04-18-2010, 21:41 | #1 (permalink) |
No Life Poster Join Date: Jan 2006 Location: ARG - AZUL
Member: 226845 Status: Offline Thanks Meter: 78 | ALCATEL C820a imei repair Now phone shows on screen: "insert correct sim", with any sim of any carrier. Phone was previously flashed from official support service. I did it by 3 ways. First, I unlocked it and then repaired imei, problem not solved Second, unlocked, repaired imei, and unlocked again....problem persisted Third, repaired imei then unlocked...same problem. I observed that Infinity soft could not resolve a step at the middle of proccess (highlighted in red). I mean, I know that flashing it again I can solve the problem of this message, but I want to repair its imei too! Could you solve this problem, it´s really necesary please. Here´s the log: COM4 [VCP0] selected module v3.34 Device: Alcatel-C820A Checking data, wait... advanced flash detection enabled Action: "repair imei" new imei: 012045001690032 ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6226:8A03:8A02]... CPU: MT6226 chip: 0031:345E:A000 status: 01 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 01227E223C2200:2AEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 007Ex040000 0004x010000] 32Mb otp offset: 00000000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: 2nd [enhanced] generation TCL-ID is present startup code area #1 is Ok startup code area #1 backup saved: C:\Archivos de programa\InfinityBox\MModule\backup_security\id.85 0B9A98.[JRD26_06A_PCB01_GPRS_MT6226_S02.MAUI_06A_W06_28_MP _V45.BIN_72F55A1A].rpl rom info detection finished TCL-ID detection... TCL-ID detection done device-id: 850B9A98 rom info ver: 05 sw version: JRD26_06A_PCB01_GPRS_MT6226_S02.MAUI_06A_W06_28_MP _V45.BIN project-id: MAUI.06A.W06.28.MP.V45, 1A5AF572 code offset: 00000000 ffs offset/size [01]: 01000000/01000000 TCL-ID identification version: 166 provider: C820A-2AAVAR1 customization: CB17NQ51 customization: XB17NQ51 TCL-ID identification done rom info structure: 2nd [enhanced] generation TCL-ID is present ffs/eeprom address assigned: 01000000 startup code area #1 check... startup code area #1 fixed sec info (detailed) detection... searching sec info#1... search sec info#1 finished sim-lock status: disabled product id: JRD_Communication_Inc_SH_Branch area1 is valid area2 is valid area3 is valid area4 is valid searching sec info#2... . search sec info#2 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... original imei: 01104500169008 flash: 01227E223C2200:2AEA0000000000 Backup required data Done ====> Patch required data ... ................................ pass #1 firmware remap[01]: 08000000 ................................ Patch required data Done ====> Special operation ... Special operation Done ====> Write ... flash: 01227E223C2200:2AEA0000000000 flash: 01227E223C2200:2AEA0000000000 Write: imei sec info (fast) detection... searching sec info#1... search sec info#1 finished searching sec info#2... . search sec info#2 finished security area (sec info, cust) calculation... identification header detected relocation table detected name table[00] #7000000 detected customization: CB17NQ51 customization name adjusted customization: CB17NQ51 customization name adjusted customization detected: CB17NQ51 customization: CB17NQ51 customization: XB17NQ51 error: can't calculate security area (sec info, cust), existing data will be used Check support area for updates ! security area (sec info, cust) calculation done security area (sec info, hash) calculation... ..................security area (sec info, hash) detecting size... security area (sec info, hash) detecting parameters... security area (sec info, hash) encoding... done flash: 01227E223C2200:2AEA0000000000 flash: 01227E223C2200:2AEA0000000000 Write: security area (sec info, hash) security area (sec info, hash) calculation done Write Done ====> Finalization ... ffs formatting... flash: 01227E223C2200:2AEA0000000000 Finalization Done file saved: C:\Archivos de programa\InfinityBox\MModule\backup_security\Alcat el-C820A_JRD26_06A_PCB01_GPRS_MT6226_S02.MAUI_06A_W06 _28_MP_V45__system_log_850B9A98_72F55A1A_20100418-115517.B0X.bin Finished, time used: 5 min 41 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! BR |
04-20-2010, 12:10 | #2 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,861 | Hello, Please, read full flash from this phone and send to [email protected] so we will be able to check what is wrong. Also for now you can flash phone with another 820A firmware from support area, make imei and unlock. |
05-05-2010, 01:36 | #4 (permalink) |
Member: 226845 Status: Offline Thanks Meter: 78 | I know that you have received the flashfile, I've saw your sent e-mail. I've flashed with another version of flashfile from support, but phone became dead, luckily, I could revive it again flashing it at the official support. Have you seen what could be happened with the unsuccessful procedure of making imei? Have you detect any programm bug? I trust you are in the rigth way... Best regards |
Working IMEI changed phone? | Barjo | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 03-01-2015 11:49 |
what prog changes imei on 6110 and how do i do it? | Ravetrancer | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 07-31-2012 20:09 |
Nokia 51xx/61xx imei changer ver. 1.10?????? | Ravetrancer | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 04-06-2012 16:22 |
6110 imei changer !!!!!! | Ravetrancer | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 11-21-2011 01:44 |
