alcatel 9009g and tcl 8082 not booted plz i need da for this tablet alcatel 9009g alcatel tcl 8082 Operation : Identify [ v2.12 ] Mode : FLASH 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port_V1632 (COM23) MODE : BOOTROM PORT : 23 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM Error : Fail to init protocol! >>> Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation! Reconnect Power/Cable! |
Recharge battery (on external power source), re-connect it to device, try identify again. post log for each device. p.s. Both are Mediatek MT8321, should identify till some point. b.r. Alex |
I think problem in DA file , also there's no da file available. |
Try to delay your desired operation by 3 to 4sec. Meaning of its frp remove , plug phon first then after 3sec hit reset tab. It worked for me Sent from my SM-G570F using Tapatalk |
If you need Preloader mode choise only Preloader mode only in cm2mt2 and will not detect BROM if mobile boot by default in BR |
No DA file available right now!! |
I've selected Perloader only and i have tried both DA files, Same problem too. I have used MT2 V2.17 latest. |
