06-21-2017, 11:36 | #1 (permalink) |
Freak Poster Join Date: Aug 2011
Member: 1639426 Status: Offline Sonork: khurram136 Thanks Meter: 94 | oppo a37f dead after wrong flash read backup Code: Operation : Read Flash [ v1.11 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 410 [MSM8916] ID_BLOCK_S : 22E2C868 ID_BLOCK_I : 007050E1 ID_BLOCK_L : 7D87FD19B4222F5A057A9AFB441F97B7 ID_BLOCK_L : B9D47AD5C649F17297662BE0E20D1B20 Use CM2 Internal Loader Loader Sent! Initializing ... Error : FH Configuration failed! Remove battery, cable. Check cable and connection. Repeat operation! Reconnect Power/Cable! Operation : Read Flash [ v1.11 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device not found! Check cable, connection and drivers! Reconnect Power/Cable! Operation : Read Flash [ v1.11 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 410 [MSM8916] ID_BLOCK_S : 22E2C868 ID_BLOCK_I : 007050E1 ID_BLOCK_L : 7D87FD19B4222F5A057A9AFB441F97B7 ID_BLOCK_L : B9D47AD5C649F17297662BE0E20D1B20 Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8916 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000003A3E00000 [ eMMC 16 GiB ] ExtInfo : 0x00004000/00004000/00001000/00001000 Boot Ok! Brand : OPPO ProdName : A37f ProdModel : A37f AndroidVer: 5.1.1 Manufact. : OPPO QLMxCPU : MSM8916 DevInfo : MSM8916__OPPO__OPPO__ANDR_v5.1.1__A37f__A37f Reading Flash Content ... [Read Ok] : gpt_main0.bin [Read Ok] : NON-HLOS.bin [Read Ok] : sec.dat [Read Ok] : sbl1.mbn [Read Ok] : emmc_appsboot.mbn [Read Ok] : rpm.mbn [Read Ok] : tz.mbn [Read Ok] : hyp.mbn [Read Ok] : pnvbak.img [Read Ok] : lsplash.img [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : system.img [Read Ok] : cache.img [Read Ok] : persist.img [Read Ok] : misc.img [Read Ok] : driver.iso [Read Ok] : userdata.img [Read Ok] : gpt_backup0.bin Android Info saved! Read finished! Configuration : MSM8916 / eMMC Firmware Size : 3093 MiB Done! Elapsed: 00:06:17 Reconnect Power/Cable! Code: Loading firmware ... Created by Infinity-Box (c) Chinese Miracle II (c) 2017 Device Brand : OPPO Device Manufact.: OPPO Device Model : A33 Device CPU : MSM8916 Device IntName : A33f Device Version : 5.1.1 CU_SWVer : OPPO Device Compile : 7/8/2016 3:09:06 AM Device ExtInfo : A33f Load Ok! Operation : Flash [ v1.11 ] ForceFlashing : Disabled Verify FW package ... Verification passed! 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 410 [MSM8916] ID_BLOCK_S : 22E2C868 ID_BLOCK_I : 007050E1 ID_BLOCK_L : 7D87FD19B4222F5A057A9AFB441F97B7 ID_BLOCK_L : B9D47AD5C649F17297662BE0E20D1B20 Pickup loader from firmware package Loader Sent! Initializing ... Running FireHose on BBID : MSM8916 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000003A3E00000 [ eMMC 16 GiB ] ExtInfo : 0x00004000/00004000/00001000/00001000 Boot Ok! Files in Chain : 33 Flashing now Flashing : gpt_main0.bin Flashing : NON-HLOS.bin Flashing : sec.dat Flashing : sbl1.mbn Flashing : sbl1.mbn Flashing : emmc_appsboot.mbn Flashing : emmc_appsboot.mbn Flashing : rpm.mbn Flashing : rpm.mbn Flashing : tz.mbn Flashing : tz.mbn Flashing : hyp.mbn Flashing : hyp.mbn Flashing : lsplash.img Flashing : boot.img Flashing : recovery.img Flashing : system.img Flashing : cache.img Flashing : persist.img Flashing : misc.img Flashing : driver.iso Flashing : userdata.img Flashing : gpt_backup0.bin Boot settings configured! Flashing done! Done! Elapsed: 00:05:08 Reconnect Power/Cable! Code: Loading firmware ... Created by Infinity-Box (c) Chinese Miracle II (c) 2017 Device Brand : OPPO Device Manufact.: OPPO Device CPU : MSM8916 Device IntName : A37f Device Version : 5.1.1 CU_SWVer : OPPO Device Compile : 5/6/2017 8:08:20 AM Device ExtInfo : A37f Load Ok! Operation : Flash [ v1.11 ] ForceFlashing : Disabled Verify FW package ... Verification passed! 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 410 [MSM8916] ID_BLOCK_S : 22E2C868 ID_BLOCK_I : 007050E1 ID_BLOCK_L : 7D87FD19B4222F5A057A9AFB441F97B7 ID_BLOCK_L : B9D47AD5C649F17297662BE0E20D1B20 Pickup loader from firmware package Loader Sent! Initializing ... Error : FH Configuration failed! Remove battery, cable. Check cable and connection. Repeat operation! Reconnect Power/Cable! Operation : Flash [ v1.11 ] ForceFlashing : Disabled Verify FW package ... Verification passed! 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device not found! Check cable, connection and drivers! Reconnect Power/Cable! Operation : Flash [ v1.11 ] ForceFlashing : Disabled Verify FW package ... Verification passed! 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 410 [MSM8916] ID_BLOCK_S : 22E2C868 ID_BLOCK_I : 007050E1 ID_BLOCK_L : 7D87FD19B4222F5A057A9AFB441F97B7 ID_BLOCK_L : B9D47AD5C649F17297662BE0E20D1B20 Pickup loader from firmware package Loader Sent! Initializing ... Running FireHose on BBID : MSM8916 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000003A3E00000 [ eMMC 16 GiB ] ExtInfo : 0x00004000/00004000/00001000/00001000 Boot Ok! Files in Chain : 34 Flashing now Flashing : gpt_main0.bin Flashing : NON-HLOS.bin Flashing : sec.dat Flashing : sbl1.mbn Flashing : sbl1.mbn Flashing : emmc_appsboot.mbn Flashing : emmc_appsboot.mbn Flashing : rpm.mbn Flashing : rpm.mbn Flashing : tz.mbn Flashing : tz.mbn Flashing : hyp.mbn Flashing : hyp.mbn Flashing : lsplash.img Flashing : boot.img Flashing : recovery.img Flashing : system.img ProgStart : start 917504, num 5767168 Flash Error , No ACK message! Check Battery charge , Cable Error : Flashing failed! Check previous message for more info! Reconnect Power/Cable! |
The Following User Says Thank You to khurram136 For This Useful Post: |
06-21-2017, 12:14 | #2 (permalink) |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Hello, Charge battery to atleast 40% and try again. Br. Infinity Box Team. |
The Following User Says Thank You to PASSIONATE_BOYS For This Useful Post: |
06-21-2017, 14:59 | #4 (permalink) |
Member: 1639426 Status: Offline Sonork: khurram136 Thanks Meter: 94 | write orgnail file with flasher phone power on but bassband and imei damage write infinity backup but same imei damage Code: Card found : D44A8988 , v0135 Infinity-Box Chinese Miracle Qualcomm Module [QLM] v 1.11 Loading firmware ... Created by Infinity-Box (c) Chinese Miracle II (c) 2017 Device Brand : OPPO Device Manufact.: OPPO Device CPU : MSM8916 Device IntName : A37f Device Version : 5.1.1 CU_SWVer : OPPO Device Compile : 9/18/2016 10:16:05 AM Device ExtInfo : A37f Load Ok! Operation : Flash [ v1.11 ] ForceFlashing : Disabled Verify FW package ... Verification passed! 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device not found! Check cable, connection and drivers! Reconnect Power/Cable! Operation : Flash [ v1.11 ] ForceFlashing : Disabled Verify FW package ... Verification passed! 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device not found! Check cable, connection and drivers! Reconnect Power/Cable! Operation : Flash [ v1.11 ] ForceFlashing : Disabled Verify FW package ... Verification passed! 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 410 [MSM8916] ID_BLOCK_S : 22E2C868 ID_BLOCK_I : 007050E1 ID_BLOCK_L : 7D87FD19B4222F5A057A9AFB441F97B7 ID_BLOCK_L : B9D47AD5C649F17297662BE0E20D1B20 Pickup loader from firmware package Loader Sent! Initializing ... Running FireHose on BBID : MSM8916 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000003A3E00000 [ eMMC 16 GiB ] ExtInfo : 0x00004000/00004000/00001000/00001000 Boot Ok! Files in Chain : 34 Flashing now Flashing : gpt_main0.bin Flashing : NON-HLOS.bin Flashing : sec.dat Flashing : sbl1.mbn Flashing : sbl1.mbn Flashing : emmc_appsboot.mbn Flashing : emmc_appsboot.mbn Flashing : rpm.mbn Flashing : rpm.mbn Flashing : tz.mbn Flashing : tz.mbn Flashing : hyp.mbn Flashing : hyp.mbn Flashing : lsplash.img Flashing : boot.img Flashing : recovery.img Flashing : system.img Flashing : cache.img Flashing : persist.img Flashing : misc.img Flashing : driver.iso Flashing : userdata.img Flashing : gpt_backup0.bin Boot settings configured! Flashing done! Done! Elapsed: 00:04:21 Reconnect Power/Cable! |
06-21-2017, 16:21 | #5 (permalink) |
Freak Poster Join Date: Oct 2015 Location: bangladesh
Member: 2471765 Status: Offline Thanks Meter: 87 | DOWNLOAD THIS FILE AND FLASH THIS 100% TESTED.INSIDE FIRMWARE + FLASH TOOL. https://repairmymobile.in/flash/oppo-a37f-stock-rom/ |
The Following 3 Users Say Thank You to technopoint200 For This Useful Post: |
06-23-2017, 15:00 | #8 (permalink) | |
No Life Poster Join Date: Nov 2011 Location: Student
Member: 1686564 Status: Offline Sonork: PM me Thanks Meter: 157 | Quote:
my phone is dead after flash i use both flash file but no power on | |
06-24-2017, 18:31 | #9 (permalink) | |
sir i nead oppo a37fw file pliz my phone not a37fex my phone A37fw | |
07-26-2017, 16:11 | #10 (permalink) | |
Freak Poster Join Date: Jan 2015 Location: Nepal
Member: 2321524 Status: Offline Sonork: 100.1679349 Thanks Meter: 33 | Quote:
stuck's on logo hang many time tried with different version | |
12-04-2017, 14:25 | #15 (permalink) | |||
Freak Poster Join Date: Jun 2014 Location: United States Of Islam
Member: 2203737 Status: Offline Sonork: 1656500 Thanks Meter: 462 | Quote:
http://forum.gsmhosting.com/vbb/f100...sword-2274270/ | |||
The Following User Says Thank You to ch wajid For This Useful Post: |
