: Offline Thanks Meter: 5,118 | Quote:
choose manually by select scatter file in flash tab and repeat operation or use mtk 2.04 and try with different EMI select 1/2/3.. will be ok | |
