07-14-2020, 16:13 | #1 (permalink) |
No Life Poster Join Date: Oct 2007 Location: EGYPT
Member: 601566 Status: Offline Sonork: 100.1637134 Thanks Meter: 551 | alcatel 9009g and tcl 8082 not booted alcatel 9009g alcatel tcl 8082 Operation : Identify [ v2.12 ] Mode : FLASH 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port_V1632 (COM23) MODE : BOOTROM PORT : 23 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM Error : Fail to init protocol! >>> Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation! Reconnect Power/Cable! |
07-17-2020, 01:14 | #2 (permalink) |
Member: 163 Status: Offline Thanks Meter: 7,783 | Recharge battery (on external power source), re-connect it to device, try identify again. post log for each device. p.s. Both are Mediatek MT8321, should identify till some point. b.r. Alex
__________________ Always press THANKS button if my post was helpful! Please DO NOT send me PM's for help, You can ask for help on forum Do not post THANKS posts - use thanks button ! ALWAYS use SEARCH button before posting! |
01-19-2021, 20:04 | #3 (permalink) | |
No Life Poster Join Date: Jul 2001 Age: 42
Member: 5184 Status: Offline Thanks Meter: 246 | Quote:
Code: PTFN : MTK USB Port (COM158) MODE : BOOTROM PORT : 158 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6580 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : LEGACY MTK BROM : SecLevel : 0x00000007 BROM : SecMode : SBC+SLA+SDA BROM : BOOTROM MODE : 0_base : BASE_v1712 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6580 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : 0x00000001 : DA SEND ERROR! ERROR : BROM : DL MODE ERROR INFO : BROM Level : SLA AUTH or AUTH required! Error : Fail to init protocol! >>> Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation! Reconnect Power/Cable! I think problem in DA file , also there's no da file available. | |
01-19-2021, 21:12 | #4 (permalink) | |
Freak Poster Join Date: Apr 2016 Location: Zimbabwe,chitown Age: 36
Member: 2559678 Status: Offline Thanks Meter: 29 | Quote:
Try to delay your desired operation by 3 to 4sec. Meaning of its frp remove , plug phon first then after 3sec hit reset tab. It worked for me Sent from my SM-G570F using Tapatalk | |
01-20-2021, 02:31 | #5 (permalink) | |
No Life Poster Join Date: Feb 2006 Location: In my LAB
Member: 231728 Status: Offline Thanks Meter: 2,103 | Quote:
If you need Preloader mode choise only Preloader mode only in cm2mt2 and will not detect BROM if mobile boot by default in BR | |
01-20-2021, 06:57 | #6 (permalink) | |
01-20-2021, 09:12 | #7 (permalink) | |
