Alcatel E 207 Sucessfully Unlock With Infinity ALCATEL E 207 SUCESSFULLY UNLOCK WITH INFINITY COM5 [VCP0] selected Device: Alcatel E207 "advanced chip detection" active Action: unlock Checking data, wait... Boot... Phone should be Switched OFF ! Press Power button now ! rom version: 0502 Connecting... booting... finalizing... Boot done Check connection... Check connection done Set baud... 812500 Set baud done Check hardware... flash: 012A7E2A242A00:54000000000000 flash: AMD/Fujitsu std [T 003Fx010000 0004x004000] 4Mb Check hardware done Read data... reading Alcatel E207_eeprom_calibration-1... file saved: C:\Program Files\InfinityBox\HModule\backup_Alcatel E207_eeprom_calibration-1_20080404-165612.80E.bin Read data done Check data... Check data done Writing... .. flash: 012A7E2A242A00:54000000000000 Write: simlock Writing done Finished, time used: 57 sec Remove/Install battery now ! BR RAJAN CELLULARHUT |
Hello, Thank you very much for good test report ! |
Bro always say it to me boot fail boot fail i try many time many time. when say power on i push and the set power on. what can i do? |
I have no cable i make cable rx tx and gnd problem is the same always phone on. Br Mahadi |
Whats the prob COM14 [VCP0] selected module v1.29 Device: Alcatel-E207 "advanced chip detection" active Action: unlock Checking data, wait... Boot... Phone should be Switched OFF ! Press Power button now ! Boot fail error: operation failed Finished, time used: 33 sec Remove/Install battery now ! |
Hello, Double check your cable, probably you need to swap RX <-> TX wires. |
