Register | FAQ | Donate | Forum Rules | Root any Device | ★iPhone Unlock★ | [ Easy-JTAG ] | Direct Unlock Source | Search | Today's Posts | Mark Forums Read |
![]() | #1 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Jul 2004 Location: UNITED KINGDOM Age: 43
Member: 74415 Status: Offline Sonork: gsm.zone Thanks Meter: 334 | ![]() regards karim COM2 [VCP0] selected Device: Alcatel-E227 "advanced chip detection" active Action: unlock Checking data, wait... Boot... Phone should be Switched OFF ! Press Power button now ! rom version: 0502 Connecting... booting... finalizing... Boot done Check connection... Check connection done Set baud... 115200 Set baud done Check hardware... flash: 012A7E2A242A00:54000000000000 flash: AMD/Fujitsu std [T 003Fx010000 0004x004000] 4Mb Check hardware done Read data... reading Alcatel-E227_eeprom_calibration-1... file saved: C:\Program Files\InfinityBox\HModule\backup_Alcatel-E227_eeprom_calibration-1_20080606-091152.80E.bin Read data done Check data... Check data done Writing... .......... .......... .. flash: 012A7E2A242A00:54000000000000 Write: simlock Writing done Finished, time used: 120 sec Remove/Install battery now ! second COM2 [VCP0] selected Device: Alcatel-E221 "advanced chip detection" active Action: unlock Checking data, wait... Boot... Phone should be Switched OFF ! Press Power button now ! rom version: 0502 Connecting... booting... finalizing... Boot done Check connection... Check connection done Set baud... 115200 Set baud done Check hardware... flash: 012A7E2A242A00:54000000000000 flash: AMD/Fujitsu std [T 003Fx010000 0004x004000] 4Mb Check hardware done Read data... reading Alcatel-E221_eeprom_calibration-1... file saved: C:\Program Files\InfinityBox\HModule\backup_Alcatel-E221_eeprom_calibration-1_20080606-085416.80E.bin Read data done Check data... Check data done Writing... .......... .......... .. flash: 012A7E2A242A00:54000000000000 Write: simlock Writing done Finished, time used: 186 sec Remove/Install battery now ! o0 |
![]() | #2 (permalink) |
Product Manager ![]() ![]() ![]() ![]() ![]() Join Date: Mar 2005 Location: infinity-box
Member: 130995 Status: Offline Thanks Meter: 35,122 | Thank you very much for test report ! Each test report with attached logs is very important for us so we can see how is Infinity-Box software works and what is possible problems and successfully done work. |
![]() | #5 (permalink) |
Crazy Poster ![]() ![]() ![]() Join Date: Jan 2006
Member: 224906 Status: Offline Thanks Meter: 2 | I'm having a problem desbloquar Alcatel E-221 please help me. hello, I'm having a problem desbloquar Alcatel E-221 please help me. I am not getting post the image of the programme in the forum. |
![]() | #7 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Dec 2001
Member: 8102 Status: Offline Thanks Meter: 118 | E221 Successfully done COM4 [VCP0] selected Device: Alcatel-E221 "advanced chip detection" active Action: unlock Checking data, wait... Boot... Phone should be Switched OFF ! Press Power button now ! rom version: 0502 Connecting... booting... finalizing... Boot done Check connection... Check connection done Set baud... 115200 Set baud done Check hardware... flash: 012A7E2A242A00:54000000000000 flash: AMD/Fujitsu std [T 003Fx010000 0004x004000] 4Mb Check hardware done Read data... reading Alcatel-E221_eeprom_calibration-1... file saved: C:\Program Files\InfinityBox\HModule\backup_Alcatel-E221_eeprom_calibration-1_20080708-005649.80E.bin Read data done Check data... Check data done Writing... .......... .......... .. flash: 012A7E2A242A00:54000000000000 Write: simlock Writing done Finished, time used: 81 sec Remove/Install battery now ! |
The Following User Says Thank You to Seedy For This Useful Post: |
![]() | #8 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Jan 2008 Location: KEF_TUNISIA
Member: 681313 Status: Offline Thanks Meter: 506 | problem after direct unlock e227 with infinity hello friends i had made direct unlock for alcatel E227 with infinity and the fone lost its email and its firmware identity ![]() ![]() ![]() then i tried to flash "ffs" with multibox but nothing happend the fone still like that and the keybord don't work; problem in lcd too...... |
![]() | #9 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,122 | @Seedy Thank you very much for test report ! Each test report with attached logs is very important for us so we can see how is Infinity-Box software works and what is possible problems and successfully done work. @biri26 It can not be true that E227 lost any data after unlock with Infinity-Box, I am sure in this due to I know the unlock method details. So you must post here honest explanation what you have tried to do with phone, in other case we will be unable to help you. |
![]() | #10 (permalink) |
Member: 224906 Status: Offline Thanks Meter: 2 | hello, I want to post my thanks, managed to unlock E-221, I do not have cable and was soldering the wires directly at the point of tp of the cell was so put my finger above the tp and unlock cell. |
![]() | #11 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,122 | Thanks for good test report ! Also, as some people reported about problems with E207 (and other Alcatel models produced in 2008) unlock, please, post here complete text from phone back label (if you still have this phone on hands) so we can see what phones can be unlocked and what phones may have problems. Thank you ! |
![]() | #12 (permalink) |
Member: 224906 Status: Offline Thanks Meter: 2 | I would like to thank our moderator of INFINITYSUPPORT by us and help bring clarification on the BOX I have a problem in my BOX UST-PRO2 time and does not have any answers and looked not only I who is having trouble with the UST, yet nobody tries to help. So once again thank you and congratulations on your work and commitment. |
![]() | #13 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Oct 2002 Location: www.tapgsm.com.ph/forum Age: 46
Member: 16768 Status: Offline Sonork: 1583568 Thanks Meter: 37 | Nice one infinity team,just unlocked E221 today ![]() Heres logs: Press Power button now ! rom version: 0502 Connecting... booting... finalizing... Boot done Check connection... Check connection done Set baud... 115200 Set baud done Check hardware... flash: 012A7E2A242A00:54000000000000 flash: AMD/Fujitsu std [T 003Fx010000 0004x004000] 4Mb Check hardware done Read data... reading Alcatel E207_eeprom_calibration-1... file saved: C:\Program Files\InfinityBox\HModule\backup_Alcatel E207_eeprom_calibration-1_20080719-124753.80E.bin Read data done Check data... Check data done Writing... ......... ......... .. flash: 012A7E2A242A00:54000000000000 Write: simlock Writing done Finished, time used: 88 sec Remove/Install battery now ! BR |
The Following User Says Thank You to Ryuken For This Useful Post: |
![]() | #14 (permalink) |
![]() | #15 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Mar 2000 Location: Bulgaria Age: 53
Member: 1128 Status: Offline Thanks Meter: 13 | With HModule 1.23 sucsesfuly unlock E227: Device: Alcatel-E227 "advanced chip detection" active Action: unlock Checking data, wait... Boot... Phone should be Switched OFF ! Press Power button now ! rom version: 0502 Connecting... booting... finalizing... Boot done Check connection... Check connection done Set baud... 115200 Set baud done Check hardware... flash: 012A7E2A242A00:54000000000000 flash: AMD/Fujitsu std [T 003Fx010000 0004x004000] 4Mb Check hardware done Read data... reading Alcatel-E227_eeprom_calibration-1... file saved: D:\GSM BOX\InfinityBox\HModule\Alcatel-E227_eeprom_calibration-1_20080815-181443.80E.bin Read data done Check data... Check data done Writing... .......... .......... .. flash: 012A7E2A242A00:54000000000000 Write: simlock Writing done Finished, time used: 130 sec Remove/Install battery now ! |
The Following User Says Thank You to Sandino For This Useful Post: |
alcatel s107 unlock ok with infinity box | kopsa2005 | Alcatel & TCL Old Models | 11 | 07-02-2008 09:32 |
When we can unlock W375 with Infinity-Box? | stylius | Infinity-Box | 1 | 05-14-2007 09:03 |
plz is c117 unlock posible with infinity box | ARAB GSM | Infinity-Box | 2 | 10-20-2006 07:49 |
can i unlock p341 with Infinity-Box | elsokary | Infinity-Box | 2 | 08-27-2005 17:45 |
i Can't Unlock G51E with Infinity Box | flechazo | Infinity-Box | 1 | 07-09-2005 14:47 |
