01-17-2010, 16:24 | #1 (permalink) |
No Life Poster Join Date: May 2006 Location: Sambrial (Sialkot)
Member: 282066 Status: Offline Sonork: 100.1590696 Thanks Meter: 569 | Alcatel E221 error with Infnity but done with FG e221 error not unlocked by infinity but unlocked donn with FG COM6 [VCP0] selected module v1.38 Device: Alcatel-E221 "advanced chip detection" active Action: unlock Checking data, wait... Boot ... Phone should be Switched OFF ! Press Power button now ! rom version: 0502 Connecting... booting... finalizing... Boot done Check connection ... Check connection done Set baud ... 115200 Set baud done Check hardware ... flash: 012A7E2A242A00:54000000000000 flash: AMD/Fujitsu std [T 003Fx010000 0004x004000] 4Mb Check hardware done Read data ... reading Alcatel-E221_eeprom_calibration-1... file saved: E:\InfinityBox\HModule\Alcatel-E221_eeprom_calibration-1_20090117-071232.80E.bin Read data done Check data ... Check data done Write ... .......... .......... error: unexpected termination/freez: 06000000 error: unexpected termination/freez: 06000000 error: unknown structure, read flash and send to support ! Write fail error: operation failed Finished, time used: 1 min 36 sec Remove/Install battery now ! --------------------------------------------------- but unlock done by FG Press power on shortly ... Starting communication ... BootRom v05.02 Authorising ... Sending certificate ... Sending preloader ... Preloader started ... Sending applet ... Changing baudrate ... Flash ID(0): 0001:2A7E:2400 IMEI: 3549000153106500 Requesting mepd info ... Saved: LOCOSTO_07.15.39_17.01.2009_SP.bin Direct unlock finished. 1 locks were cleared. Done ! Time needed - 00:00:13 |
The Following User Says Thank You to zeerik For This Useful Post: |
how to fix confirguration key with cyclone [Job done with the last update] | bolaji olugbani | Cyclonebox | 3 | 01-05-2010 09:53 |
K550 Not work with R6BC002 but works with R8BA024 but bad network | -luigi- | Cruiser Suite | 6 | 10-30-2009 16:03 |
Strange problem with 6101 phone! swtichin on with cable but not with battery??? | ReyTech | Nokia Hardware & Hardware Repair | 0 | 08-01-2006 14:06 |
k750i problem with virgin but fine with o2 | cduuffo13 | Sony Ericsson | 2 | 11-01-2005 12:13 |
