Alcatel C701, read error!!! COM7 [VCP0] selected module v4.00 Device: Alcatel-105X, 105A Checking data, wait... advanced flash detection enabled Action: read/check information ====> Boot ... Press and HOLD Power button now ! baud autodetection active 9600 autodetect Connecting, wait... error: can't detect CPU id Release Power button now ! in case of initial connection problem: on/off "Boot baudrate autoselect" Boot Fail Finished, time used: 3 sec Remove/Install battery now ! |
PLUS SELCTE ALCATEL C701 ;) |
jejejej, i try to both box divice, the Alcatel C701 and 105A. why happen this, i try to read with RJ45.??? And the cable is build like infinity pinout. What is wrong? |
Did you connected all 3 wires from box to phone ? (rx/tx/gnd) |
Ok, but the MTK phone can be read by RJ45 cable? i build this cable and no read. is posible?? read with cable, not welded lines??? |
You can read Alcatel MTK via bottom connector & RJ45. Here is an instruction how to get cable/pinout information: 1. be sure that you have downloaded and installed latest Infinity-Box Pinouts update: Infinity-Box - News - 22-08-2011 - Resellers database updated 2. run Infinity-Box Shell 3. select required model 4. see detailed information about cable/pinout (Rx/Tx/Gnd pins and other information) Here is an example of information given by Infinity-Box Shell. It's just an example for Alcatel, if you have another model you must select your model ! http://www.infinity-box.com/download...shell_v126.jpg RJ45 connector pinout: http://www.infinity-box.com/download...pins_small.jpg Here is an information how to build your own cable: FAQ: Frequently Asked Questions, cables/pinouts |
